Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
ICP dvig je 15% ampak na CESu ni imel dokončne clocke, ker je čip 75W namesto 95W.
V igri so še frekvence za potlej dosežen 25% - 30% ICP (skupaj)
- predlagal izbris: AapocalypseE ()
Predator X ::
kje imaš ti 15%? Trenutno smo 15% nad 4,05GHz R7 2700X
- spremenilo: Predator X ()
https://www.anandtech.com/show/13829/am...
+15% Performance Generation on Generation, Minimum.
During the keynote, AMD showed some performance numbers using the new Ryzen 3rd Generation (Matisse) processor. The test in question was Cinebench R15.
Our internal numbers show the 2nd Generation Ryzen 7 2700X scores 1754.
This new 3rd Generation Ryzen processor scored 2023.
This would mean that at current non-final clocks, the new parts give a 15.3% increase in performance generation on generation. Cinebench is an idealized situation for AMD, but this is not at final clocks either. It will depend on the workload, but this is an interesting data point to have.
single thread.
BTW.
Slo-Tech IPC dobra.
BTW.
Slo-Tech IPC dobra.
- spremenil: D3m ()
Bwaze6 ::
You lost me completely... Kako je to single thread, če ga računaš iz mulithread Cinebench R15 rezultata?
Zadnji podatek clock to clock Zen+ vs Zen 2 je bil 13%.
Dober mesec nazaj. Zakaj ne bi bilo možno?
mahone ::
Kakšne bodo cene dali ne vem.
Njihova stvar. Sam osebno ne bi dal preveč, lih tok, da zjebem konkurenco do prihoda 10nm. :)
Predator X je izjavil:
Kaj? Zdej je AdoredTV AMD man? Nakonc bo pa 8C/16T 400$ in 16C/32T 700$-EUR.
Pa še GHzji bodo all core bost pri 4-4,3Ghz in max OC na 4,6-4,7GHz.
PS: Naj te bode še bolj.
Nikoli ni rekel, da je AMD man.
Kje s pa bil ko je objavil 5 part video o AMD dominaciji s Polarisom na celu?
Tip ne morer bit more obvious AMD fanboy samo poglej si njegove stare videote iz leta 2014
Wrop ::
Ti ga pa že od začetka 2017 pohaš/pokaš s napovedmi o cenah 8C/16T. 8C/16T okoli 500-600€, so bile tvoje napovedi.
Pa ti sploh veš, da že sedaj dobiš 8C/16T gen 1 za 160 € (Ryzen 7 1700). Pri nas pa pod 200 € za Ryzen 1700X. Eni pa še sanjate od 400 € za 8C/16T ZEN 2. WTF?
Najcenejši 8C/16T ryzen 3000 bo tam okoli 200 € +- 10%.
Me tudi zanima kje v videu je to zatrdil.
mahone ::
Poglej si njegov Amd 5 part masterplan video. Polaris hype machine
Ne morem resno jemat nekoga, ki zali nvidia kupce za nvidiote, bluzi o 720p benchmarkih da so fake in nerealni... Pa se marsikaj se najde ni bil tip brez razloga benan na r/amd zdaj je pa kar naenkrat spet AMD Prophet
Treer ::
Če bi bila tale nova Vega cca 500EUR, bi še nekako šlo, za 700 je pa sedaj, ko bo freesync deloval tudi z Nvidiami ne bo kupil praktično nihče
- spremenil: Treer ()
rdecaluc ::
Aha ker bodo vsi sedaj kupovali točno teh 10 podprtih zaslonov, katerim bo cena šla v nebo.
Bolje nekaj kot nič. Tisti ki jo bo želel jo bo kupil, večina folka pa itak životari na integriranih.
Est modus in rebus. ,typos
ziga1990 ::
Fičo proti Ferrariju, nimaš kaj...![]()
samo potrjuje , da so igre zoptimatizirane za intel ne pomeni,da je Ryzen slab
Treer ::
FlyingBee ::
Freesync ima precej omejen diapozon v katerem deluje, gsync pa od 30 pa do max kar monitor omogoča.
galu ::
extra package. Dejno ne blebetaj CPU ima do 300-350W TDP zlahkoto na AM4.
Aha, CPU bo bundled s chillerjem in DIY kompletom za prišvasat nekaj dodatnih VRM.
Hmm kolk ma pa nek i9 9900k 5Ghz W?
Preveč nedoločeno vprašanje (AVX, napetost, itd.): https://www.tomshardware.com/reviews/in...
Tako to gre.
