[Qt/C++]problem z Undefined reference na konstanti znotraj razreda
KernelPanic ::
Imam sledec razred:
#ifndef UEPEOPLEMODEL_H
#define UEPEOPLEMODEL_H
#include <QImage>
#include <QVariant>
#include <QStringList>
#include <QDebug>
#include <QHash>
#include <QByteArray>
#include <QtSql/QSqlError>
#include <QtSql/QSqlQueryModel>
#include <QtSql/QSqlRecord>
#include <QModelIndex>
#include <QQuickImageProvider>
#include "../settings/uedefaults.h"
#include "../settings/uetypes.h"
class UePeopleModel : public QSqlQueryModel, QQuickImageProvider
    Q_OBJECT
public:
    UePeopleModel(QObject *parent=0);
    ~UePeopleModel();
    QVariant data(const QModelIndex &index,
                  int role) const Q_DECL_OVERRIDE;
    QImage image(const QString &id) const;
    QImage requestImage(const QString &id,
                        QSize *size,
                        const QSize &requestedSize);
    UeTypeRoles roleNames() const;
public:
    static const int UePersonNameRole=0x101;//Qt::UserRole+1;/*0x0101;*/
    //static const int UePersonImageRole=UePersonNameRole+1;/*0x0102;*/
    //static const int UePersonImageRole=Qt::UserRole+2;
#endif // UEPEOPLEMODEL_H
in njegovo implementacijo:
#include "uepeoplemodel.h"
UePeopleModel::UePeopleModel(QObject* parent)
    : QSqlQueryModel(parent),
      QQuickImageProvider(QQmlImageProviderBase::Image,
                          QQmlImageProviderBase::ForceAsynchronousImageLoading)
    QSqlDatabase db;
    if(!QSqlDatabase::connectionNames().contains(UePosDatabase::UeDatabaseConnectionNames::DATABASE_CONNECTION_NAME_PEOPLE,
                                                 Qt::CaseInsensitive))
            db=QSqlDatabase::addDatabase(UePosDatabase::DATABASE_DRIVER,
                                         UePosDatabase::UeDatabaseConnectionNames::DATABASE_CONNECTION_NAME_PEOPLE);
    }   // if
    db.setHostName(/*this->uePosSettings()->ueDbHostname()*/UePosDatabase::UeDatabaseConnectionParameters::DATABASE_HOSTNAME);
    db.setDatabaseName(/*this->uePosSettings()->ueDbName()*/UePosDatabase::UeDatabaseConnectionParameters::DATABASE_NAME);
    db.setUserName(/*this->uePosSettings()->ueDbUser()*/UePosDatabase::UeDatabaseConnectionParameters::DATABASE_USERNAME);
    db.setPassword(/*this->uePosSettings()->ueDbPassword()*/UePosDatabase::UeDatabaseConnectionParameters::DATABASE_PASSWORD);
    if(db.open())
        this->setQuery(UePosDatabase::UeSqlQueries::UeTablePeople::SQL_QUERY_GET_ALL_PEOPLE,
                       db);
    else
        qDebug() << db.lastError().text();
}   // default constructor
UePeopleModel::~UePeopleModel()
}   // default destructor
QVariant UePeopleModel::data(const QModelIndex &index,
                             int role) const
    QVariant value=QSqlQueryModel::data(index,
                                        role);
    if(value.isValid())
        switch(role)
        case UePeopleModel::UePersonNameRole:
                return value.toString();
            }   // case
        case UePeopleModel::UePersonImageRole:
                return QString::number(index.row());
            }   // case
            default:
                value=QVariant();
        }   // switch
    }   // if
    return value;
}   // data
QImage UePeopleModel::image(const QString &id) const
    int iRow=id.toInt();
}   // image
QImage UePeopleModel::requestImage(const QString &id,
                                   QSize *size,
    QImage image=this->image(id);
    *size = image.size();
    return image;
}   // requestImage
UeTypeRoles UePeopleModel::roleNames() const
    UeTypeRoles roles;
    roles.insert(UePersonNameRole,
                 "UePersonNameRole");
    roles.insert("UePersonImageRole",
                 UePersonNameRole);
    return roles;
}   // roleNames
V .cpp datoteki mi v vrsitci (v metodi roleNames())
javi napako:
uepeoplemodel.cpp:87: error: undefined reference to `UePeopleModel::UePersonNameRole'
Zakaj za vraga?!
