Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
A day after...
First and foremost, a word of warning. When reading ANY of the AMD Ryzen 3000-series "Matisse" launch-day reviews, the first thing you should do is navigate to the page which lists the hardware setups.
AMD supplied four different motherboards to the media, one from ASRock, ASUS, GIGABYTE and MSI. In case of the ASUS Crosshair VIII Hero Wi-Fi motherboard, the media was instructed to use 0066 bios build,
which had been vetted and approved by AMD. However, newer bios builds were available and ASUS has also (allegedly) told the media to use those versions. What exactly has transpired here is still under investigation,
but regardless of the actual reasons behind it, the consequences might be rather significant. In practical terms, all reviews which were done on ASUS Crosshair VIII Formula or Hero motherboards using other than 0066 bios build must
be considered invalid, at least partially. Reviews using other ASUS motherboard models (not provided by AMD) are under suspicion as well.
Bwaze6 ::
Eh, "invalid", verjetno gre za majhne razlike. AMD in izdelovalci matičnih so si datum predstavitve izbrali že pred meseci, če so dan ali dva prej dokončevalii bios, so si sami krivi, da recenzenti niso vrgli vsega stran in šli testirati na novo...
Je že kdo primerjal AMDjeve prosojnice iz Computexa in E3 z včerajšnjimi recenzijami? Se mi, di, da je bil na svoji reklami AMD precej bližje 9900K, marsikje tudi nad - tega zdaj praktično ni videti. Pa niso izbirali nekih obskurnih špilov, ki bi slučajno dobro tekli na AMDju.
Tudi PCIe 4 SSDjev niso ravno kazali kot prodajno točko, čeprav so pri recenzentih. Vsaj en od njih je omenil, da se mislim da ASUSov blazno greje, kljub velikemu hladilniku, in se močno greje cela matična. Prednost imajo pa zgleda samo v sequential prenosu, 4K je že za npr. 970 EVO.
FlyingBee ::
Dej ga poklič in vprašaj kako mu je uspelo 3900x brickat.
3900X, prvi dan prodanih 460:
https://www.mindfactory.de/product_info...
3800X, prvi dan prodanih 120:
3700X, prvi dan prodanih 540:
3600X, prvi dan prodanih 140:
3600, prvi dan prodanih 280:
Govorimo o eni trgovini.
Glede prodaje se ne gre bati.
Ravno danes sem razmisljal, koliko sem placeval za cpu+mobo. Vedno je bilo oboje solidno (plate po 150-180), plus dober consumer cpu. Vedno me je prislo ~400e, amd ali intel.
Zdej bi me en tak soliden komplet prisel 550-600e, brez da bi se preseraval. Amd poceni my ass.
- predlagalo izbris: camx ()
Wrop ::
V juniju so na Mindfactory pokupili cca 9000 kosov AMD CPU+APU. Če bo šlo tako naprej, bo že do 10. pokupili toliko CPU, kot jih je Intel v celem juniju (4000 kosov).
Kot vidim, je 8 in 12 jedrnikov že zmanjkalo.
To pa nisem opazil.
Torej bi jih šlo še več, če bi bili na zalogi
No, četudi bi želel kupiti že zdaj ne bi šlo, ker je vsepovsod razprodano.
Mindfactory jih dobi jutri.
- spremenilo: FireSnake ()
Bwaze6 ::
PSA: Ryzen 3000 Gaming Performance is being gimped by MB bios issues. Explains inability to reach advertised boosts.
Razlaga, zakaj nekateri niso dosegali niti stock boost frekvenc. Bodo morda prišle tudi PBO overclock +200 MHz frekvence?
Tile procesorji so polni presenečenj.
Če to kupiš, ti res ne more biti dolgčas
Hočejo povedati, da bi se naj zadeva, v igrah, obnesla še bolje?
Edit (Anandtech):
Ko so vprašali Ryna, če so za intel vključeni popravki, je rekel:
Ryan Smith - Sunday, July 07, 2019
Pa ravno njim sem najbolj verjel. in to ni, v recenziji, nikjer omenjeno.
Edit (Anandtech):
They are with Spectre and Meltdown mitigations. They are not new enough results to include anything for Fallout/ZombieLoad.
Buggy ::
A ima kaksen nas trgovec kaksno 3700X na zalogi ali pa vsaj v prihodu ta teden...so sploh kej dobili v SLO? Funtech ima sicer opcijo na obvescanju za 387€, kar je ok cena..ostali pa se nic. Mlacom je ponavadi tudi imel prvi te novosti zdaj pa nic.
Drugac pa kot je ze Bwaze6 linkal. Tudi sam sem opazil da teli testi sploh niso bili z max uradnim boostom. Zgleda so se neke BIOS restrikcije in se znajo teli rezultati se malce spremeniti, ce/ko bodo proci dobili dodatnih 100Mhz+ boosta.
