Davčna blagajna na androidu (Xamarin)
TadejGruber ::
Pozdravljeni.
Trenutno razvijam davčno blagajno na Androidu. Uporabljam pa Xamarin Studio (platforma Xamarin.Android).
Vem kako se v C# za desktop aplikacije naredi podpis XML dokumenta s certifikatom, vendar ta ista koda ne deluje na Androidu (Xamarinu).
SignedXml razreda mi sploh ne zazna, javlja pa mi napako "Can't implicitly conver System.Xml.XmlElement to System.XML.XmlElement" (verziji obeh knjižnic sta enaki).
Koda za podpis je takšna (če bo komu pomagala):
System.Xml.XmlDocument xmlDoc = new System.Xml.XmlDocument ();
xmlDoc.Load (filename);
// ------------že tukaj javi napako---------------------
System.Security.Cryptography.Xml.SignedXml signedXml = new System.Security.Cryptography.Xml.SignedXml (xmlDoc);
byte[] data = cert.GetPublicKey ();
string base64 = Convert.ToBase64String (data);
RSACryptoServiceProvider rsaCSP = (RSACryptoServiceProvider)cert.PrivateKey;
CspParameters cspParameters = new CspParameters ();
cspParameters.KeyContainerName = rsaCSP.CspKeyContainerInfo.KeyContainerName;
cspParameters.KeyNumber = rsaCSP.CspKeyContainerInfo.KeyNumber == KeyNumber.Exchange ? 1 : 2;
RSACryptoServiceProvider rsaAesCSP = new RSACryptoServiceProvider (cspParameters);
signedXml.SigningKey = rsaAesCSP; //newKey;
System.Security.Cryptography.Xml.KeyInfo keyInfo = new System.Security.Cryptography.Xml.KeyInfo ();
System.Security.Cryptography.Xml.KeyInfoX509Data keyInfoData = new System.Security.Cryptography.Xml.KeyInfoX509Data ();
keyInfoData.AddIssuerSerial (cert.Issuer, cert.SerialNumber);
X509Extension extension = cert.Extensions [1];
AsnEncodedData asndata = new AsnEncodedData (extension.Oid, extension.RawData);
keyInfoData.AddSubjectName (cert.SubjectName.Name);
System.Security.Cryptography.Xml.Reference reference = new System.Security.Cryptography.Xml.Reference ();
reference.Uri = "#test";
reference.DigestMethod = @"http://www.w3.org/2001/04/xmlenc#sha256";
System.Security.Cryptography.Xml.XmlDsigEnvelopedSignatureTransform env = new System.Security.Cryptography.Xml.XmlDsigEnvelopedSignatureTransform ();
reference.AddTransform (env);
signedXml.AddReference (reference);
keyInfo.AddClause (keyInfoData);
signedXml.KeyInfo = keyInfo;
signedXml.SignedInfo.SignatureMethod = "http://www.w3.org/2001/04/xmldsig-more#rsa-sha256";
signedXml.ComputeSignature ();
System.Xml.XmlElement xmlDigitalSignature = (System.Xml.XmlElement)signedXml.GetXml ();
XmlNode element = xmlDoc.GetElementsByTagName ("fu:InvoiceRequest") [0];
element.AppendChild (xmlDigitalSignature);
Če kdorkoli ve kaj delam narobe ali morda za kakšen drug način kako zgenerirati podpis Xml datoteke (niza), se priporočam za vso pomoč, ki jo lahko dobim.
Tadej Gruber
stb ::
Še enkrat preberi sporočilo o napaki:
TadejGruber ::
stb je izjavil:
Se opravičujem, to sem jaz tiskarsko napako naredil, ko sem tipkal.
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344389607 (129610) Macketina
E-račun
218851 (5614) ivanhoe5x
PHP davčna blagajna
189068 (7092) brble
[JAVA] HTTPS client
173679 (2409) peterv6i
C# - xml import v bazo
71933 (1751) nuclear
