AMD ZEN - nova X86 Jedra
Se prav je 9900k spet vodilni. :D
|HP EliteBook|R5 6650U|
A govorimo tem : https://www.notebookcheck.net/AMD-oblit...
The Intel Core i9-9900KS tops the list with a result of 3,039, while the :Dhighest :DAMD chip is down in 8-O35th position with the Ryzen 8-)38-) 4300U on 2,673
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
KAVINSKY ::
Verjetno so pri Intlu zaposlili Kim Jong Un-a za PR :))
Ja sedaj je tistih famoznix AVX-512 primarni odločilni fakotor.
Ali pa sledeče.
"Financial Horsepower"
Kakor koli matematika očitno ne deluje več pri PassMarku ali pa morajo še enkrat pregledati kodo testiranja. :)
En primer:
9900KS vs 3800X
https://www.cpubenchmark.net/compare/In...
Update:
Napaka v kodi
https://www.passmark.com/forum/pc-hardw...
Novi rezultati bodo sledili. :)
Kaj je dobrega pri tem: Treer je imel 3 dni trdega.
Pametnemu človeku pa ti testi ne pomenijo nič. Štejejo le testi na programih/igrah. Kje se pa ni spremenilo popolnoma nič :)
Horas ::
  • spremenil: Horas ()
Horas je izjavil:
Tu dalje sem nehal gledat test :
Sicer sem najprej mislil da bo 17.Marca objavljen test kaj resnega... morda enaka cena paketa... na koncu morda samo grafična...
Potem se se zavedal resnosti testa
Adata XPG SX8200 Pro NVMe PCIe M.2 1TB - 353.5% vs Samsung 970 Evo Plus NVMe PCIe M.2 500GB - 307.3%
Kakšen poseben razlog za tak jabka - hruške test?
D3m je izjavil:
Update:
Napaka v kodi
There was a 15% drop in the compression benchmark between Win10 Build 10240 & Win10 Build 18362 (we don't know exactly which patch caused the problem, but speculation is that it was one of the many security fixes). So it seems clear that patches on Windows significantly slowed down the test
Nemogoče, Inteli so počasni zaradi lukenj, AMD nikoli! - vprašaj kateregakoli AMD fanboya
mirzad ::
D3m je izjavil:
https://www.reddit.com/r/Amd/comments/f...
if IS_INTEL score *= 1.1;
MrStein je izjavil:
D3m je izjavil:
Update:
Napaka v kodi
Vemo kako je to.
Če je patch samo za Intel, MS naredi, da je security fix CPUID za vse ni važno ali posledično zaradi tega konkurenca trati cikle. >:D
MrStein je izjavil:
D3m je izjavil:
Update:
Napaka v kodi
Ni dobolj informacij.
Si pomislil, da flikanje lukenj za intove procesorje univerzalno upočasni vse?
To, da je krpanje lukenj (ki so na strojnem nivoju) prepuščeno operacijskemu sistemu je svojevrstna šlamparija že v štartu.
Popravljeno: so me že prehiteli. Pod črto: ni dovolj informacij za take trditve (govorimo za specifični primer).
  • spremenilo: FireSnake ()
FireSnake je izjavil:
Kaj da ne, sedaj so najbolj pomembni testi pri 480p.
Da, bottleneck kričijo eni.
Škoda, da ne vedo o čem govorijo :))
https://www.extremetech.com/computing/3...
To je mobilni procesor!
Ne pa 100+ Wattna jajca.
FlyingBee ::
Glede testiranja v igrah res nisi pravi naslov.
Wrop ::
Res ni. Saj zmogljivost procesorjev se pa res ne testira z igrami.
FlyingBee je izjavil:
seveda, zato testiramo z deset let staro igro pod 720p in potem potegnemo zakljucek z visoko vrjetnostjo, da je / bo pri 4k resoluciji doticni cpu bottelnek, ker je 3FPS pocasnejsi. Zato tudi se stegnemo po 300€ drazjem cpu-ju, ker nam zmanjka za jurja graficno.
FlyingBee ::
Z razlogom se gpu bottleneck odstrani, tako se dela že dolgo časa in nekaj nejevernežev na forumu ne bo tega razveljavilo. Se pa strinjam, da si moraš pravilno interpretirati rezultate, drugače je le nepotreben nesporazum.
Sej zato pravim za 3 FPS razlik v 4K das 300€ vec, ker je ce je v 720p 10% pocasnejsi bo to zagotovo vidno v toaletnem papirju.
Pridejo tudi novi Sirface-ji:
https://www.tomshardware.com/news/amd-m...
FlyingBee ::
Mr.B, ja, vsak sam presodi kaj se mu splača, ali si ti spokesman za vse ostale? Tudi dejstvo, da za zadnjih 5% perf več preplačaš nesorazmerno veliko, spada med ancient rules nakupa komponent. Boš kaj novega napisal?
A ni 20% vec performan.
FlyingBee ::
Pisal sem na splošno. Ti podnapisi ne delajo?
  • predlagalo izbris: tikitoki ()
klinker ::
Mr.B je izjavil:
Ti pac ne razumes da je to samo test, ne pa napotek za nakup. Pa tudi ocitno ne mores sprejet dejstva da Intel se vedno nekje vodi, kljub temu da je zluknjana pecica, je to pac resnica in bi blo lepo da jo ze 1x sprejmes.