Semafor ::
kuglvinkl ::
Kupi Crosshair VI Hero (X370) - za podoben denar ne boš našel boljšega za Zen2 trenutno, v kolikor ne potrebuješ PCIe gen4 (kar trenutno verjetno nihče). Sam imam Crosshair VII Hero in 2700X, čakam 3700X in 3800X.
C6H (tudi z WiFi) dobiš novo za okoli 150-160EUR v tujini, če se potrudiš.
Bejž od teh poceni MSI B450 plat, ker te bo samo glava bolela. Iz lastnih izkušenj.
Se eno verzijo nazaj? Zanimiv predlog. S pocen platami se mi ne da ukvarjat. Kisto bom sestavil in ma da dela leta in leta.
- spremenil: kuglvinkl ()
Bwaze6 ::
A je to razlog, da 3800X niso testirali, in jih ni naprodaj? Če boosti ne delajo pravilno, ni bilo verjetno dovolj razlike med 3700X in 3800X...
Včeraj se je torej začelo širše beta testiranje matičnih.
Za zen2 bomo zvedl sele cez ene pol leta, ce je res tako dober, kot trdijo. Pri prvemu je bilo tocno tako.
za kaksen quadcore apu je tut poceni msi dovolj dobra :)
Ista zgodba, kot s prvim Zen.
Še vsaj 2 BIOS update, da bo stvar optimalno delovala.
Kaj? Nemogoce! Ce je lokalni trol objavil, da imajo par ducatov CPUjev za celo drzavo in je to sam paperlaunch!
Bwaze6 ::
Kar sem jaz spremljal niti pod LN2 ne dosežejo teh ferkvenc. derBauer ma dober review na Youtubu.
To je pa pretiravanje, der8auer je govoril, da ne dosegajo vsi Ryzen 3000 procesorji 5 GHz pod LN2, ne da ne dosegajo nazivnih frekvenc pod tekočim dušikom. Do nazivnih frekvenc je s stock hlajenjem njemu (in še nekaterim drugim) kljub single core obremenitvi boostalo cirka 100 - 200 MHz premalo, in ne PBO ne manual overclock ni pomagal. Nekateri teh težav niso imeli, TechPowerUP 3900X je šel povprečno do 4571 MHz, se pravi je večino časa prav boostal. Ampak še vedno je pa manjkal PBO single core overclock, ki ga je AMD napovedoval še par dni nazaj.
Ne rabi frekvenc: zmogljivost je že sedaj na mestu.
Peče, ane?
Semafor ::
Peče, ane?
Praktično nič ne zipam, tako da mi ni treba menjat.
KAVINSKY ::
scipascapa je izjavil:
tole nekaj tisoč glede na eu trg mindfactory niso ne vem neke hude cifre, nje?
Niso edina trgovina, so pa ena redkih, katera objavlja prodajne številke (mislim, da so jih še ameriške tech strani povzemale). Povrhu, DIY sestavljanje računalnikov po komponentah je majhna franšiza. Večina kupi prebuild mašine oz prenosnik + konzolo. In večina ne menja oz. nadgradi računalnika vsako leto.
Mogoče bo pa marketing z številom jeder kaj pospešil prodajo. Nekdo z 4 bo videl 16 pa potem se odločil nadgradit na vsaj 12 corov.
Peče, ane?
Nihče ni govoril o nadgradnji. Vemo, da z računalnikom ne počneš ničesar pametnega.
Govorimo o številkah. In trdil si, da se bodo nekateri tukaj "jokali".
No, na koncu si samo ti izpadel čuden.
Ryzen ne rabi 5GHz, da poseka konkurenco
Ob manjši porabi, če smem dopridjati.
FlyingBee ::
In kaj imaš ti toliko od tega? Boš zdaj toliko več služil ali kaj?
Bwaze6 ::
Se je pa spet pokazalo, koliko so recenzenti v resnici neodvisni. Koliko jih je upalo kaj več kot le namigniti na nestabilnosti, čeprav ne gre za izdelek, ki bo do izida mogoče še popravljen, ampak je izšel včeraj, in so desettisoči vstopili v "beta testiranje"?
Kapo dol Der8auerju, da je lepo povedal, da v bistvu pri njemu procesorji ne dosegajo nazivnih frekvenc (kar v bistvu šteje za zavajanje kupcev, v ZDA bi lahko fasali skupinsko tožbo).
Hec je, da imajo ene recenzije celo stran razlage, kako bi moral delat PBO po novem (AMDjeva razlaga), nato dejansko dosežene frekvence, ne izpostavijo pa, da stvari ne štimajo.
Se res vsi tako bojijo izgube privilegijev zastonj procesorjev, da nihče ne upa povedati, da cesar sicer ni gol, ampak namesto obljubljenih večjih hlačnih žepov kaže rit?
Se strinjam.
Če je linku zgoraj kaj za verjeti, bi se naj zadeva poštimala.
Me pa čudi, kako hudiča je potem zmogljivost na mestu?
"Neodvisnost" testerjev pa gre v obe smeri: Anandtech nima vključenih vseh posodobitev za Intel, pa tega nikjer ne omenijo.
