AMD ZEN - nova X86 Jedra
chucki ::
Sem vprašal na functech in so rekli, da ima box 3 leta garancije, tray pa verjetno 1 leto potem?
Threadripper 1900X so dali "na police" v Indiji.
  • spremenilo: FireSnake ()
chucki ::
6151 ::
nebi raje kakšne noctue?
7900X3D | 32GB | 6800 | 4 TB
No, počasi bo dovolj o nakupih.
Če se to nadaljuje, potem se bo treba preseliti v sklop "kaj kupiti".
Ker menim, da smo dali že dovolj informacij (tudi glede hlajenja).
hojnikb je izjavil:
Some extra notes:
How to reproduce the segmentation faults of Ryzen bug:
http://fujii.github.io/2017/06/23/how-t...
Some users in Japan have done analysis and think it's address shift errata by 64 bytes. If so, it is a hardware defect.
Turning on/off certain hardware features as some people may suggest only reduces the chances of encountering the issue and may introduce other unwanted effects like lower performance or compromised security.
Issue was initially encountered with GCC on Linux, but was later found to also occur on the Windows Linux subsystem. Other *Nixes and BSD has also observed the issue.
Stock CPU and RAM and even ECC RAM does not eliminate the issue.
Quote:
ouch ;((
New Ryzen Is Running Solid Under Linux, No Compiler Segmentation Fault Issue
mitna ::
Lp,
Včeraj sem pustil mojemu R5 1600 lavfat https://github.com/hayamdk/ryzen_segv_t... (prek WSL)čez noč in seveda je vrglo cel kup seg faultov:(. Se mi splača pošiljat cpu AMDju za reklamacijo? Bi blo bolje to opravit prek štacune kjer sem ga kupil(nakupovanje.net)?
Linuksa sicer ne uporabljam, vendar včasih kaj sprogramiram na windowsih in nebi rad videl da se v prihodnosti prikaže kakšna napaka zaradi tega.
Poleg segfaultov mam pa še cel kup problemov, ki mi kravžajo živce. Ko se nalagajo določeni programi mi miš zamrzne za 1/3 sekunde, predvajanje videa ni gladko. Ram ne lavfa pri 3200mhz pa čeprav je bil na QVL seznamu itd. Ampak to je vprašanje za drugo temo.
galu ::
Nice, zdaj lahko programerji za crashe SW okrivimo uporabnikove Ryzen CPU-je, ne pa bugastega programa. :P
Kar se pa tiče zamenjave - v kolikor nimaš dejanskih težav sedaj, se ti morda splača počakati na kak recall AMD-ja, ali pa microcode update, ki bo olajšal/odstranil potrebo po vračilu. Serviserji bi te drugače znali malo čudno gledati, biti (do) 45 dni brez CPU-ja pa je tudi tečno.
P.S. za tisto 64B addr shift napako nisem našel nobenih kredibilnih virov ... Fake news?
Tako to gre.
mitna je izjavil:
Dvomim, da je za druge težave, ki jih imaš, kriv procesor.
Najprej bi se obrnil na AMD, da bi se prepričal, da imam dejansko procesor z napako.
Če bi bil odgovor AMDja pozitiven,bi jaz najprej vprašal pri nakupovanje.net, ker bo hitreje.
Šele nato bi se (spet) obrnil na AMD.
hojnikb ::
glede na to kok napak majo cpuji dandanes (googlaj intel errata če ne verjameš) nebi bil presenečen, da so nekateri crashi ravno zarad tega.
Z razlogom določene industrije uporabljajo zastarelo tehnologijo.
#brezpodpisa
mitna ::
FireSnake je izjavil:
Po vsej verjetnosti imaš prav.
Verjetno bom počakal kak mesec, če bo AMD dal kako izjavo, preden stopim v akcijo.
mitna je izjavil:
Lp,
BIOS matične je zadnji?
|HP EliteBook|R5 6650U|
Predator X ::
wccftech.com/amd-launches-ryzen-threadripper-1900x-8-core-processor-with-64-pcie-lanes/
Predator X ::
vsi smo se usteli pri ryzen 8c hedt, 4+0 die 0 + 4+0 die 1 .
Predator X ::
SuperVeloce ::
Mogoče ima to kaj veze s količino L3?
Predator X ::
SuperVeloce je izjavil:
Seveda ima.
AMD ima 4 die. Od tega uporablja samo 2 za threadripperja
1 die = 2x CCX, 16C/32T, 32 PCIE lanes
2 die = 4x CCX, 32C/64T, 32 PCIE lanes
Zdej
16C/32T = die0(4+4)16MBL3$ + die1(4+4)16MBL3$ = 32MBL3$
12C/24T = die0(3+3)16MBL3$ + die1(3+3)16MBL3$ = 32MBL3$
8C/16T = die0(4+0)8MBL3$ + die1(4+0)8MBL3$ = 16MBL3$
Poglej kaj naredi IF z RAM latenco.
http://www.guru3d.com/articles_pages/am...
Predator X ::
neo5468 ::
Me zanima če tisti ki so v zadnjem času kupili i5 sploh vejo da obstaja Ryzen 1600. Tista fora ko daš 200€ za inferior produkt na dead platformi hehehehe.
