Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
dolenc ::
Je cel kup kanalov, ne-tech, ki samo jokajo čez vse, očitno je to žanr!MSM že kako stoletje ve, da se najbolje prodajajo slabe novice. YT očitno to odkriva šele sedaj... Kar grozno, ampak tako smo narejeni.
Je žalostno/čudno, al po drug stran, maš pa vsega boga... Prej sem gledal kako pcb konzole Wii porezat, da pobereš samo procesno enoto vn in lahko potem iz tega sestaviš prenosno, v velikosti gameBoya, konzolco.
Koga predlagaš namesto GN ?
Za tovrstne zadeve vsekakor Igor's Lab. Ne dela drame. Der8auer je tudi že iz starih časov Intel fan in ima tam tudi poznanstva.
mahone ::
Igor's Lab ga tut fiksa vcasih - tista njegova o kablih pri Nvidiji je bila cist mimo. In potem so vsi spammali njegove ugotovitve, ki so bile napacne.
Je pa res, da je to blamaza na ravni nVidjinega fiaska s cvrtimi kabli. Z eno pomembno razliko, AMD ne probla napake naprti na plece koncnim uporabnikom.
Igor:
Those who are now beating up on the new 12VHPWR (although I don't really like the part either) may generate nice traffic with it, but they simply haven't recognized the actual problem with the supposedly fire-hazardous and melting connections or cables. Even if certain YouTube celebrities are of a different opinion because they seem to have found a willing object of hate in the 12VHPWR once again: This connection is actually quite safe, even if there are understandable concerns regarding the handling.
However, the "safe" is only valid if e.g. the used supply lines from the power supply with "native" 12VHPWR connector have a good quality and 16AWG lines or at least the used 12VHPWR to 4x 6+2 pin adapter also offers what it promises. Which brings us directly to the real cause of the cases that occurred: It's the adapter solution exclusively provided by NVIDIA to all board partners, which has fire-dangerous flaws in its inner construction!
- spremenil: Jarno ()
mahone ::
A to sam pocne
https://www.reddit.com/r/nvidia/comment...
Jaz ga ze od drkanja DerBauerja zaradi punce, ki je porno zvezda ne jemljem vec resno.
Seveda, ko se zbere 50+ "mehov7" s svojimi prepričanji, potem nastajajo takšni threadi.
Resnica pa je seveda v tem, da npr. RTX 3090 se ni samovžigala, razen v določenih igrah, krivi pa seveda uporabniki, valda.
GN Steve je npr. spraševal Wendla glede single vs. dual rank DDR4 in kva je to za en "performans issue", sam ni imel pojma...
To so takšni trenutki, ki demitizirajo osebnost...
Če koga zaradi smisla za humor ne jemlješ resno, potem pač nisi pretirano sofisticiran, ane?
Igor:
Pravi, da je kriva nVidija oz. kaj si sploh hotel povedati?
Vbistvvu pa imas bolj podobno primerjavo z nVidijini GPUji, ki so med igranjem dolocenih iger crknile. GPU killing games. Eni fanbojcki pa trobijo, k da bi zgolj AMD imel tezave.
Kaj mores, fanbojcki velikokrat izvedejo Darwina. Zato pa imamo Darwinove nagrade.
Igor:
Ni letelo nate. Samo si že podal konkreten odgovor na to temo, da je design flaw ob ponavljajočih se primerih najbolj korekten odgovor.
Mozno, videl sem novico, kjer so omenili napake v BIOS maticnih plosc vecih proizvajalcev.
Senior Dev ::
Že popravljajo. Vmes bo eksplodiralo nekajsto AMD procesorjev po svetu in folk bo MAD.
mahone ::
Poslusaj od 27. minute naprej. Kdo je povzrocil vsesplosno paniko? Igor's Lab. Potem so pa vsi njegove ugotovitve spammali - od raznih techtuberju -Jayz2cents do pc spletnih strani - videocardz,...
Kaj smo izvedeli ? nič vemo samo da je ASUS šrot in da so napetosti previsoke zelo če primerjamo z AM4 pa je na slabši litografiji. Razumljivo bi bilo, da je napetost manjša, ker je proces manjši, torej so razdalje manjše.