Vsem je jasno keri je trenutno overall best buy proc, vseeno Intel se miga in nekje je pac celo boljsi. Who cares.
Točno tako. Tudi Bulldozerja so prodajali za orenk nizke cene, kar pa ne moremo reči za slednjega.
klinker je izjavil:
Mr.B je izjavil:
Vsakemu zahodnjaku, ki se zaveda kaj je blue pill virtualizacija, ne bo kupil intla. Je pa res da od zahodnjakov, ki se ne morejo ločiti od goolge iskalnika, FB, instagram, OS in se podobnih platform, resnično ni za pričakovati da 3FPS razlike ne pomeni nič.
Cange ::
CPU fundamentalno določa FPS igri, grafične nastavitve pomagajo v veliki večini izbolšat FPS samo GPU-ju. Podhranjen GPU se da z ingame nastavitvami še vedno pognat na konkurenčne FPS. Iz tega se izhaja da so CPU-ji tisti ki delajo PC pay to win.
Trenutno možnosti: AMD dovolj jeder in proper poraba z malo manj FPS, intel pečica z premalo jeder in rahlo več FPS. Premalo jeder je slabše kot malo manj FPS na dolgi rok, torej AMD zmaga. Pay to win je nastalo pa tako: AMD pol desetletja ni imel novega čipa, sedaj pa intel enostavno noče konkurirat = I7 9700k ki je ubistvu I5 se prodaja za ~400$, in to se ne bo spremenilo ker nova I5 bo 6/12 šele konec leta, torej I3 je po novem I5, I3 pa vsi vemo da je bottelneck v gamingu.
FlyingBee ::
Ker jim client desktop sektor pač toliko pomeni trenutno, mi pa samo to spremljamo, podjetji pa sta na mnogih sektorjih še prisotni in Intel v tem prednjači, zato si lahko privoščijo take cene, ker itak bodo enkrat nekaj boljšega od Zen izdali na novem procesu in karte se bodo obrnile.
mirzad ::
Cange je izjavil:
i9 bi mogu bit 16c/32t, i7 12c/24t, i5 8c/16t, i3 6c/12t
Ni realne potrebe po tem. Intelov popatchan 6c/12t cpu je lahko gamerska klasika, 8c/16t pa že investicija v prihodnost.
Pečke bodo še vedno, morda z manj luknjami in malce hitrejše brez sw patchev, dokler ne bo novih ranljivosti seveda.
Po drugi strani pa bo AMD navdušil z zenom 3, tudi s cenami najverjetneje.
Ni nobena skrivnost, da bo za solidno igranje potreben predvsem beefy gpu.
RDNA 2.0 v PS5 naj bi šibala do 2.2GHz.
mirzad ::
seveda ne bo, ampak mogel bi pa bit
Jarno je izjavil:
3 nove v zadnjem tednu. :|
Microsoft surface:
https://www.techradar.com/news/amd-ryze...
Govorijo, da prihaja v kratkem.
Kakšna bo kaj cena?
neo5468 ::
Surfacei niso bli nikol pocen.
Ryzen tudi v obgriženi jabolki:
https://www.notebookcheck.net/AMD-Ryzen...
modelno1 ::
Še enkrat preberi. Primerjajo R7 iz Asusa in i9 iz MacBooka.
Respect the bacteria! They are the only culture some people have.
FlyingBee ::
Revež je tak AMD fanboy, da je disleksijo dobil.
modelno1 je izjavil:
Ups, preveč hitro sem bral.
@leteča čebela: raje bi imel disleksijo, kot pa, da bi bil (dokazano) neumen, kot si ti.
Res sem imel srečo, da se narava za mano ni tako kruto poigrala, kot se je s tabo. Pa saj nisi sam kriv.
Neumneži radi opletate z besedo "fanboy". Pa spada v kontekst, ali ne. To ni važno. Važno je, da se fancy sliši, ane? ;((
WarpedGone ::
Vsi smo neumni - neumnost je le doseg našega racionalnega dojemanja.
Vsi smo omejeni, le da nismo vsi enako omejeni. Polovica nadpovprečnih in polovica podpovprečnih. Ko si enkrat na svojem limitu si zadeve naprej ne znaš razložit več in se nujno zatekaš v 'feel good' floskule. Fanboj, venrnik, bedak, ...
Drugega nam ne preostane.
Kako ugotovit čigav doseg seže dlje?
Kakšna ideja?
Zbogom in hvala za vse ribe
WarpedGone ::
P.S. I was wrong again... posledica gre v ponedeljek v krematorij...
FlyingBee ::
Mogoče ti pa le angleščina ne gre tako dobro, kar bi razložilo kakšne bedarije večkrat napišeš oziroma povzameš iz tujih medijev.
Fanboy pa je zelo dober opis za nekoga, ki le na eno firmo pali, tukaj ni zarote zadaj, le zaslepljen um, ki vidi eno. Lahko bi ga tudi kot neumnega opisal, ja.
hojnikb ::
WarpedGone je izjavil:
Kakšna ideja?
malo kiksnal tesla temo?
#brezpodpisa
WarpedGone ::
Umakni plašnice in preberi napisano.
FlyingBee ::
Vse bi bilo ok, če bi OP prav prebral, ne pa da takoj odpne šlic in napiše na ST.
klinker ::
Se kr z Beejem tu strinjam. Malo je tezko tako fejlat tako ociten clanek.
462 / 611
