Forum » Na cesti » Tesla 3
Tesla 3
lufthammer ::
So I drove from Los Altos CA to Portland OR on Tuesday, a drive of over 650miles.
Če jaz napišem, da naredim včasih 1000 km v enem dnevu, sem cepec, ker ne grem raje z avionom. A tale ameriška primerjava je pa OK?
Bi bil čas, da se neha s temi neumnimi primerjavami, ker ne povedo popolnoma nič našim razmeram primernega. Nikakor NE morem niti s Teslo iz Ljubljane do Mostarja preko Bosne in nazaj. Če se motim, bi prosil za vse pumpe na tej relaciji. Mimogrede, v Kočevju ne dela, že lep čas.
Ti nobeni pospeški ne pomagajo.
Unknown_001 ::
Pospeški?
Če rabijo pospeške greš vozit električni gokart. Je isto.![]()
Prosti pad anyone?
Begabt
Begabt
Spock83 ::
codeMonkey je izjavil:
Ampak Spock83 se nič več ne oglaša :D
Torej so v igri Gen-i, Dravske elektrarne in Petrol.
Ali pa seveda Spock83 nima časa za slo-tech, naklada, uživa v debati, itd.
Malo sem pozabil na to temo. Sem vec na tisti splosni.
Javim se decembra ko bom konkretno vedel in ko/ce bom narocil. Zdaj imam Priusa. Na mesec naredim toliko km da za benz placam 300eur. Prakticno mesecni obrok avta bi bil toliko koliko dam za bencin.
Delavce pri Tesli že spet čaka ena udarniška akcija.
Musk hoče imeti 1000 avtov na dan.
On the 27th and 28th, I will be walking the entire Model 3 production line from cells to finished vehicles.
By the 28th, all Model 3 production subsystems need to be at 50+ UPH steady, which is what's needed for a true 1000 vehicles per day rate (taking equipment uptime into account). To be clear, this includes all lines for a particular subsystem, so, for example, general assembly UPH would include both GA3 lines plus GA4.
If you can't see a way to get there, please let me know as soon as possible, so that I can help solve for this outcome. This is extremely important for our prosperity.
Thanks for kicking ass,
Elon
Truga ::
Kvalitetna izdelava, to bo super vplivalo na avto, ko bojo celo zimo vozili polni snega in soli :D
WarpedGone ::
Sneg se je nabral okrog koles?!?!?
Kvaliteta11111
Na avtih se to ne sme dogajat111
Kvaliteta11111
Zbogom in hvala za vse ribe
- spremenilo: WarpedGone ()
Odpadel poden =/= sneg okoli koles.
koyotee ::
WarpedGone je izjavil:
Kvaliteta11111
Dobro so te opral
Rear DVD collector!
JTD power!
JTD power!
WarpedGone ::
Pluženje z avtom po snegu in jokcanje, da se je sneg zaril v razne oprtine in polomu kako plasitko?
Žal ne samo na slotechu ... stupid is by default.
Ti si res trčen, da je zate to sprejemljivo.
Unknown_001 ::
Da se je sneg nekam zarinu ni problem. Da se je kaj zlomilo pa da je šlo za navaden celc... HUD PROBLEM.
Begabt
Begabt
koyotee ::
Nemorš verjet, kere jajca so to za 35000
Rear DVD collector!
JTD power!
JTD power!
Unknown_001 ::
Da se je kaj zlomilo pa da je šlo za navaden celc... HUD PROBLEP
Joj... si kdaj videl kako imajo drugje narejeno zaščito podvozja?
FAIL v designu.
Begabt
Begabt
Unknown_001 ::
Meni to ne gleda glih kot navaden celc. Cisto lahko da je bil zamrznjen.
Sej če se celc nabije pod tisto ploščo pa da ga še baterije sproti malo grejejo... čist normalno, da je iz tega nastala ledenka.
In kaj naj bi ta zaščita bila? Ravna prišrafana Kompozitna plošča narejena po standardu za Gokart? Če hočeš vozit pozimi, dežju itd... vsaj za odvodnjavanje in odrivanje poskrbi. Daleč najbolj kritično je okoli koles.
Begabt
Begabt
BigWhale ::
Zivi bili pa videli. Ce je zapeljal cez kup trdno zbitega in zmrznjenega snega in je potrgal zadevo, potem si je cist sam kriv. Ce se je pa vozil po zasnezeni cesti, potem je pa tole LOL.
hojnikb ::
Works both ways :)
Nemorš verjet, kere jajca so to za 35000![]()
make that 50,000$
#brezpodpisa
- spremenil: hojnikb ()
Unknown_001 ::
Bi se verjetno še kje drugje poznalo glede na to, kako je ta avto nizek.
