Forum » Problemi človeštva » Konflikt v Siriji
Konflikt v Siriji
"They destroyed 11 tanks and infantry fighting vehicles, 31 vehicles carrying large-caliber automatic guns, more than 300 militants," the ministry said.
https://www.almasdarnews.com/article/ru...
- spremenilo: Telbanc ()
http://www.middleeasteye.net/news/us-st...
US strikes on Syrian troops: Report data contradicts 'mistake' claims
Deir Ez-Zor, tisti majhen Ĺžep SAA sredi IS podroÄŤja...
Journalist Elijah Magnier of the Kuwait daily newspaper Al Rai has followed the struggle between the Syrian army and IS for control of Deir Ezzor closely for years.
He told Middle East Eye in an email that at the time of the air strike the defence of the airport depended entirely on four interconnected Syrian army positions on the Thardeh mountain chain.
Magnier said IS forces had been carrying out “daily attacks” on Deir Ezzor airport prior to the US air strikes but had failed, mainly because of the higher elevation of the four Syrian bases in relation to the positions occupied by IS further south.Â
Fabrice Balanche, a leading French expert on Syria who is now a visiting fellow at the Washington Institute for Near East Policy, said in an interview with Middle East Eye that the Syrian army had maintained continuous control over the base at Thardeh mountain from March 2016 until the US air strikes, which then resulted in IS gaining control of it.
In sedaj naj jim Rusi zaupajo.
7tom1ja ::
Na nas leži naloga, da naprej razvijamo našo samoupravno socialistično družbo,
da jo gradimo na revolucionarnih temeljih, temeljih marksizma.
Brigada AVNOJ 77;Komisar Ivan Janša
7982884e ::
BTW, če pade USA pomoč, pade tudi FSA.
So pa dol poslali še 300 specialcev.
Za pomoč pri osvoboditvi Mosula, so rekli, in Mosul je, kot vsi vemo, v Siriji.
Sicer bodo pa itek vsem porezali glave, eni ali drugi.
am, ne. ti specialci so za rako, kar so jasno povedali. za SDF torej. mosul je druga zgodba in ni bil nikjer omenjen.
Kako se lahko tak napad v puĹĄÄŤavi praktiÄŤno zgodi? Ruski sateliti, izvidniĹĄka letala niÄŤ ne vidijo?? Isto je bilo poleti v napadu na Tabqo.
SAA se je dobesedno v enem dnevu dezintegrirala.
v tej isti temi je folk isto govoril za americane, da kako ni mogoce, da pridejo isisovci v napadalne polozaje, brez da bi vmes kasirali bombe. in da je to razlog za amerisko zaroto.
vzrok je pac drugacen, isis je napade v okolici palmire zacel ze 4 dni nazaj, tako da se je ze od takrat naprej vedelo, kaksni so nameni in da grozi nevarnost. vendar stvar ni tako enostavna kot zgolj poslati par avionov in pometat par bomb. ce sile na tleh ne nudijo nobenega posebnega odpora, so ne-vodene bombe nad razprsene napadalce v puscavi, ki jih je povrh vsega ze problem najt, ne prevec ucinkovite. helikopterji malo bolj z uporabo topov s termalnimi kamerami, samo ce so sele vceraj prisli, so ocitno bili (pre)pozni.
Vanich ::
Verjetno so upali da se bodo preselilil v Sirijo. Toda kot kaže bodo okrepili sile
v boju proti nevernikom,v Mosulu...
Samuel ::
Torej Palmira je padla. Ker Rusi niso naredili praktično ničesar, je edina logična razlaga ta, da Rusi podpirajo ISIS.
Jelda?
Jelda?
noticably not worth noticing.
Ti kozjejebci so zdaj vsi v Palmiri in so na kupu.
Zdaj jih samo še obkoliš in popucaš...
