Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
Miha20 ::
Natančneje je hladilnik 1650w sam tdp je 1000w
Mogoče je pa čas za trofazne napajalnike.
- spremenil: Miha20 ()
tryhard ::
ziga1990 ::
malo berem po internetu in sem zasledil rumor da bo AMD z zen 2 jedri uporabil 6 core CCX torej lahko pričakujemo procesor z 12 jedri?
Pred dnevom ali dvema je bila AMDjave predstavitev nacrtev za bliznjo prihodnost in so omenili podvojitev stevila CCX, nic pa ni bilo omenjeno vecje stevilo jeder pri samih CCXih. Nisem pa prav pozorno bral, ker me je bolj zanimlo za GPUje.
Na Tomshardware si poglej, mogoce notri najdes odgovor.
- spremenilo: tikitoki ()
Truga ::
Tako je. Govorice so tudi da bo zen 3 ze kar 8 jeder na CCX :P
Also,
Intel used a Xeon processor for its "new" desktop demo, likely the 8176 Xeon CPU, then pretended that the CPU was a brand new desktop part. The company also pushed the narrative of a 5GHz overclock on 28 cores, but neglected to note that they were using a chiller to achieve these temperatures. It's an old CPU -- rebranded as a new one, at that -- and it's overclocked with an unnamed chiller that operated below -10 degrees Celsius.
lol
- spremenilo: Truga ()
filip007 ::
Ja Intel straši s frekvenco, AMD pa z jedri, to bo še zanimivo kam bo šlo to vse skupaj.
Zero games, zero talk.
ziga1990 ::
^^ ne daleč, če AMD-ju uspe z 7nm Zen 2 jedri bo tudi z frekvenco dohitel intel
BT52 ::
Also,Intel used a Xeon processor for its "new" desktop demo, likely the 8176 Xeon CPU, then pretended that the CPU was a brand new desktop part. The company also pushed the narrative of a 5GHz overclock on 28 cores, but neglected to note that they were using a chiller to achieve these temperatures. It's an old CPU -- rebranded as a new one, at that -- and it's overclocked with an unnamed chiller that operated below -10 degrees Celsius.
lol
Truga misliš ZEN 2? Ker ZEN 3 pride šele 2021. Zdaj smo na ZEN 1 in Zen 1+.
Damn, zadnje čase spremljam ceno AMD-jeve delnice.
Krepko čez 15$ ta hip. Če jo primerjamo z 9.7$ 25 aprila, je to več kot 50% boost.
klinker ::
Ryzen jih je okrepil na vseh podrocjih. Ce bo se nova Vega vsaj problizno tako dobra, bodo spet na konju, ceprav dvomim da bodo na nivoju Nvidije p/w, kljub 7nm, ker je Nvidia precej naprej tu.
filip007 ::
Saj z nižjo ceno balancirajo pa je, hitrost ni vse danes.
Predator X ::
In kaj ti to pomaga?
NB je problem... če dvignejo NB 2:1 IMC je lahka tud sam 4C per CCX.
- spremenilo: Predator X ()
Predator X je izjavil:
https://www.pcper.com/reviews/Processor...
Komunikacija med jedri na različnih CCX-ih zna biti zamudna.
Saj za ZEN2 napovedujejo napredek v "multiple dimensions".
Če bo 8 jedernik imel vsa jedra na istem CCX-su, potem bodo latence de-facto boljše.
Na primer PS3 emulator RPCS3 optimizacija za Ryzen se glasi tako, da teče samo na enem CCX-su, potem je precej bolje.
Predator X ::
Zakaj rabiš hitro komunikacijo med jedri?
Ker so sodobne aplikacije/igre večnitne in "komunicirajo" med seboj.
Za primer bom dal kar RPCS3, kjer večina iger teče občutno hitreje na 3c/4c (6/8c cpuji), samo, da je CCX enak.
Sedaj je to tudi uradna optimizacija za Ryzen procesorje v tem emulatorju.
Intel teh težav na svojih 6c procesorjih revimo nima.
- spremenil: Jarno ()
Predator X ::
Za primer bom dal kar RPCS3, kjer večina iger teče občutno hitreje na 3c, samo, da je CCX enak.
AHAHAHA
Kaj delajo?
Kako so pa konzole narejene... če bi zdej probal 1+1 vs 2 + 0 nek špil bo razlike 0-1%.
Whatever. Intelu tudi ni uspelo spacati hitrega mesha, in so novi 6 jederniki 8x00 na istem cpu kompleksu.
AMD lahko stori enako, zakaj pa ne. Dokler bosta v igri 2 CCX-sa za 4-8 jeder bodo latence temu ustrezne.
Predator X ::
Špili/engini so narejeni ravno obratno.