Lp,
Marko
stapler rump ::
KernelPanic ::
stapler rump je izjavil:
Tole si preberi.
Sem ze prej, ampak v cem je fora?!
Jeremias ::
Na hitro. Predvidevam da tvoja funkcija deklarirana kot UeTypeRoles::insert(const int &type, String &name) oz. nekaj podobnega. No problem pri tebi je, da funkcija za prvi parameter pričakuje referenco, ker pa ti imaš UePersonNameRole spremenljivko deklarirano kot static (katero kompajler zamenja z dejansko vrednostjo ob prevajajnju) ti ne more podat kot referenco in zaradi tega dobiš error. Možnosti imaš tu dve, umakneš static od spremenljivke ali pa enostavno spremeniš funkcijo insert da sprejema int namesto referenco na int.
Jernej
KernelPanic ::
Jeremias je izjavil:
Funkcija pricakuje navaden int, drugi parameter je QByteArray:
    UeTypeRoles roles;
    roles.insert(0x0101,
    roles.insert(0x0102,
                 "UePersonImageRole");
    return roles;
}   // roleNames
UeTypeRoles je pa deklariran kot:
typedef QHash<int, QByteArray> UeTypeRoles;
Ze veckrat sem konstante znotraj razreda deklariral kot static constpa nikoli nisem imel tezav in mi ni jasno, v cem je fora!
windigo ::
Tako, kot so ti napisali: QHash::insert(const Key & key, const T & value) jemlje reference, ne vrednosti, kompajler pa reference sploh nima, ker se je pisec kompajlerja odločil, da bo v takem primeru povsod po kodi raje vstavil neposredno vrednost in ne bo alociral prostora za statično spremenljivko (saj gre za konstanto), tukaj zato ne more narediti reference.
Workaround je simpl:
const int myRole = UePersonRoleName;
roles.insert(myRole, "bla bla");
KernelPanic ::
windigo je izjavil:
AAAA, torej tukaj sploh ni tezava v deklaraciji static const memberja znotraj razreda! Bom sedaj se malo potuhtal, se javim, kaj sem spacal! Hvala za obrazlozitev, sedaj sem se 1x pogledal funkcijo insert in da, jemlje reference, slamparija, slamparija ... :D
windigo ::
Če bi bil insert klican s parametri po vrednosti, bi se ob klicu ustvarile kopije objektov key in value. V primeru int in char * to ni poseben problem, pri kakšnem drugem objektu pa bi se klicali copy-konstruktorji in destruktorji, ali pa bi morda zasedli precej prostora na skladu. Da o morebitnih kasnejših problemih z identitetami niti ne govorim.
Zadeva s deklaracijami in definicijami razrednih statičnih konstant za int pa je zgodovinsko rahlo komplicirana (spreminjala se je do standarda do standarda), več o tem tukaj.
windigo ::
Btw,
out of class definicija
const int UePeopleModel::UePersonNameRole;
bi po mojem pomagala v skoraj vseh primerih.
KernelPanic ::
windigo je izjavil:
Sem takole resil, kot si predlagal, hvala, sicer je malo grdo, ampak dela! :D
phantom ::
To je tudi odvisnocod kompajlerja. Clang konstante razreda (static const int) vstavi direktno, tudi kadar funkcija jemlje reference, in bi tvoja originalna koda delovala. GCC pa, če funkcija vzame referenco (četudi je const), konstanto pošlje kot referenco do konstante, torej jo moraš imeti definirano tudi v .cpp fajlu, isto kot static spremenljivko, drugače bo undefined reference.
:wq
  • spremenil: phantom ()
Qt/QML zajem podatkov iz podatkovne baze, dobim samo opise fieldov ter prazne vrednos
Oddelek: Programiranje
72401 (2144) windigo
C++ problem: težava z hirerarhijo razreda
141522 (1362) fiction
[VB2005PRO]Database
91401 (1337) darkolord
[ C ] floating point not loaded !!?
112001 (1934) Fizikalko
[C++] for {}
292053 (1747) Gundolf