FlyingBee ::
Mah, ne vem, no. Ryzen 2000 serije še ni presegel konkurence, ne bi ravno amd na piedistal postavljal, mogoče po izidu 3000 serije. 9900k je vseeno še vedno hitrijš od vsega kar je amd v 8/16 konfiguraciji izdal.
MostWanted ::
Dej se pomiri in ne pisi neumnosti. Razpon je odivsen od posamezne implementacije in ni omejitev samega freesynca.
Predator X ::
Sej ni panike naredit proc slab. Jst lahko takoj naredim, da i7 8700k ne doseze niti 1000fpsjev ceprav laufa na 5ghz ter ddr4 3600.
Lahko dam jst zravn samo primerjavo ce se strinjate sam da...
Treer ::
Ti šment, niti 1000 fps-jev! Kaj pa zdaj?!?
Iskanje na slo-tech zna biti zelo dehamorno.
Le kako ti je uspelo zadeti tak v nulo?
Če bi bila tale nova Vega cca 500EUR, bi še nekako šlo, za 700 je pa sedaj, ko bo freesync deloval tudi z Nvidiami ne bo kupil praktično nihče![]()
Zato bodo navili cene?
Zanimivo.
- spremenilo: FireSnake ()
Predator X ::
Ti šment, niti 1000 fps-jev! Kaj pa zdaj?!?![]()
Mislil sm 100 fps.
Bom dal sam vam ne bo vsec. Ker bo hitrejsi od njegovega hing end setupa pri 3,8GHz
Ahim ::
evo, "delujoč" fresync ;)
https://www.pcworld.com/article/3332198...
What exactly is wrong? Nvidia’s answer is to shrug and suggest asking the companies that made the misbehaving monitor. We didn’t get official comment from AMD
Zanimiva logika - nek monitor (NVidia namenoma skriva proizvajalca in model) ne deluje v redu z NVidiino kartico. Krivec je seveda AMD, ker ni naredil dobre NVidiine kartice in neznanega monitorja.
Zanimivo, da ko ima taisti neznani monitor s kilavim cungalunga panelom zelo podobne tezave z AMDjevo kartico, ne grejo vprasat v McDonalds ali Ford zakaj je temu tako.
Predator X ::
No sej sm ti dal primerjavo kjer R7 2700X ddr 3446llc premaga i7 8700K ddr4 3466MHz.
Bom se dal za primerjavo BF5 DX11 in DX12.
Tisti CPU RYzen 3000, ki je bil na benchu naj bi bil R5 3600X base clock 3,7GHz all core ~ 4GHz ter boost up to 4,5GHz. SC naj bi se navil na 4,5GHz kar pomeni ~ 4,95GHz ZEN+ oziroma 4,8GHz Intel.
Sej je jasno, da je AMD s Freesync Gsync zgazil. Poteza nVidia pa je brezpogojna kapitulacija.
Vse ostalo je Pr stunt.
Wrop ::
Samo malo nadpovprečen spomin je potreben.
Pa pri določanju cen nekega še neizdanega procesorja, je potrebno pretehtati precej stvari (zmogljivost, cene primerljivih CPE konkurence, znamka, tržni delež, želje po večjem trgu, želje po prodaji, leta slabe prodaje in posledično bistveno višje cene konkurence, itd.) Ne more se samo pogledati cene od konkurence primerljivega procesorja in dat ceno -10 %.
Wrop ::
Uradno vemo samo podatke o sistemu.
AMD engineering sample silicon, Noctua NH-D15S thermal solution, AMD reference motherboard, 16GB (2x8) DDR4-2666 MHz memory, 512GB Samsung 850 PRO SSD, AMD Radeon RX Vega 64 GPU, graphics driver 18.30.19.01 (Adrenalin 18.9.3), Microsoft Windows 10 Pro (1809); Intel i909900K, Noctua NH-D15S thermal solution, Gigabyte Z390 Aorus, 16GB (2x8) DDR4-2666 MHz memory, 512GB Samsung 850 PRO SSD, AMD Radeon RX Vega 64 GPU, graphics driver 18.30.19.01 (Adrenalin 18.9.3), Microsoft Windows 10 Pro (1809).
Vir: AMD
FlyingBee ::
Jasno je, da bo 7nm ZEN2 prinesel tisto kar čakamo od AMDja ves ta čas od Phenom II naprej. Dobro za trg, za kupce, za AMD in tudi Intelu ne bo hudega, dokler se bodo držali napovedi 10nm v 2020. Prihajajo zanimivi časi, končno.
FlyingBee ::
Athlon 200e ali rabljen i5 2500 za podobno ceno? Recimo, da je vse ostalo za enako ceno.