Čim manj "komuniciranja", optimizirani za 2MB LLC ter RAM (bandwidth). Samo zaradi konzol.
Kakorkoli, 1 CCX (8 jeder) za consumerje/igričarje je predpogoj, da pri pomnilniški arhitekturi ujamejo Intel.
Pogoj je potreben in ne zadosten, lahko še vedno pičijo "lazybones".
Predator X ::
Če ima kdo čas lahko naredi primerjavo 2+2 vs 4 + 0.
Pri 2 + 2 naj uporabi single channel 3200Mhz in pri 4+0 dual channel 1600MHz ddr4.
TOP ::
Rabim en nasvet.Plata bo X470 Asus Strixe F in zanima me,katere rame 3200mhz.Hvala.Ker na uradni strani je zelo slaba podpora 3200Mhz.
BT52 ::
Bojda velikokrat priporočajo tiste z Samsung die. No je pa res, da podpora dandanes zelo zelo izboljšana in skoraj laufa na krompirju.
TOP ::
klinker ::
Samo CL14 so woho drazji od CL16.
Kot sem bral, niso vazne frekvence in timingi ki jih navaja proizvajalec, le chip mora bit Samsung B die in vsi letijo vsaj 3200 CL14, tudi ce so po defaultu pocasnejsi.
BT52 ::
Lahko pogledaš bilokateri yt video na te teme. Načeloma tehnični kanali priporočajo Samsung. Predvsem glede memory zadev pogledaj Wendela na Level1tech. Potem imaš GamerNexus, KitGuru, PaulsHardvare, Hardvare Unboxed, TechDeals, Bitwit, deloma Linustechtips...
BT52 ::
Na žalost je tega preveč. Naredi si sam raziskavo. Tudi ni moj denar. :D Zdaj lahko pri vsakem kanalu pogleaš rarnorazne "builde" sestavljenih videjev, kjer tudi testirajo sestavljen PC. Izpiši si podatke.
Drugače 5s googljanja...
https://www.reddit.com/r/Amd/comments/6...
Drugače pa preveč kompliciraš ne delaš space shuttla zadeva bo bomba. Letela bo danes in tudi v prihodnosti.
- spremenilo: BT52 ()
Se strinjam, če kupuješ za 1080p in 144Hz gaming, potem raje vzameš Intela.
Pri 1440p ja je bottleneck že gpu.
Zato so cenovno DDR4 3200/16 sweet spot.
ziga1990 ::
AMD je boljši v P/P
Za normalen PC gaming raje vzamem R5 2600X kot i5 8600, čakamo zgolj na B450 matične.
Z midrange grafično itaq ne bo neke razlike, sploh pa ne med CL14 in CL16 rami.
Če tako našparamo 100€ (rami, plošča, cpu hladilnik) pa razliko v grafično, way to go.
Predator X ::
Počak na 7nm, če se ti ne mudi.
klinker ::
Pa ni to igracka za glupe igrice, mater
32 jeder all core boost na 3,4Ghz in hlajeno z zracnim Intel lahko sanja se dolgo. To bo workstation da glava boli, za tega ki to rabi!
Spock83 ::
a je core boost ali je cores boost?
BT52 ::
Ta novi XFR 2.0 boost individualno poisce najboljsa jedra. Omogoci tudi OC glede na hlajenje. Zanimivo ugotavljajo, da se skoraj vec ne splaca manualni OC, ker je algoritem kar ucinkovit.
filip007 ::
Ja pa voltaža gre do 1.5V in 90°C.
Truga ::
To je meni ful vsec, tele avtomatske OC varjante. Koncno bom prinesel domov chipovje, vrgel gor cooler, in bo vse delalo samo. Nic vec enga mesca jebanja z bios clocki in stability checki.
BT52 ::
Ja za hipec. Dvomim, da bo od tega pobralo cpu. Niso inzenirji krav pasli...
klinker ::
Bi firesnake znal kaj rect okoli tega, glede na to da ima 2700X. Malo dvomim v to, ker prvic vidim, pa kot sem marsikje vidu zre 2700X na max turbo okoli 108W, ihs je prispajkan, cooler pa dober.
Tudi Intelovi niso krav pasli, pa glej do kam gre 8700K s stock coolerjem.
BT52 ::
Seveda niso. Ker so zmagali ekonomisti in so jim rekli naredijo 10% plusa pri strošku izdelave (številka potegnjena iz riti). Pač "pasta" je za en k***. :D Žalostno je predvsem, da tega ne naredijo niti pri HEDT segmentu. Čudno. Jaz razumem za razne APUje in midrange potrošniško šaro je dovolj. Ampak z mojega vidika nedopustno. Da morajo razni derbauerji, nexusi pacat z "LM" pastami in delidi...