To pa tebe, mulo, nič ne briga.
FlyingBee ::
Občutek več vrednoti ti pa res že škodi. Aja, beta testiranje, vse je ok, čeprav ne dela kot bi bilo treba. Lol, biased.
Rabi pa 7nm. Dobro je, konkurenca ne škodi, škodite pa taki fanboyi.
Ales47 ::
Kdaj pa bo v SLO v prodaji in na zalogi? Zakaj ni 3800X testov?
ocitno je cas da vrzem mojga i5 6600 stran :D
Ryzen 7 5800X3D|Aorus X570|32GB KINGSTON DDR4|RTX 3080|250GB SSD Samsung|2TB
Bwaze6 ::
Ker 100 - 200 MHz pri 4.4 ali 4.6 GHz pomeni 2 - 4.5 % višjo zmogljivist, nič takega, kar bi ob uporabi v bistvu sploh lahko zaznal, in kar bi bilo zelo očitno v primerjavi med eno in drugo recenzijo.
Je pa tu mogoče ta razlika med AMDjevimi lastnimi testi na Computexu in včerajšnjimi. Če je njim delal še PBO pravilno, potem bi npr. 3900X res povedel pred 9900K v npr. single core Cinebenchu, in v marsikateri igri, kjer je zdaj le malce zadaj.
- spremenilo: Bwaze6 ()
Po vsem prebranem sem tudi jaz o tem razmišljal.
Verjamem, da bo v naslednjih dnevih kaj več znanega tudi o tem. Še bo zanimivo.
Zdaj, ko je to malo bolj znano se bodo še drugi zakopali v to.
Ko je imel pa Intel prednost, v proizvodnem procesu, je bil pa zopet AMD kriv.
Zdaj, ko je v prednosti je zopet AMD kriv.
Funkcionalno nepismeni tiči tvojega kova težko koga predalčkate, ker se vidi kam pes taco moli.
Semafor ::
KAVINSKY ::
To pa je fanbojevsko napisano
Nič ti ne pomaga dober čip, če ne upaš zmanjšati proizvodnega procesa. In nič ti ne pomaga majhen proizvodni proces, če nimaš solidnega čipa. Saj vidiš z novimi grafičnimi, kjer 7nm ne niti malo približa performansa 2080ti.
mahone ::
Driver level errors associated with either the PCI Express bus and/or Nvidia GPUs may have prevented the chips from boosting properly - which was interesting because several reviewers today commented on not hitting advertised boosts. The author observed this behavior on both Gigabyte and MSI boards but only with Nvidia cards and at least for their own work decided it was sufficient enough to warrant not publishing any FPS benchmarks until sorted out.
hamez66 ::
Cene plat so pa kar navite. Najcenejše (kar gledam) tam okoli 200 eur, potem pa preko 600. Kaj ima recimo plata za 650 eur več od plate za 200? Kaj bistvenega po moje da nima. Kaj pravite?
V mislih imam seveda novo x570 serijo.. Za delovanje 3900x rabimo x570, ali je kakšna starejša tudi ok? Ma saj, če bom novo kupoval, bo verjetno x570..
- spremenilo: hamez66 ()
Vse kaže, da nima.
Nima pa ena za 600 ventilatorja (ima toplotne cevke namesto tega)
Z dobro x470 matično ploščo boš dober. Sicer pa je vedno več testov, primer:
https://www.techpowerup.com/review/amd-...
Med tem denarnice pravijo svoje.
Pet ur (!!!) razlike:
3900X: 500 (pred petimi urami še 460)
3800X: 120 (isto)
3700X: 630 (pred petimi urami še 540)
3600X: 230 (pred petimi urami 140)
3600: 440 (pred petimi urami 280)
Skupaj: 1920 kosov.
Lep primer, ko dobiš slabše rezultate, če privzeto izklopiš PBO. OC on zen 2 dead.
https://postimg.cc/GBcg0jKF
mahone ::
A ni bla podobna situacija z Zen+ ko so nekateri z All Core OC dobivali slabse rezulate vs stock settings?
Mislim, da se je zen+ splačal navit na 4.1/4.2 GHz overall, sploh, če si je ratalo na 65W cpu-ju.
Pri zen2 je na voljo še PBO + Auto Overclock, sam tega ne bi počel na B450 oz. še nekaj časa, Steve iz HU je skuril svoj 3900X npr.
Sparat je treba, pa tut ce se kej skuri.
Men je tko ze 2x ratal neki skurit, pri 775 intelu cpu, pri am3 pa plato (odletel VRM, pa je bila high end plata), tko da ne dajem vec novih procesorjev na stare plate.
s1m0n ::
Ampak ta nov čipset (X570) pa tudi porabi 2x več "štroma" kot X470.
A niso mogli dat malo večje HSje na čipset namesto teh ventilatorjev, ko dobro vemo kaj je bilo z njimi v preteklosti:)
- spremenil: s1m0n ()