Edino kar sem iz videa zaznal, da bi moral AMD enega partnerja iz čistega strahu brcniti, ker quality control in da imaš voltaže 1.4V itd? morda bi raje investirali v development in ne 24 faz na plošči, ki jih rabi samo 10.
Dlje ko boste plačevali influencerjem za čustveno stanje,
slabše bo za ukjince in posledično tudi Evropo.
Vseeno je včasih potrebno pogledati stanje na terena.
Kakšen je razlog, da Mindfactory nima Asus plošč v asortimanu ?
- spremenilo: sbawe64 ()
Senior Dev ::
Slaba kakovost. Kake Strix karte so bile še dobre, ampak je pa cena nehumana.
Ne vem, je to amd ali oem problem biosa ?
Vuli ::
a ni Amd overclocking del AGESE?
Verjetno bi tako sporadicno spreminjanje napetost nekdo v nadzoru kvalitete opazil? Ce ne, bi rekel amaterizem od amd-ja.
Testiranja so po večini avtomatična, dinamiko voltaž pa uravnava "smart" sistem.
Če imaš kombinacije privzetih (auto) vrednosti in ročnih popravkov pri bios-ih proizvajalcev se lahko pripeti splet okoliščin, kot se je pri R7 7800X3D.
Hakeljc bi bil, da ne bi mogli "kar tako" popraviti, kot division by 0 napake v pentiumih.
Ja samo iz videa jaz zaključujem,
daje nekaj konkretno narobe..
Ker nastavitve niso bile "Auto" oziroma je bila številka.
In da ko skoči napetost na 1.4V "Avto" , pa je nisi nastavil na 1.4V ni čudno da procesor odleti.
Gigabyte issue
povzetek
rami voltaža na 1.6V (4800 Mhz, no expo/xmp)
plata da voltažo Soc na 1.4V ne glede na to , kaj tip vpiše notri.
fail:
Vsoc voltaža se nastavlja na dveh mestih, v "amd overclocking" ter v "advanced mode", prikaz na 21:21
popravek:
fail
Vsoc voltaža se nastavlja na dveh mestih, v "advanced mode -> tweaker" ter v "amd overclocking" , prikaz na 21:21 VCORE SOC, 13:35 SoC Voltage.
Ter ob cold b0otu spet druga vrednost (1.357V) kot ob rebootu (1.20V), a nastavljeno na 1.20V, 23 minuta.
fail
https://www.youtube.com/watch?v=O2n4rOWehtQ&lc=UgzSZWhgYkLgR-iu3S54AaABAg
The SOC voltage being overridden by the AMD Overclocking tab on Gigabyte boards is really infuriating. I can confirm this also happens on the Gigabyte B650E Aorus Master, and B650M Aorus Elite.
When I installed my 7800X3D and set the memory 6000 MT/s I immediately reduced my SOC voltage to 1.25v because I knew the default of 1.35v was unnecessarily high. The voltage initially applied, but unfortunately due to this bug my SOC voltage kept getting reset back to 1.35v on reboot, and I didn't realize it since I had no reason to check. Then later it turns out that high SOC voltage was not just excessive but potentially dangerous, and my voltage was stuck running at 1.35v for a couple of weeks even though I never wanted it that high!
Prva izjava:
https://www.anandtech.com/show/18828/am...
Druga izjava:
https://www.anandtech.com/show/18835/am...
Druga izjava:
Senior Dev ::
AMD Q1 earnings: Beats on revenue and EPS, but chip sales drop 64%
Katastrofa. Nihče ne kupuje AMD. Ma gotovo je in še eksplozije niti niso vkalkulirane.
Intel je podobno
https://slo-tech.com/novice/t815267#crta
Senior Dev ::
Ko ti pade prodaja za 70% veš da si proti koncu. Lisa bi morala ponuditi odstop ali pa bo podjetje kmalu v stečaju.
Ja, seveda. AMD bo propado, yeah sure.
