Prijavljanje napak
Prijavljanje napak
52 / 75
AvtoR ::
Meni pa kar naenkrat ne deluje več avtomatsko logiranje. Poskusil sem pobrisati cashe pa nič bolje. Prav nadležno je, ko moram vedno znova vpisovati username in password, pa še prav zoprn nickname sem sim izbral... Uporabljam pa Firefox.
bluefish ::
Imaš v nastavitvah uporabniškega računa vklopljeno avtomatsko prijavo?
AvtoR ::
Seveda imam vklopljeno. V Firefoksu mi ne dela v IE pa dela! Od kar so v FF stalno neke posodobitve imam z njim vedno več problemov...
_CaCkO_ ::
Ste opazili da vam e-mail ne dela (team@slo-tech.com)
This is the mail system at host posta.owca.info.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
posta.owca.info[extern/cyrus/lmtp] said: 550-Mailbox unknown. Either there
is no mailbox associated with this 550-name or you do not have
authorization to see it. 550 5.1.1 User unknown (in reply to RCPT TO
command)
Reporting-MTA: dns; posta.owca.info
X-Postfix-Queue-ID: 7C438160046B
X-Postfix-Sender: rfc822; miha.nastran1@gmail.com
Arrival-Date: Wed, 8 Aug 2012 18:11:58 +0200 (CEST)
Final-Recipient: rfc822; team@posta.owca.info
Original-Recipient: rfc822;team@slo-tech.com
Action: failed
Status: 5.1.1
Remote-MTA: dns; posta.owca.info
Diagnostic-Code: smtp; 550-Mailbox unknown. Either there is no mailbox
associated with this 550-name or you do not have authorization to see it.
jinzo ::
Če prav razumem pravila potem lahko račun "izbrišem" tako da odstranim vse podatke in e-mail.
Ampak trenutno ni mogoče odstraniti e-maila.
Pri (zadnjem v temi?) sporočilu ostaja link "popravi", tudi ko že preteče rok za popravila. Po kliku se potem tudi pojavi okno za editiranje, le pri kliku na gumb "shrani" se začne videti, da nekaj ni v redu, zgodi se namreč nič.
Bi lahko gumb odstranili ko več ni mogoče urejanje? Ali vsaj na klik napiše, da več ne gre editirat.
  • spremenil: MrStein ()
korenje3 ::
A še komu resetira omrežno povezavo, ko poskušaš citirat odgovor:
https://slo-tech.com/forum/t523365/p368...
Vsakič ko pritisnem pošlji, mi resetira NIC.
repetitor ::
Ne vem točno kdaj se je to zgodilo, vendar se mi sedaj vedno prikaže spodnji drsnik. Uporabljam pa Chrome 21.0.1180.79 m.
 Drsnik
Drsnik
Dropbox - http://db.tt/QsWCWPSg
axee ::
Meni tudi. To ima Chrome težave.
MasterKiD ::
repetitor je izjavil:
 Drsnik
Drsnik
Meni tudi. Veliko stran tako rekoč ne podpira Chroma. Pomojem je Chrome najbolj uporaben brskalnik. Res je Chrome kriv, samo mene to ne moti.
MrStein je izjavil:
Šumniki, (N+1)-tič:
Pri pisanju sporočila in dodajanju slike:
(upam da je kompozicija thumbnaila in linka uspela)
Firefox 14.0.1 na Windows 7 64 bit
Venum ::
Ali se še komu dogaja, da ko hoče v enem podforumu it na kako starejšo stran, da mu kaže sam po eno temo na stran ?
Primoz ::
Na cesti?
There can be no real freedom without the freedom to fail.
Venum ::
Ubistvu v vseh podforumih. Ko recimo klikam vedno starejše strani je še na parih straneh isto število tem pol pa vedno manj in pri kaki 10 strani + je še sam ena tema na stran.
To ni bug, ampak feature. Baje.
Sem že sam pisal o tem.
Nekaj v tem smislu, da vsaka stran prikazuje sporočila/teme iz nekega časovnega obdobja, in če jih je v tem obdobju le (recimo) tri, bo samo tri prikazal. Ostali pa so že na naslednji strani. Ali pa bo stran celo prazna.