Matako ::
Palmira se imenuje "mesto" iz zgodovinskih razlogov, če odšteješ antične razvaline gre za malo večji kraj z recimo temu centrom 1 kvadratni kilometer. Plus letališka steza (1 komad) vzhodno, ki nima pomena.
Počasi bo treba spoznati, da so tudi Rusi popolnoma nesposobni. Nakar vam ne ostane nihče več, le puščava polna Arabcev, ki so vsi glih.
Vsi.
Vsi.
/\/\.K.
- spremenil: Matako ()
Točno to. Zakaj bi branili 1 km2 mesta, če nima smisla. Strateško je čisto nepomembno...
Ne vem, če je neodločitev da ne gredo v brezzveze akcijo ravno znak nesposobnosti.
- spremenil: Invictus ()
Samuel ::
Dosti lažje je ISIS spucat na prostem, kot pa zaprtega v kakšnem mestu. Smo videli to v Ramadiju, Faluji, Manbiju in sedaj v Mosulu.
Cervantes ::
Me pa čudi, porka.
A Rusi dobivajo satelitske posnetke z enodnevno zamudo al itak gledajo sam GoogleEarth?
Satelitski posnetki so ekvivalent gledanju skozi slamico. Enostavno ne vidiš dovolj terena za pokrivanje takega območja.
Ni to Holivud.
Vir je, kakršen je, ampak
https://twitter.com/JACM212/status/8080...
so pa priskrbeli malo dokumentarnega materiala
https://twitter.com/RamiAILoIah/status/...
BPM-97 @ Wikipedia
Ni to Holivud.
For fucks sake. IS claiming 30 tanks, 6bmp, 6 122mm guns 7 23mm mounted technicals and a bunch of ATGMs ammo small arms captured in #Palmyra
BPM-97 @ Wikipedia
papasmrk ::
Me pa čudi, porka.
Rusi gledajo tisto kar američani želijo, da rusi vidijo
- spremenil: papasmrk ()
7982884e ::
se milijontic, s sateliti ne mores pokrivati majhnih sovraznikovih manevrov na velikem obmocju. geostacionarni sateliti so predalec, da lahko razlocujejo kaj uporabnega v realnem casu, sateliti v nizki orbiti pa seveda niso vedno nad istim mestom. in oboji majo tak problem, kot je pac man napisal zgoraj - gledanje skozi slamico.
najboljsa resitev je nekaj takega, kot imajo americani v afganistanu - blimpi s kopico senzorjev in IR kamer:
hammock ::
Predvidevam da tole leti vsaj 3 km visoko, drugace bi bilo easy target za ostrostrelce, ali kaksno tezko strojnico.
Zelo na hitro z Google Earth - okrog Palmire je za cca 3 Slovenije puščave, če se šteje še tisto čez mejo (Jordanija, Irak) 6-10.
Kdor želi v tem senu iskat iglo z metodo ostrega očesa, naj kar izvoli.
SimplyMiha ::
Ja, sploh ne razumem, zakaj sploh braniti Palmiro oziroma Tadmur. Kvečjemu 30 tisoč prebivalstva, naj jih evakuirajo, onesposobijo infrastrukturo in gredo vojno bit tam, kjer se splača. Puščavo lahko očistijo z grabljami potem, ko je vse drugo fertik.
Cervantes ::
I see.
Se posipam.
7982884e ::
SimplyMiha je izjavil:
ker je branjenje cenejse (v smislu zivljenj in opreme) kot eventuelno ponovno zavzetje?
pri isisu nikoli ni veljalo, da jim lahko nekja prepustis, pa bodo enkrat kar semi sli stran. vsaj dokler je to stratesko pomembna lokacija.
O, lej, lej...razpoke med demokrati in odkrita debata o tem kako ZDA financirajo in opremljajo IS in Al-Nusro (kakorkoli se že sedaj imenuje):
To! Glupi iranski ajatole (ki seveda niso Arabci, ampak Perzijci) redijo in spodbujajo in financirajo in oborožujejo in usmerjajo v bistvu arabsko nacionalistično kačo na svojih prsih.![]()
V bistvu financirajo vsakega, ki je pripravljen delati za njih.