D3m0r4l1z3d ::
Za igre sploh ne bodo opazili, tudi če bi imeli r5 1600, tako da taki, ki ne vedo da sploh 1600 obstaja, so itak z enim ali drugim za ta denar zadovoljni.
chucki ::
6151 je izjavil:
Ne želim imeti kilski hladilnik, ki zasede pol ohišja :) NZXT kraken x62 se mi zdi, da bo odličen nakup :)
neo5468 ::
Predator X ::
D3m0r4l1z3d je izjavil:
To si razlagate zelo napačno, dost ljudi ne bo opazil razliko med FX 8350, i7 7700K, R7 1600 in i5 7600K
Predator X ::
Ker imam ravno malo časa ;)
AIDA
CineBench R15
Lulz
Ermmmmm......slike?
Predator X ::
D3m je izjavil:
Ermmmmm......slike?
globoko grlo ::
citirano iz predatorX
CPU type : DUAL CORE, mwahahahaha
Predator X ::
globoko grlo je izjavil:
2c/4t.
Slike so sedaj prikazane.
Predator X ::
Glavno je, da je score višji od i3 7350K.
Če bi AMD prodajal 2C/4T z mini iGPUjem (128sp) za 75-80€ bi bil killer še za pentiuma.
i5 4460 performance ;)
D3m0r4l1z3d ::
Teorija.
Predator X ::
Teorija.
Sem hitrejši od i3 7350 4,2GHz ;)
D3m0r4l1z3d ::
Ker imaš čas.
neo5468 je izjavil:
Boljši grafi:
https://imgur.com/a/FcsF0
Tale graf je zelo zanimiv.
Zanimivo je pa tudi, da Intel ni toliko izgubil, ampak je AMD ogromno pridobil.
Skupaj pa se je procesorjev prodalo več.
Vseeno, procent je vzpodbuden. Če AMD nadaljuje v tem stilu jih nekje decembra čakajo lepe številke :)
Wrop ::
Kako ni nič izgubil? Vsak nakup pri konkurenci je izgubljen denar za njih.
Jaz sem gledal absolutno. Glede na prodane kose.
Je pa res, da graf ni normaliziran. In tudi celotna "pogača" (desno) je večja kot ob začetku merjenja.
Wrop ::
AMD je marca prodal 3000 kosov, Intel pa 7500 kosov. V avgustu je AMD prodal 7000 kosov Intel pa 6000. Prihodki so temu primerni. So pa cene procesorjev AMD bolj padali kot Intelu.
Več kot polovico prodanih procesorjev v avgustu je AMD, prihodki prodanih procesorjev tudi.
8 jedrnika se dobi že pod 300 €. Noro. Prodaja R7 1700 bo verjetno septembra poskočila. Zato se pa Intelu tako mudi z novo generacijo.
Si bodo vsaj Intel fani končno lahko privoščili poceni 4C/8T.
D3m0r4l1z3d ::
Ne bo 4/8, i3 4/4, i5 6/6, i7 6/12. 8700k za 330 eur bo šel za med, če bo cena držala in performance obljubljeno višji. High IPC, FTW.
neo5468 ::
i5 in i7 cene so bile že več let iste. Mislite da bo sedaj i5 še vedno 200€, glede na to da bo 6/6? To bojo prvič višal jedra v 7 letih čez celoten lineup.
D3m0r4l1z3d ::
Zahvala gre AMDju seveda, na mf so prvič v zadnjem desetletju prodali več AMD procov od Intelovih. I7 7700k se še vedno dobro prodaja, i5 pa razumljivo ne več toliko, 6/12 imajo za 200eur, 8/16 pa za 290eur, kar je zelo aggressive pricing, thank god.
Predator X ::
zakaj bi avg gamer kupil karkoli nad r5 1600?
je zelo ucinkovit, ima dober stock cooler.
ryzen 2 7nm je ze napoti, taped out 2H 2017
am4 - 4 leta
TOP ::
AM4 4 leta intel Cofy lake pa koliko ene 6 mesecev,leto ziher ne.I5 tudi sedaj ni bila 200e vsaj K različica sepravi bo okoli 280 in I7 pa bliže 350 vsaj prinas,to je moje mnenje.
D3m0r4l1z3d ::
average gamer več od r3 1200 ne rabi
gddr85 ::
kupiš konzolo in si dober za par let :P
neo5468 ::
Zraven pa še eno vedro, da kozlaš not od 30 fps.
hojnikb ::
nimamo vsi motion sicknessa
#brezpodpisa
Truga ::
eni hocejo 60fps ali celo vec, drugi pac raje gledajo diapozitive. tak to je.
  • spremenilo: Truga ()
globoko grlo ::
Lol psihopati in self drkalice, konstantnih 30 fps je cist zadost za normalno spilanje. V kolikor ste pa mutantje z x-rayi pa spili niso za vas.
Predator X ::
tud konzole gredo proti 60hz
30 FPS je dovolj za možgane. Za oči pa ne (še vedno "trpijo").
Šele pri 60FPS je dovolj tudi za oči.
Seveda imaš primerke, ki vidijo razliko med 60 in 75FPS (čeprav ni mogoče, da bi možgani to zaznali).
Tako, da ... jaz ne bi ravno poveličeval 30FPS, kot zadovoljiv FPS.
196 / 623
