c++ napaka v kodi
c++ napaka v kodi
kretze ::
zdravo masjtri kaj ve kdo kako bi odpravil te napake v kod?? hvala za odgovore
Error error C3861: 'chechguess': identifier not found
Error error C2512: 'dealer' : no appropriate default constructor available
class DIE
private:
	int sides;
	int valuee;
public:
	DIE(int numsides)
		unsigned seed = time(0);
		srand(seed);
		sides = numsides;
		roll();
	void roll()
		valuee = rand() % (sides - 1 + 1) + 1;
	int getsides()
		return sides;
	int getvaluees()
		return valuee;
class dealer
private:
	DIE kocka1;
	DIE kocka2;
	int die1valuee;
	int die2valuee;
public:
	void deal()
		die1valuee = 0;
		die2valuee = 0;
	void rolldice()
		kocka1.roll();
		kocka2.roll();
		die1valuee = kocka1.getvaluees();
		die2valuee = kocka2.getvaluees();
	string getchoirhan()
		string result;
		int sum = die1valuee + die2valuee;
		if (sum % 2 == 0)
			result = "cho (even)";
		else
			result = "han (odd)";
		return result;
	int getdie1value()
		return die1valuee;
	int getdie2value()
		return die2valuee;
class player
private:
	string name;
	string guess;
	int points;
public:
	player(string playername)
		name = playername;
		guess = " ";
		points = 0;
	void makeguess()
		int guessnumber;
		guessnumber = (rand() % (1 - 0 + 1)) + 0;
		if (guessnumber == 0)
			guess = "cho (even)";
		else
			guess = "han (odd) ";
	void addpoints(int newpoint)
		points += newpoint;
	string getname()
		return name;
	string hetHuess()
		return guess;
	int getpoint()
		return points;
void roundResult(dealer &delivec, player &igralec1, player&igralec2)
	cout << "the delaer rolled " << delivec.getdie1value() << " and " << delivec.getdie2value() << endl;
	cout << "result " << delivec.getchoirhan() << endl;
	chechguess(igralec1, delivec);
	chechguess(igralec2, delivec);
void chechguess(player &igralec, dealer &delivec)
	string gues = igralec.hetHuess();
	string chohanresult = delivec.getchoirhan();
	cout << "the player " << igralec.getname() << " guesed " << igralec.hetHuess() << endl;
	if (gues == chohanresult)
		igralec.addpoints(1);
		cout << "awarding " << 1 << "point to add" << igralec.getname() << endl;
void displaygrandwinner(player &igralec1, player &igralec2)
	cout << "-----------------------------------------\n";
	cout << "game over here are the resuslt\n";
	cout << igralec1.getname() << ": " << igralec1.getpoint() << "points\n";
	cout << igralec2.getname() << ": " << igralec2.getpoint() << "points\n";
	if (igralec1.getpoint() > igralec2.getpoint())
		cout << igralec1.getname() << "is the grand winner ";
	else if (igralec2.getpoint() > igralec1.getpoint())
		cout << igralec2.getname() << "is the grand winner ";
	else
		cout << "both player are tied ";
int main()
	string player1name;
	string player2name;
	cout << "enter first name of player " << endl;
	cin >> player1name;
	cout << "enter second name of player " << endl;
	cin >> player2name;
	dealer delivec;
	delivec.deal();
	player igralec1(player1name);
	player igralec2(player2name);
	for (int i = 0; i < 5; i++)
		cout << "----------------------------------------\n";
		cout << "now playing roudn " << i + 1 << endl;
		delivec.rolldice();
		igralec1.makeguess();
		igralec2.makeguess();
		roundResult(delivec, igralec1, igralec2);
	displaygrandwinner(igralec1, igralec2);
	system("pause");
	return 0;
AndrejO ::
kretze je izjavil:
funkcija chechguess() je definirana kasneje, kot pa se jo poskusi uporabiti. Dodaj deklaracijo ali pa premakni definicijo pred prvi klic.
kretze je izjavil:
Natancno to, kar pise: razred nima privzetega konstruktorja. Ce ga nima, ga bos verjetno moral dodati, ce ne zaradi drugega, pa vsaj zato, da nastavis zacetne vrednosti polj.
c++ rabim pomoč konstuktorji
Oddelek: Programiranje
61428 (1123) Snowflake2
[Java] Podatkovni tip
235243 (4895) piki12
[android] vstavljanje slike
71674 (1571) messi
C# je mozna referenca do int izven funkcije (direkt v classu torej)
81945 (1759) TopCat
tomcat in datasource
132679 (2436) infiniteLoop