Intel je podobno
AMD Revenue -9%
Intel Revenue -36%
Intel ima 4x izgubo prihodka napram AMD-ju
AMD gross margin 50%
Intel gross margi 38.4%
AMD shipment drop 30%
Intel shipment drop 36%
Edino kar nisem našel koliko je dejsko padec prodaj graičnih in kolikmPS5/XboxX
AMD’s gaming segment je padel za 120 milonov $.
In pri 50% marži , zasluži AMD pri prodaji grafičnih kot kaže ogromno...ni ravno Rdeči križ kot bi rad rekel Darwin...
NV ima pa objavo rezultatov čez tri teden...
Darwinovi mozgani so ze zdavnaj zadeli darwinovo nagrado:).
Naslednji podatek je tudi zanimiv. Gaming segment konkretno prekasa data center segment, tako po obsegu, kot dobickonosnosti.
- spremenilo: tikitoki ()
Nice CPU.
Senior Dev ::
Nice CPU. Škoda, da je AMD mrtev in je prodaja dol 70%. Vprašanje ali jih lahko sploh še kaj reši iz nastale godlje in ali spremljamo zadnje leto za AMD.
Pa ne že spet ena slotekovska napoved konca podjetja...
Buggy ::
Se je kdo vprasal kaj je danes pravzaprav CPU intensive task in ga generacija pred tem ne opravlja tako zadovoljivo, da je smiselno zradi CPU power nadgradit mainfraime in s tem prevzeti odgovornost za vso nekomatibilnost z virtualizacijskimi orodji, ker predvidevam da se taki sistemi koristijo ravno pri tem?
Vsak nadobudnez doma v peskovniku, ki se igra itaq s tem nima nobenih prakticnih gainov, pa si lahko laze kot ce vec casa pokuri, da zadeve spet ustrezno optimizira v production Q, gain pa je zanemarljiv. Eni se tega ne naredijo pa imajo celo slabse ali se performance gaine kot pred staro platformo...optimizacija sistema jim pac ne lezi ker so lamerji.
Strosek na projektu imet enega lejmerja, ki bo optimiziral ali pa drzat solid gold production brez prvih novitet...no brainer
- spremenil: Buggy ()
Enterprise nadgrajuje zato, ker se podpora izteče oz. postane dražja od novega hardvera. Pridobi pa se manjša poraba štroma, performance šele na drugem mestu.
Buggy ::
Z novimi procesorji je bil z VMWare vedno tezava! Jaz si tega ne upam privoscit za nek mid range test depo.
Sicer smo pa kot vsi ze po vecini na non-critical sitemih v cloudu, ce politika firme seveda to dopusca
Buggy ::
GPU stack in ostalo na high level je tvoja domena, govorim na splosno za firme, ki bi potencialno sle v upgrade BZ. Sam sem zgolj v teamu z 20 ljudmi in na VMvare fural testna in DEV okolja z vsemi apache iteracijami na ustrezni redundanci diskovnih polj, ki je tudi najbolj optimalen gain. Zdej smo bili prisiljeni migrirati tudi mi na Azure a vseeno...vedno ko je prisela nova generacija CPU-jev za nek middle usagae v startu to ni bila dobra resitev, kaj sele za kaksno resno stvar. CPU power ni bil nikoli issue...vedno storage...pa naj bo to build proces ali baza.
CPU pri compile je pizdin dim glede na artifacte in deploye, ki jih prek git-a mora buildat skripta. CPU utilizacija je se najmanjsi problem pri tem mojem delu.
Imam en problem z enim AMD sistemom. Dobim error page fault in nonpaged area pri namestitvi Win 10. Kakšen error je to? Tole je ECS barebone PC. Ryzen 3 2200G, 8gb rama, M2 sata. Prosim za pomoč.
- spremenil: mtosev ()
So.
Senior Dev ::
Vsak dan nove težave z novo AMD platformo. Sem imel čisto prav da še ni zrela za resne uporabnike. Veliko veselja vsem beta testerjem in tudi zahvala za požrtvovalno delo.
https://www.techpowerup.com/308330/late...
Da.
Sam pa našo krivca očitno. Sem dal memtest86+ in je bilo polno errorjev.
