Forum » Programiranje » c++ napaka v kodi
c++ napaka v kodi
kretze ::
zdravo masjtri kaj ve kdo kako bi odpravil te napake v kod?? hvala za odgovore
Error error C3861: 'chechguess': identifier not found
Error error C2512: 'dealer' : no appropriate default constructor available
class DIE
private:
int sides;
int valuee;
public:
DIE(int numsides)
unsigned seed = time(0);
srand(seed);
sides = numsides;
roll();
void roll()
valuee = rand() % (sides - 1 + 1) + 1;
int getsides()
return sides;
int getvaluees()
return valuee;
class dealer
private:
DIE kocka1;
DIE kocka2;
int die1valuee;
int die2valuee;
public:
void deal()
die1valuee = 0;
die2valuee = 0;
void rolldice()
kocka1.roll();
kocka2.roll();
die1valuee = kocka1.getvaluees();
die2valuee = kocka2.getvaluees();
string getchoirhan()
string result;
int sum = die1valuee + die2valuee;
if (sum % 2 == 0)
result = "cho (even)";
else
result = "han (odd)";
return result;
int getdie1value()
return die1valuee;
int getdie2value()
return die2valuee;
class player
private:
string name;
string guess;
int points;
public:
player(string playername)
name = playername;
guess = " ";
points = 0;
void makeguess()
int guessnumber;
guessnumber = (rand() % (1 - 0 + 1)) + 0;
if (guessnumber == 0)
guess = "cho (even)";
else
guess = "han (odd) ";
void addpoints(int newpoint)
points += newpoint;
string getname()
return name;
string hetHuess()
return guess;
int getpoint()
return points;
void roundResult(dealer &delivec, player &igralec1, player&igralec2)
cout << "the delaer rolled " << delivec.getdie1value() << " and " << delivec.getdie2value() << endl;
cout << "result " << delivec.getchoirhan() << endl;
chechguess(igralec1, delivec);
chechguess(igralec2, delivec);
void chechguess(player &igralec, dealer &delivec)
string gues = igralec.hetHuess();
string chohanresult = delivec.getchoirhan();
cout << "the player " << igralec.getname() << " guesed " << igralec.hetHuess() << endl;
if (gues == chohanresult)
igralec.addpoints(1);
cout << "awarding " << 1 << "point to add" << igralec.getname() << endl;
void displaygrandwinner(player &igralec1, player &igralec2)
cout << "-----------------------------------------\n";
cout << "game over here are the resuslt\n";
cout << igralec1.getname() << ": " << igralec1.getpoint() << "points\n";
cout << igralec2.getname() << ": " << igralec2.getpoint() << "points\n";
if (igralec1.getpoint() > igralec2.getpoint())
cout << igralec1.getname() << "is the grand winner ";
else if (igralec2.getpoint() > igralec1.getpoint())
cout << igralec2.getname() << "is the grand winner ";
else
cout << "both player are tied ";
int main()
string player1name;
string player2name;
cout << "enter first name of player " << endl;
cin >> player1name;
cout << "enter second name of player " << endl;
cin >> player2name;
dealer delivec;
delivec.deal();
player igralec1(player1name);
player igralec2(player2name);
for (int i = 0; i < 5; i++)
cout << "----------------------------------------\n";
cout << "now playing roudn " << i + 1 << endl;
delivec.rolldice();
igralec1.makeguess();
igralec2.makeguess();
roundResult(delivec, igralec1, igralec2);
displaygrandwinner(igralec1, igralec2);
system("pause");
return 0;
AndrejO ::
funkcija chechguess() je definirana kasneje, kot pa se jo poskusi uporabiti. Dodaj deklaracijo ali pa premakni definicijo pred prvi klic.
Natancno to, kar pise: razred nima privzetega konstruktorja. Ce ga nima, ga bos verjetno moral dodati, ce ne zaradi drugega, pa vsaj zato, da nastavis zacetne vrednosti polj.
| » | c++ rabim pomoč konstuktorjiOddelek: Programiranje | 1428 (1123) | Snowflake2 |
| » | [Java] Podatkovni tipOddelek: Programiranje | 5243 (4895) | piki12 |
| » | [android] vstavljanje slikeOddelek: Programiranje | 1674 (1571) | messi |
| » | C# je mozna referenca do int izven funkcije (direkt v classu torej)Oddelek: Programiranje | 1945 (1759) | TopCat |
| » | tomcat in datasourceOddelek: Programiranje | 2679 (2436) | infiniteLoop |
