Forum » Pomoč in nasveti » sapphire trixx problem
AapocalypseE ::
Še malo in bom dobil popizditis...
Danes sem dal dol zadnjo verzijo trixx programa, da bi videl, če so se kaj izboljšali, ampak vidim, da so se še poslabšali...
V idle mi nabija 3D voltažo 1.169V, čeprav bi morala bit 2D 0.850V
Resetnem vse v programu in je isto.
Ga odstranim, tudi isto.
Na novo sem dal gor driverje in reflashal bios, ampak problem ostaja...
Sem dal dol tudi Asus tweak in ne morem sploh spreminjat voltaže čeprav sem jo vedno lahko.
Še malo manjka in poleti kartica v steno in si grem po Nvidia kartico...
msi afterburner si stegn dol...
Pa pofleši si overclock v biosu, pa niti nerabiš več namenskega programa.
- spremenil: iloveboobz ()
AapocalypseE ::
Afterburner sem dal dol, ampak ne morem spreminjat voltaže.
Sem flashal OC bios, ampak voltaža ostaja enaka, tako da nimam pojma kaj naret več.
Overvoltanje morš vkjučit v konfig fajlu.
Drgač pa, kje spremlaš voltaže ?
AapocalypseE ::
Misliš tisto, ko vpišeš "I confirm that I am aware... ??
Voltažo spremljam v gpuz in kaže pravo stanje.
Asus tweak kaže kao 0.850V in afterburner tudi 0.850V, ampak vidim po stopinjah, da ni na 0.850V.
- spremenil: AapocalypseE ()
Da ti hladilnik oz. termalna pasta ne nagajata...
Lahk da je voltaža čist pravilna
to, ja
You need to alter the following:
Seek UnofficialOverclockingEULA field and add following text:
I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
Using the unofficial overclock method opens up more freedom in terms of voltages and clock ranges, it however also can open a can of worms in terms of stability or weird issues.
Unofficial means unsupported -- we grant some extra tweak options to fool around with, but in no way, manner or fashion is it supported by Guru3D.com or MSI.
So asking questions about it in the forums .. is a no-go. Regardless, have fun with this feature and be careful to not push the card over its limitations.
to, ja
AapocalypseE ::
trixx nagaja, ker kak sem tam spremenil clocke in dal apply, je voltaža 3D v idle.
Isti problem ma polno ljudi in pri nekaterih se čudežno kar sam reši, pri meni pa se še ni.
Normalno bi moral met 32 stopinj, mam pa od tistega trenutka 38.
briši vse programe za overclock dol, tudi pripadajoče driverje (če so kaki).
Resetiraj
Počakaj kakih 5minut, da se grafika ustali.
Potem čekiraj temparaturo.
Čeprav 6C ni neki no...
Resetiraj
AapocalypseE ::
Sem dal dol vse programe, na novo driver gor in reflash bios in ne pomaga.
Točno vem, da mi laufa na 3D voltaži v idle, ker mam previsoke stopinje.
Bom še probal enkrat z afterburnerjem.
Clocke pa normalno spusti na 300/150, samo voltažo pusti na 3D... čudn trixx res pa sploh ni več nameščen...
AapocalypseE ::
Po petih urah zabavanja in ugotavljanja kaj bi lahko blo, ugotovim, da nič od naštetega zgoraj ne pomaga in tudi resetiranje ne, ampak izklop in vklop računalnika in je normalno spet na 0.8V v idle...
trixx, nikoli več...
AapocalypseE ::
SW in AMD se rada kregata.
Se kaže tudi pri fpsjih v igrah.
Treba it pogledat malo v zeleni tabor.
Hvala hojnik za pomoč
| » | Navijanje 7850 dual-x oc (strani: 1 2 )Oddelek: Navijanje | 11295 (10455) | Blue3D |
| » | Radeon 6950 2GBOddelek: Navijanje | 1281 (1189) | AapocalypseE |
| » | HD 5770 memory downclockOddelek: Navijanje | 1532 (1410) | JC Denton |
| » | kontranavijanje intelovega core duo 2 E8400Oddelek: Navijanje | 1554 (1230) | psychoshorty |
| » | Ali je tale računalnik dober ali bi za takšen denar dobil kaj boljšega?Oddelek: Kaj kupiti | 1968 (1781) | IVo |
