Forum » Strojna oprema » AMD Radeon R9 400 Series
neo5468 ::
Uf, tole bo pa kr ja. Jaz imam i5 760, slabih 6 let. To je ta upgrade. Po 6 letih prvič neko stvar menjaš, pa si spet dober za 5 let.
hojnikb ::
Just gonna leave this here
Exactly! Being critical of AMD doesn't make you a "Nvidia shill". Some of us are just consumers who expected (and wanted) a better product. Honestly, /r/amd is becoming the computer hardware equivalent of Scientology. Any criticism (even if constructive or factual) is met by an abusive horde of brainwashed simpletons who are in denial.
#brezpodpisa
SimplyMiha ::
Exactly! Being critical of nVidia doesn't make you an "AMD shill". Some of us are just consumers who expected (and wanted) a better product. Honestly, /r/nvidia is becoming the computer hardware equivalent of Scientology. Any criticism (even if constructive or factual) is met by an abusive horde of brainwashed simpletons who are in denial.
FTFY
PredatorX ::
Tko pridemo hitr do tega, da je GTX 1060 superiorna napram RX 480 in da je GTX 1070 2x hitrejša od RX 480... ane?
PS: Vise versa
- spremenilo: PredatorX ()
D3m0r4l1z3d ::
šalo na stran ... zelo resna situacija pri AMD, lansko leto samo highend, letos samo ena grafa midrange, kje pa je full scale range, kot si zaslužimo
- spremenilo: D3m0r4l1z3d ()
D3m0r4l1z3d ::
Je bilo že neštetokrat obrazloženo.
Bilobil pomaga veš.
Pozabil si dati vejico pred besedo veš.
Ni p/p pri 320eur, halo :-), samo pri 199USD, lol
D3m0r4l1z3d ::
Če se greš iskanje vejic si na napačnem forumu.
Pred besedo si si pozabil vejico, Bilobil pomaga.
Zakaj d3m še vedno po teh temah o grafičnih bluzi kar vsepovprek? Kje so moderatorji?
AapocalypseE ::
Bilobil pomaga veš.
AapocalypseE je izjavil:
Best p/p ever
A ni?
Saj sem napisal, da je. Problem kje?
Itak pa bo PowerColor Red Devil rešla ta tako manjkajoči OC in boost, ki ga Asus Strix in Sapphire Nitro, kljub 1x8 pinu, ne dosežeta
Mogoče bi 2x8 pin pomagal. Bi bila takoj 480 = 1080
D3m0r4l1z3d ::
bojo bundlal kake špile zram teh graf ? Bi se spodobo kak DOOM zraven
To bi se pa res spodobilo, še kakšen popust za highend cpu novejše generacije, da ne bodo potem Vulkana prekleli.
Bilobil pomaga veš.
Best p/p ever
A ni?
Not sure. Tvoj evil smile je bil sumljiv.
Anymal umakni se pred soncem.
|HP EliteBook|R5 6650U|
D3m0r4l1z3d ::
Glej, k ga je emotikon zjebal pri presoji, ni siguren v best p/p, saj za amd je že po defaultu tako, sploh ni treba cene v eur upoštevat.
D3m0r4l1z3d ::
Ti pa dogaja danes.
Misliš resno ali se samo hecaš, tvoj emotikon mi daje mešane signale.
D3m0r4l1z3d ::
Bi rekel, da si že prej imel mešane signale Anymal.
V tej temi ne, 480 je dala čiste signale, da je krš.
pebi, bo treba dat klimo na mal nižjo temparaturo
Nimam več radeonke, ni potrebe.
AapocalypseE ::
Sem mislil, da bo počakal 470, ki bo pa ultimativni p/p ever
Bo pa moral seveda naredit selfie s svojo novo 480ko, da vsaj enkrat dokaže kar trdi
480 + timestamp bo dovolj, ne rabimo frisa.
Razen, če je poleg sestra od hojnika.
- spremenil: D3m ()
gtx970op ::
Bilobil pomaga veš.
Best p/p ever
A ni?