Oldi ::
V parih dneh se mi je že dvakrat zgodilo, da ne morem poslati odgovora. Na klik Pošlji se na prvi pogled nič ne zgodi, ko pa hočem skopirati napisano, pa kopiranje ne dela.
Nato skušam odgovoriti v drugi temi in tam kopiranje napisanega deluje, če bo šlo naprej, bomo pa videli.
Uporabljam IE 8.076 32 bit
Očitno je šlo, ker tole berete, jaz pa popravljam :).
Sila nerodna reč, pišeš nek zahteven odgovor nekomu in gre pol ure v maloro.
  • spremenil: Oldi ()
Oldi je izjavil:
Lazarus plugin, za večino browserjev... ;)
sloxl8 ::
Ko v forumu "Teme zadnjih 24 ur" odpiram teme v novih zavihkih, jih brskalnik nekaj odpre (manj kot 10), nato pa zmrzne. Pri nekaterih zavihkih utripa oranžna (potrditev odpiranja ne-varne strani), pri kakšnem pa je prikazan "Blank Page". Če poskusim ta "Blank Page" zapreti, zmrzne.
IE 8.0.6001 v Win XP 64-bit
Oldi ::
V poplavi tem me rešuje link "Moje teme", ki pa dela slabo, vse pokaže šele klik na vse moje teme. Glavni problem pa je, da sta ta 2 gumba prisotna le v nekaterih brskalnikih ali rersolucijah ekrana, nisem raziskoval, vsekakor ju pa ni v Opera Mobyle in defolt brovserju v SG S3. In predno na telefončku najdeš svojo temo te že mine.
Rias Gremory ::
Manjša napaka.
 Napaka- šumniki
Napaka- šumniki
Še za info če pomaga:
Mozilla Firefox 15
OS: Windows 7 Ultimate 64-bitni
illion ::
postanje tega linka:
http://stackoverflow.com/questions/2174875/android-canvas-to-jpg
povzroči tole (najbrž je problem besede jpg na koncu?):
http://stackoverflow.com/questions/2174...
  • spremenil: Primoz ()
Primoz ::
@illion: Hvala
Hmm, ste kaj spremenili glede "Moje teme"?
Očitno so.
kriko1 ::
Pozdravljam to spremembo, super :)
para! ::
A je kej s šumniki narobe? V vseh temah mam tkole, recimo:
Death before dishonor!
  • spremenil: para! ()
Da. Meni kaže isto. Chrome 21.0.1180.89
nofaith ::
meni tudi na chromu
V prostem in neprostem času tehnološki entuziast.
CaqKa ::
para! je izjavil:
kako pa bi naj blo?
Je že popravljeno.
Oldi ::
Vse moje teme so sedaj tudi v OperiMobile, ni mi pa jasno v čem je razlika med moje teme in (vse), itak je pa to kar iščem skoraj vedno pod vse, torej je kriterij zame napačen, zato predlagam, da se uporablja samo en link: "Vse moje teme".
Zakaj?, na mobilcu moraš zaslon najprej hudo povečati, ponavadi ti zagrabi sredino (z vsebino teme) in moraš nato pomanjšati, da greš lahko iz sredine na levo, potem tam spet povečati, da ti prst lahko zadane (vse).
Za mobilce bi bilo res super, da so linki kot moje teme, sveže teme, oglasi.. na vrhu srednjega stolpca pod dovolj velikimi gumbki, da se jih da klikati s prstom. Glede mojih tem je rešitev, da jih daš v bukmark in vedno padeš nanje. Je pa za mobilce super, da klik na temo pripelje na zadnjo stran in ne kot na phBB, kjer te vrže na prvo.
Bor H ::
Moje teme ti pokaže "tvoje teme" ki imajo neprebrana sporočila, (vse) ti pa prikaže tudi tiste ki si jih že pogledal.
Hmm, zdaj mi v Moje teme kaže eno (in le eno) temo, katero pa sem že prebral.
Tudi prikazana je že tako, ne-bold, kot so sicer prebrane teme.