Tudi al-Kaido, mimogrede. Ja, vem da so Iranci šiiti, al-Kaida pa suniti. Da, tudi oni vedo. Iranskih mul to ne zanima, zanima jih samo to kdo je pipravljen streljati po Zahodnjakih (ali Židih).
Iran and state-sponsored terrorism @ Wikipedia
No in te imate vi za manjše zlo. Mnenje o tem kdo je tu glup naj si ustvari vsak sam. Jaz sem si ga že, Iranske mule pa verjetno tudi.
To se je vse že zgodilo, Palmira je (spet) ruševina brez prebivalcev. Zakaj jo branijo? Menijo, da je to ceneje, kot ponovno kupovanje Palmire od ISIS.
'Zavzetje' pred 9 meseci je bila namreč konjska kupčija v zameno za nafto. ISIS Palmire sploh ni branil, SAA jim je tudi povedala kaj in kdaj bodo bombardirali, da so se lahko odmaknili.
http://www.businessinsider.com/assad-is...
Zato jo je tudi ISIS spet napadel - očitno jih koalicijske sile v Mosulu tako stiskajo, da potrebujejo novo odkupnino za financiranje vojne. Nekdo bo moral spet razvezati denarnico, sicer zna tale velika zmaga v Alepu pasti v vodo.
- spremenil: Smrekar1 ()
Precej o uspehu satelitov pove dejstvo, da se ruske letalske sile za napade zanašajo na sirske izvidniške Su-22M. Težava je v tem, da analogni fotoaparati na njih niso najbolj primerni za spremljanje premikov sil v realnem času.
Russian intelligence gathering capabilities in Syria are insufficient, pressuring the SyAAF to send its Su-22M-4Ks equipped with 40-year-old KKR-1 pods — equipped with old, analog film cameras — to fly reconnaissance for the Russian air force.
Uporabljajo tudi svoje izvidnike, ki imajo pogoste težave z vidom. Posledice seveda ne izostanejo:
In late February 2016, a Tu-214R flying high above Aleppo failed to detect a large concentration of Islamic State fighters approaching across the desert toward the road connecting Khan Nassir with Aleppo.
Because of this failure, the jihadists not only mauled several minor loyalist units controlling the area, but severed the only supply route for 20,000 Syrian soldiers and Iranian Revolutionary Guards Corps members for nearly a week.
https://warisboring.com/does-the-russia...
Šiiti vsaj dokaj spoštujejo kristjane, namesto da jim režejo glave, kot satanisti za katere navijaš.
Za začetek najprej ti dokaži, da so vsi sirski uporniki enaki in da vsi režejo glave vsepovprek.
Ko boš nekoč priznal, da to ni res se lahko poglobimo v to kaj šiiti delajo kristjanom.
https://www.nytimes.com/2014/03/15/opin...
Matako ::
Evo - Asad je postal žrtev pripovedi, da "velika večina muslimanov ni džihadistov". Točno to: hadžiji se v veliki večini furajo po cestah in družijo skupaj z ostalimi. Neki tanki in oklepniki.. to je bolj eksotika in izid vojne ni odvisen od tega.
Zdaj jih pa loči iz zraka. Ampak ko pa mi omenimo točno isto težavo s profesorji smo pa takoj označeni za negativce.
Vsi so isti. V.s.i.
/\/\.K.
Vsi so isti. V.s.i.
OK, samo potem je on itak tudi tak in ne moreš tega uporabljati kot nek smiseln argument proti upornikom, kajne?
Matako ::
Vsi so isti. V.s.i.