Jaz sem za enak denar naročil PALIT Geforce GTX 1060 Dual 6GB, ker se mi je zdelo da ima povprečno malenkost prednosti pred 480-ko
D3m0r4l1z3d ::
V Slo. ne.
AapocalypseE ::
Zakaj bi kdo kupil v slo?
Mi je pa zanimivo, da ima Mlacom najcenejšo 1060 v slo.
- spremenil: AapocalypseE ()
Gledam review asus rx480 strox na tpu. Sicer cena ni znana, predvidevajo da bo vsaj $20 visja kot referencna, ceprav bo verjetno prej 30$ (a niso eni klovni trdil, da bodo celo cenejse?).
Znogljivost je komaj kaj visja kot stock, overclock je pa joke.
Prov nevem, a se AMD res tako zelo trudi delat norca oz folka? Amd fani pa celi trdi in mokri...
AapocalypseE ::
Nitro 480 laufa na 1342MHz, da se jo spravit na cca. 1370MHz, kar ni praktično razlike v igrah, tako da je amd bil toliko prijazen, da je gpu za nas navil, tako da še ostane ram iz 2GHz na 2.25GHz in to je to
1.5GHz pa bo šla PowerColor Red Devil. Tisto pa je čisto drugačna kartica
Če mislijo res nabit cene na +290€, potem se znajo 1060tke podražit, ker so preprosto več vredne, 2gb rama gor ali dol. Tko da hitro (pred)naročite 1060tko. ;)
D3m0r4l1z3d ::
Devil je še zadnji up za oc dream
Navili so jo že v stock do amena, zdaj naj se pa aibji in kupci ukvarjajo, modificirajo in čakajo na driver update, da bo na nivoju 1060
PredatorX ::
Bilobil pomaga veš.
Best p/p ever
A ni?
Heh zanimiv je kako sem povzročip debato... nvidiots.
Jah lihk 320€ nebom dal za RX 480 raje dodam še 100€ pa kupim GTX 1070.
Za 270€.. max. Verjetno bo RX 470 velik boljši nakup, tako da...
D3m0r4l1z3d ::
Saj smo vedeli, tdi 470 ne boš, ker ne rabiš, 460 ti bo dovolj
PredatorX ::
RX 460 zna bit res na nivoju R7 370.
Zelo podobna primerjava med R9 390/RX 480 in R7 370/RX 460.
Ja točno to se vidi v tvojih komentarjih.
D3m0r4l1z3d je izjavil:
Ampak 460tka bo pila ~90W (uradno sicer 75W) preko pcie reže.
PredatorX ::
Dodatnega 1Gb rama bojda prinese ~4W porabe, Predator. In je nesmisel.. Med 6 in 8Gb ni nobene razlike na teh karticah. In je verjetno nikoli ne bo.
- spremenil: DarwiN ()
PredatorX ::
Napajalc ::
Rx 480 referenčna je win:
Glasnost load:
Rx 480 referenčna: 41.9db
gtx 970 winforce oc: 41.8db
gtx 980 referenčna: 43.6db
http://www.tomshardware.com/reviews/nvi...
http://www.tomshardware.com/reviews/amd...
The Radeon RX 480 does really well under load. During our gaming loop, it's no louder than Nvidia's reference GeForce GTX 1070. This is in spite of its higher power consumption, simpler cooling solution and more mainstream construction.
Finally, AMD gives us a reference card that doesn't sound like a hair dryer under heavy load. Well-done!
Očitno budget referenčni kuler na rx 480 opravlja delo bolje kot na premium kartici gtx 1080.
Glasnost load:
011011100111010101100010
klinker ::
2Gb rama.. pa okol 5-7w porabe + 258bit memory ti takoj prinese 10-15W
A da pol zmelje se Vego
- spremenilo: klinker ()
AapocalypseE ::
RX 480 reference je itak the best kar lahko kupiš.
Zanima me samo zakaj je že nima noben?
PredatorX ::
vice versa
D3m0r4l1z3d ::
Rade9ne je tudi letos za preskočit