Včeraj sem imel prazno, če sem vse moje teme imel prebrane.
Bug?
Prikazana tema je tale: https://slo-tech.com/novice/t533571
Posebni izpisi / Ključna beseda
To ne išče/najde pod opisi slik.
Primer: Hitrost vašega trdega diska, SSD-ja, ...
Vtipkam Samsung, kliknem Prikaži in mi ne najde tega posta: https://slo-tech.com/forum/t82704/p3521...
Hmm, tista slika v sporočilu je nekam meglena. kuglvinkl, si v JPEG spremenil?
MisterR ::
To ni OK
 st fail
st fail
Enron x86 ::
Meni ob pisanju odgovora (hitri odgovor) včasih zgine zgornja orodna vrstica. Nadvse nadležno. Uporabljam Chrome 21.0.1180.89. Ostane samo okvirček za pisanje besedila; mislim, da izgine tudi napis "hitri odgovor".
Core i5-4690K@4.7| ASUS MAXIMUS VII HERO| 16 GB Corsair LP DDR3 1866 MHz|
ASUS 970 STRIX| SB Z OEM| Samsung 840 EVO 250 GB|
Seagate 2 TB| EVGA SuperNOVA G2 750 W| Fractal Define R4
yayo ::
Bolj me zanima informacija kot kaj drugega: Po novem obiskujem slo-tech preko tablice. Tako v Firefoxu kot v Chromu za Android se mi ne prikaže desni rob spletne strani, kjer so vsa tista okenca (Išči, Moj profil, Hitre funkcije, Posebni izpisi). Isto je, če brskalnik nastavim, da prikaže "polno" stran in ne verzijo za tablice/telefone. Do zasebnih sporoćil ali mojih tem npr. prek tablice sploh ne morem (ne znam) priti, ker pač nikjer ni videti krajšnice. Le kaj mi je storiti?
Primoz ::
slotech -> forum -> ZS
Matko ::
slo-tech.com/wap ne dela več :(
CaqKa ::
m.st. tud ni delal.. nevem al sem to včeraj gledal al danes..
BladE_ ::
Mogoče se mi samo zdi ampak mislim, da nekaj ni ok s šumniki, včeraj je bilo vse ok...
 Recimo...
Recimo...
Iz iste teme 2. post:
Pa ni blo dosti placa za vse, pa ščije John skup z enim črncem. pa ga vpraša črnec...
tud piše WY na kurcu pa ga praša "do you
Mogoče je težava samo pri črki "Š"?
Akcija - Reakcija
gemini ::
Vaše vsebine na igoogle se ne posodabljajo že en čas. Meni še vedno prikazuje
Applova zamujena priložnost z Lighting konektorjem
Astronomska enota dobila novo definicijo
Google v arabskih državah samovoljno umaknil sporni videoposnetek z YouTuba
Vse ostale strani se lepo redno posodabljajo, samo vaša ne.
MisterR ::
Sem hotel v iPhone 5 odpret youtube video v novem tabu (s klikom na naslov videa) ampak v operi to ni mogoče. Bug or feature?
Velikokrat se mi zgodi (vendar ne vedno), da mi specifično stran teme (Vlada 2012) noče do konca odpreti (ne naloži komentarjev); in to vedno samo ta tema, ostale strani se naložijo do konca. Je narobe kaj pri meni?
(FF 16.0.1, na Win7)
Janac ::
iskanje fail?
Tole mi ne naloži: Kateri prenosnik?
Elementi (menuji in podobno) naokrog so, sporočil pa ni, niti ene.
k4vz0024 ::
Zadnji čas ne dobivam oobvestil o odgovorih. Je o kakšna nova politika ST?
Bom dočakal odgovor? Ura je več kot poldne:D
  • spremenil: k4vz0024 ()
zakaj ko odprem npr nakladalnico mi je kdaj sploh ne odpre?nalaga zelo dolgo in sploh ne odpre
mi že tole počasi najeda
  • spremenil: mtosev ()
a bo kakšen odgovori na postavljeno vprašanje al ne?
bluefish ::
Ja, znan problem. Se odpravlja. Bo rešeno, ko bo.
52 / 75