OK, samo potem je on itak tudi tak in ne moreš tega uporabljati kot nek smiseln argument proti upornikom, kajne?![]()
Arabec je arabec. Saj kaj je glavni problem džihada? Da je to zgolj malo spimpan arabski recimo temu... sekularni tribalizem. To so njihove navade.
Izraelci so to že davno pogruntali in pač temu ustrezno ukrepajo že desetletja. Zdaj se recimo vidi kako nujno je bilo zasesti Golansko planoto, kako prav zdaj to pride in koliko drame so prihranili vsem s tem.
Še premalo so zasedli.
/\/\.K.
Ne bom ti ugovarjal, ampak glavni argument za klavca Assada je na tej točki kaput.
Zakaj bi ga torej zagovarjal? Imaš glavorezce ki so nominalno na naši strani in glavorezce, ki nas sovražijo iz dna srca. Prvi se borijo proti Assadu, drugi za njega. Zakaj bi torej podpiral te druge? Podporo FSA in drugim lahko osmislimo, medtem ko podpora Rusko-Iranske osi v nobenem pogledu ni logična.
Matako ::
Saj pravim, Izraelci so se '73 prehitro ustavili. Mimogrede tisti konfilkt je bil ekvivalent zahrbtnega, nizkotnega napada ulične tolpe. Takrat so si Sirijci zaslužili, da se jih nuka in svet bi razumel. Samo prevladala je skrb za okolje in čisti zrak.
/\/\.K.
Ne bom rekel, da ne. Ampak to ni bilo zaman, Egpit so s tem potegnili iz sovjetske orbite in postal je prva arabska država, ki je normalizirala odnose z Izraelom. Jordanija je kmalu sledila. Sirija se pač oklepa svojega nacional-socializma, pardon arabskega social-nacioalizma in v stari tradiciji sovraži Žide še naprej.
Nič od tega seveda ne pomeni, da mora pri temu ostati ali da se države ne da vsaj zakrpati. Je pa res, da bo morala dobiti precej boleč tretma, ki bo vključeval vsaj federalizem če ne kar konfederalizma. Bosanski scenarij ni najbolj prijeten in državo pohabi, ampak če hočejo Sirijo obdržati kot ozemeljsko enotno državo - in to vse strani pravijo, da je njihov cilj - bo to kar nujno.
Problem je, da so vsi isti. Dokler zahod tja dol pumpa pomoč in denar, mu je vsak klavec naklonjen. Takoj, ko tega zmanjka, vojna. In novi interesi.
Pa ni važno kateri klavec je na oblasti. Kar se tiče mene, naj bo tak, ki zna svoje ljudi držati pod kontrolo. In tak, ki ima že dosti pod palcem, saj bo drugače hotel nadomestiti svoj manjko bogastva na vse možne načine.
Egipt je tipičen primer. Mubarak je sprejel pomoč od ZDA, ker je SZ takrat crknila, dobil vojaško pomoč (F-16, pa še kaj), in najbrž dovolj keša za svoje družinske člane.
Pa je bil kljub vsemu klavec, samo potem se je nanj malo pozabilo. Izrael pa si je zavaroval svojo zahodno meja.
Zdaj, po arabski pomladi, se Egipt spet obrača k Rusiji in Franciji. Pač baranta s svojo pozicijo in se pogaja v smislu, kdo da več...
papasmrk ::
A niso tile "naši" glavorezci isti kot tisti, ki delajo masakre po Parizu, Bruslju, Carigradu....
Če američani pravijo, da so to naši in da so to dobri in prijazni ljudje potem pa ja - jih podpirajmo.
Tjah, Assad to evidentno ni.
SZ je takrat še kar migala, sploh zaradi naftnega šoka. Resneje je začela crkovati kako desetletje kasneje.
Morebitne podobnosti s sedanjim stanjem niso zgolj naključne.
Jeh, to s Pomladjo nima kakšne strašne zveze. Dvig ekstremistov v državi jim je sesedel edini steber gospodarstva in zdaj išče alternative. Dvig ekstremistov se je začel precej pred Pomladjo, ta ga je morda malce pohitrila, to je bilo tudi vse.