Begabt
Begabt
WarpedGone ::
Ground clearance: 14 cm (5,5")
Truga ::
Zivi bili pa videli. Ce je zapeljal cez kup trdno zbitega in zmrznjenega snega in je potrgal zadevo, potem si je cist sam kriv. Ce se je pa vozil po zasnezeni cesti, potem je pa tole LOL.Vozil je po navadni cesti. Reminder da se je ze prej nabirala voda ob dezevju tu not (zaradi katere so pol odpadali odbijaci :D), samo sama voda pac niti ni tok grozen problem. Zdaj majo pa not mesanico soli in snega, ko je zima. Spomladi bojo pa zarjavela podvozja :D
Unknown_001 ::
Ja... nekaj normalnga. In če bi res zletl v trd sneg, bi verjetno prej kak odbijač dol potrgal.
Begabt
Begabt
Katerega bi čakal potem pol leta za kos :D
Unknown_001 ::
Poglejte si zaščito na prednji premi. Jaz se ne čudim, od kod sneg, če je pa s strani vse odprto. Ta zaščita je dobesedno zbirališče za plundro in led.
Begabt
Begabt
s1m0n ::
Pri nas je podobna ta zaščita pri motorju :)
Celo kar dosti nižja kot pri M3 pa še nam ni uspelo spravit snega med njo in motor pa je vse podobno odprto pri kolesih. So pa vidne odrgnine kjer koli pogledaš :)
bambam20 ::
lufthammer je izjavil:
Pospeški ti nič ne pomagajo, ker ti noro porablja baterijo. Zato vozjo EV-ji po AC-ju max 100 km/h. zaradi pospeškov. Desni pas ti je najboljši prijatelj in ogromno časa, ki ga nimaš, razen,. če si kvazi bogataš, ki je pravi čas prodal kriptovalute.
Zakaj je kvazi? There's no such thing as 'kvazi bogataš' bogataš.
Unknown_001 ::
Ko bo avto enkrat na dvigalki, poglej kako je narejena.
Begabt
Begabt
s1m0n ::
Verjetno solidno glede na to, da še je na vozilu :)
Tak, da sklepam, da je pri M3 ponesrečen način pritrditve zaščite.
Truga ::
https://www.revealnews.org/article/cali...
problemi z varnostjo v teslini tovarni in lazmi s strani teslinega PRja.
meni osebno najboljsi odsek:
lmao "nasa klinika je boljsa kot klinicni center"
Unknown_001 ::
In verjetno je to kakšna pločevina ali trda udarno odporna plastika. Po možnosti z zagotovljenim odvodnjavanjem za primer, da notri zaide voda.
Begabt
Begabt
Webmojster ::
V letu 2018 smo. Z novejšimi EV-ji se komot pelješ 120, 130km/h z občasnimi pospeševanji tudi več kot 300km z enim polnjenem.
koyotee ::
Webmojster je izjavil:
Mogoče v laboratoriju.
Rear DVD collector!
JTD power!
JTD power!
vostok_1 ::
Jezus kristus. Sedaj vem čemu puščajo podvozje odprto mainstream proizvajalci.
There will be chutes!
It came from the lab.
Nikec3 ::
Kaj pa Hyundai Kona EV?
@WarpedOne o Elonu Musku:
roCkY ::
M3 in kona sta primerljivi vozili, da bi se kdorkoli odločal med njima? Raje kupit Clia ali ICE kono za 10-12k€ pa bo daleč najceneje, če je strošek goriva kot faktor odločitve.
Meni kona zgleda kot jajček za osebe pod 165 cm. M3 je mnogo udobnejši avto a ima zame neuporaben zadek in prevsem zelo nizko sedenje.
Truga ::
M3 in e-kona sta primerljiva avta, ja.
S tem da je e-kona boljsa: vec km na kwh, vec dosega, in kvaliteta izdelave ni na nivoju jugota.
Nikec3 ::
Kolega, Kone za 10-12k ne boš dobil. Sem sedel not in je čisto udobna.
roCkY ::
Jah lej raje normalen avto v katerem je zadovoljen hrbet za 40K kot EV.
Kone, kolikor jih bodo pravili do EU bodo v naslednjih letih komot prodali. Cifre bodo mizerne. Bojda pride le cca. 100000 enot EV iz Kia in Hyundai linij v naslednjem letu.
BigWhale ::
Vcasih smo se delal norca ...
"Ce bi Microsoft delal avtomobile, pol vsake tolk casa avto neb vzgal in bi sam su ven, odprl vsa vrata, jih zaprl in se enkrat probal in pol bi kr slo."
Tesla se temu kr pribliza ... "Joj, rebootat morm." :>
WarpedGone ::
Tesla China official website shows that Tesla has begun to accept low-range electric vehicle Model 3 pre-order, Chinese users can pay for the 8,000 yuan (around $1160 USD) deposit on the official website to book this car online, the new car will be delivered in 2019. Starting price $35000 USD
