java filter excepion handling
BRBR ::
Tole je v filtru, skozi filter gre en .jsp
1. Ne gre v exception
2. strOut = HTML, ki pa iz nekega razloga ni celoten
3. Isti .jsp brez filtra, vse dela OK - HTML = celoten.
4. Ničesar v server logih.
5. Se pravi nekaj mora iti narobe ? znotraj naslednjega try/except. Morda pa ne ujamem vseh exceptionov ?
  GenericResponseWrapper wrappedResponse = null;
  byte[] bytes = null;
  try
  OutputStream out = response.getOutputStream();
  wrappedResponse = new GenericResponseWrapper((HttpServletResponse) response);
  chain.doFilter(request,wrappedResponse);//throws IOException, ServletException
  bytes = wrappedResponse.getData();
  catch (Exception ex)
  String strOut = new String(bytes);
Copy/paste coda z neta, oracle kolikor se spomnim
public class FilterServletOutputStream extends ServletOutputStream {
  private DataOutputStream stream;
  public FilterServletOutputStream(OutputStream output) {
    stream = new DataOutputStream(output);
  public void write(int b) throws IOException  {
    stream.write(b);
  public void write(byte[] b) throws IOException  {
    stream.write(b);
  public void write(byte[] b, int off, int len) throws IOException  {
    stream.write(b,off,len);
public class GenericResponseWrapper extends HttpServletResponseWrapper {
  private ByteArrayOutputStream output;
  private int contentLength;
  private String contentType;
  public GenericResponseWrapper(HttpServletResponse response) {
    super(response);
    output=new ByteArrayOutputStream();
  public byte[] getData() {
    return output.toByteArray();
        @Override
  public ServletOutputStream getOutputStream() {
    return new FilterServletOutputStream(output);
        @Override
  public PrintWriter getWriter() {
    return new PrintWriter(getOutputStream(),true);
        @Override
  public void setContentLength(int length) {
    this.contentLength = length;
    super.setContentLength(length);
  public int getContentLength() {
    return contentLength;
        @Override
  public void setContentType(String type) {
    this.contentType = type;
    super.setContentType(type);
        @Override
  public String getContentType() {
    return contentType;
Spura ::
Ce imas delegate pattern moras delegirat vse methods. Ti ne posredujes flush in close callov, verjetno ker se ti ni dalo vseh metod delegirat.
[JAVA] HTTPS client
Oddelek: Programiranje
173676 (2406) peterv6i
Jasper subreport
132226 (1975) nightrage
tomcat - problem z encodingom
72683 (2597) kopernik
Java - JBoss - Servlet - getOutputStream() has already been called for this response
81386 (1303) kopernik
Kako pošiljanje datotek v JAVI.
142227 (2098) kopernik
