Javascript get .pdf
Javascript get .pdf
BRBR ::
Če gledam v firefoxu, v primeru da dela, XHR response:
%PDF-1.3 ....
...... en kup non readable podatkov
%%EOF
link
Tole ne dela ni�, pride na servlet po podatke, na klientu pa je response = null.
xhr.onload,xhr.onerror se ne sproĹžita
 function loadPdfBlob(u_id)
          var xhr = new XMLHttpRequest();
xhr.open('GET', contextPath + 'servlet path?u_id='+u_id, true);
xhr.responseType = 'arraybuffer';
xhr.onload = function(e)
  if (this.status == 200)
    var uInt8Array = new Uint8Array(this.response);
    var i = uInt8Array.length;
    var binaryString = new Array(i);
    while (i--)
      binaryString[i] = String.fromCharCode(uInt8Array[i]);
    var data = binaryString.join('');
    var base64 = window.btoa(data);
    document.getElementById("pdfFrame").src="data:application/pdf;base64,"+base64;
xhr.onerror = function(e) {
  alert("Error " + e.target.status + " occurred while receiving the document.");
xhr.send();
Tole dela, ampak ne pikaĹže pdf-ja (XHR respons , kot zgoraj, na vrhu)
<input type ="button" value ="A" onClick ="$.get('servlet path',{ u_id:'<%=con.rs.getString("u_id")%>'},function(data){ document.getElementById('pdfFrame').src = data;})"/>
Kaj je za popravit ? Blob iz baze je zgleda OK.
  • spremenil: BRBR ()
BRBR ::
Popravek:
Kao dela, na Google chrome, na IE in FF pa ne.
Klik na B gumb.
test page
NA GC sicer piše v debugerju "Resource interpreted as Document but transferred with MIME type application/pdf"
ter potem sledijo base64 data in dela.
Kakšna ideja v čem je problem ?
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344392224 (132227) Macketina
jquery ajax problem
Oddelek: Izdelava spletišč
81925 (1547) miko22
[javascript] zazeni, pocakaj, osvezi
61329 (1162) detroit
[JavaScript][XML] Zapis v .xml fajl!
72165 (2066) rokpok
[php] štetje prijavljenih uporabnikov!
211685 (1422) Brilko