Nak, to so drugi osebki. Ne moreš biti na dveh mestih hkrati, veš?
Američani ne trdijo nič podobnega. Trdijo samo to, da so manjše zlo od dosedanjih glavorezcev.
Oni trdijo da bodo bodoči glavorezci bolj naklonjeni njim, kot pa sedanji.
Za rajo se ne spremeni nič...
Matako ::
Vsi so glavorezci. Arap'c je Arap'c.
Rusi delajo načeloma prav, da bombardirajo Sirijo - koncept je v osnovi zdrav. Ne bo pa rezultatov.
/\/\.K.
konspirator ::
5000 isil teroristov naj bi napadlo Palmiro
https://www.logicno.com/politika/sto-se...
Također je potvrdio kako ima saznanja o prebacivanju oko 5 000 terorista, koji su na Palmiru poslani iz Raqqe, Deir Ez-Zora, ali i iz Iraka, koji su uspjeli iznenaditi i protjerati vladine snage iz Palmire.
papasmrk ::
Teli ISIL-ovci me spominjajo na white walkerse iz GoT. Tamani jih koalicija 50-ih držav ampak te pa še kar prihajajo...
konspirator ::
13 jih je naštetih na wiki.
Military intervention against ISIL @ Wikipedia
United States
Australia
Canada
Belgium
Denmark
France
Germany
Italy
Turkey
Netherlands
Jordan
Morocco
United Kingdom
S tem da recimo Nemci s Tornadi opravljajo samo izvidniške misije.Danci, Avstralci, Maročani, Belgijci, Kanadčani, Italijani in še kdo je bolj za številko zraven.
Turki so itak poglavlje zase, kaj oni delajo v anti isil koaliciji je misterija.
- spremenilo: konspirator ()
Boljša primerjava bi bila z revolucionarno Francijo.
So tudi druge podobnosti, ki niso zgolj akademskega značaja. Nekaterim so pravzaprav ključne. Seveda so tudi ključne razlike, ampak to je že druga zgodba.
arnecan1 ::
Absolutno ni res. Assad je dosti dosti manjši glavorezec. Je pa na žalost tako, da je v islamskem svetu brez glavorezca še večja anarhija in nasilje. Bučke o demokraciji in sekularnem islamu lahko greš prodajat drugam.
Sicer pa vprašaj kristjane v Siriji, pod katerim glavorezcem želijo živeti.
Idealno bi sicer bilo, da bi živeli v samostojni državi ali avtonomiji, ampak na žalost je ob brezbrižnosti Zahoda islam uspel odpraviti verska nesoglasja med islamom in krščanstvom s tem, da je odstotek kristjanov drastično upadel.
Ti in podobni tebi nadaljujete z genocidom nad najstarejšimi krščanskimi cerkvami na svetu. Zaradi nekih interesov ali česarkoli že.
Bi se razumel, da bi ob menjavi sistema naredili...
Samuel ::
Turkey Security official: ISIS has seized plenty of MANPADS left behind by SAA after the fall of Palmyra yesterday.
http://syria.liveuamap.com/en/2016/12-d...
Kaj vse je ta SAA pustil ISISu tam v Palmiri? Keri butli neorganizirani in nesposobni.
Vanich ::
Samuel ::
V bistu v Alepu pa res ni nobenega ISISovca. ISIS se klofa z FSAjev malo v desno tam okoli AL Baba.
Vanich ::
Ko so klali ujeta SAA vojake v Alepu, nisem videl nobene razlike med njimi in Daesh. Ali pa ko so obglavljali rahitičnega otroka snetega z infuzije iz bolnice na kasonu kamiona. Zinki? Al Nusra? Ahrar Al Sham? Don't be stupid. If it walks like a duck...
- spremenil: Vanich ()
