Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
D3m0r4l1z3d ::
graf kjer je prikazano povprečje min fps, pls
AapocalypseE ::
Unshackle the GTX 1080 with some strategic settings changes, and Deus Ex can actually run quite swiftly. Its CPU scaling seems to top out at about eight threads, however, so the Core i7-7700K and company rule the roost by a decent margin. Just like Watch Dogs 2, the performance progression in the graphs above is more or less what we expect from a completely CPU-bound test.
While there's little churning of note for these CPUs at the 16.7-ms threshold in DXMD, a click over to the 8.3-ms mark shows that the Intel CPUs spend substantially less time holding up the GTX 1080 than the Ryzen chips do. Even with an apparent eight-thread workload to fully occupy them, AMD's latest just can't keep up with the GTX 1080's thirst for work at higher frame rates.
- spremenil: AapocalypseE ()
D3m0r4l1z3d ::
Jah, dummy, če enkrat pade na 30fps pri i7 in enkrat na 40fps pri r5, bo graf kjer je najnižji fps pri r5 za 10fps boljši, kar pa pomeni jack shit za playerja, povprečje avg ni dost natančno, fcat pa kot zgoraj vidiš dovolj in you have been served
- spremenilo: D3m0r4l1z3d ()
Ne spremljaš kaj dosti teme A N?
Bo treba najprej popraviti nvidin DX12, da ne bo Ryzen trpel.
Ker vem kok vama spomin peša.
- spremenil: D3m ()
D3m0r4l1z3d ::
Samo fanboyem že ni dost vseh teh izgovorov. Ok, počakmo.
AapocalypseE ::
Z ryzenom bi bili fpsji nižji
Sem prilepil zato, ker si napisal, da je treba Nvidijin DX12 popravit, ampak dela tako kot treba zgleda.
D3m0r4l1z3d ::
AapocalypseE je izjavil:
Lol, d3m še vedno bluzi.
GenZNPC ::
So ze pofixali te memory probleme z ryzenom al je se vedno ena vlka loterija vseskup?
skibidi
Seveda, da dela.
Samo ne dobro na Nvidia + Ryzen kombinaciji.
Pridruži se nam.
https://forums.anandtech.com/threads/ry...
Plata?
- spremenil: D3m ()
AapocalypseE ::
Potem pa je težava spet v ryzenu...
Intelu je vseeno s katerim taborom sodeluje.
amd pa nalašč gimpa Nvidijo, da bi še amd kartice kupovali.
Kot sem že napisal enkrat, če se odločite za ryzen, še amd kartico dodate in je to nekaj najboljšega
GenZNPC ::
Pridruži se nam.
AMD Gimping Evolved
Plata?
Nasplosna plata in nasplosn memory.
Kot sem že napisal enkrat, če se odločite za ryzen, še amd kartico dodate in je to nekaj najboljšega![]()
AMD je ocitno nezdruzljiv z zmogljivimi karticami od Nvidije,
bo mogla Nvidia placat AMDju spet za kak updejt
skibidi
- spremenil: GenZNPC ()
Kar beri dalje.
Ni problem Ryzen ampak tudi Intel (HEDT).
D3m0r4l1z3d ::
Ryzen je problem, ni treba več brat.
AapocalypseE ::
Ma neke resne probleme ta ryzen ja...
Me zanima kdaj oz. če ga bodo sploh spolirali... leto? Dve? Tri? Nikoli?
Time will tell...
Time will tell...
D3m0r4l1z3d je izjavil:
Imate kak pametni pisarniški stol?
Ali samo loungé?
GenZNPC ::
Ryzen mi je zelo zanimiv, da bi ga mogoce nabavil, ampak tako nezanesljivo platformo met,
medtem ko je stari intel rock solid stable pa karkol menjavam po njem.
skibidi
GenZNPC ::
Nah ze od prvega dne, ko sm usbflashback naredu dela tko kot mora vse.
Ne spomnim se inkopatibilnih ramov pa raznih freezov pri delovanju
Tut z graficnimi nima problemov ;P
Je pa res, da ima AMD za to nizjo ceno
skibidi
Predator X ::
IDF skenslan za vedno, AMD premočno udaril
http://www.legitreviews.com/intel-devel...
i7 4970k thank u so much
GTX + DX12 ryzenu ravno ne diši.
Še kdo opazi, da so zdej popularni samo tisti benchmarki, kjer ima AMD težave z določeno konfiguracijo?
- spremenilo: Predator X ()
GenZNPC ::
Seveda, ce ze fuknes dnar za novo masino je fajn vedet vnaprej kaj te caka, da nebo presenecenj.
zato pa bolje intla nabavt pa si ziher, (brotip: niti zarad ramov se ne sekiraj prevec) cene grejo gor gor gor
skibidi
D3m0r4l1z3d ::
R5 1600 za 232eur je real deal
Meni pa se zdi res dober deal 1600X, ki ima poleg 6 jedrnosti tudi bolše frekvence(torej low-core performance) od kateregakoli drugega ryzena, razen res čisto najdražjega s katerim je glede tega izenačen. Torej tisti pravi upgrade glede na 1500X, ker ima tako večjo frekvenco kot več jeder.
Vse to za komaj 35EUR več od 1600.
- spremenil: Lonsarg ()
D3m0r4l1z3d ::
Uh, ne navijam že od najstniških let naprej ne. Priporočila za nakup za overclockarje se itak tako drugačna, da ne moreš sploh v isti koš to mešat.
AapocalypseE ::
In bi bilo kaj narobe, če bi si vzel 5 min. časa in navil cpu?
1600X deluje na 3.7GHz in 1600 na 3.4GHz. Te frekvence so z vsemi jedri.
Oba se navijeta bp na 4GHz in sta praktično identična.
S tem, da dobiš zraven 1600 hladilnik, ki je dovolj za 4GHz.
dvignat frekvenco na 3.9Ghz in voltazo na 1.35V pac ni tezko. Nekatere plate znaj to celo same.
X pac ni vredn dodatnega kesa, zal. Ce bi mel zram 125w cooler se mogoce, tako ti pa niti kulerja ne dajo pa se extra racunajo.
- spremenil: iloveboobz ()
Predator X ::
Enega ali drugega naviješ na 3.9ghz, pa 35 eur v boljši kuler v primeru brez x
neumna primerjava. Je tole s strani techspota. Game bo sam od sebe bolj hard na 12/16T proce.
D3m0r4l1z3d ::
A ti tudi ta stran ni všeč? No daj svoj link, da ne boš užaljen.
D3m0r4l1z3d ::
Točno tako, veliko se je spremenilo od takrat. 1600 na 3.9ghz pa mir.
Ko bi še frekvence šle gor...
Ne obremenjuj se.
Ga v vsakem primeru ne boš vzel pa če bi imel 5GHz out of the box.
klinker ::
Ne obremenjuj se.
Sej ga niti ti ne bos
GenZNPC ::
Ce drugo leto izdajo kak REFRESH z clock bumpom in da bo zadeva v nulo pofiksana,
je naslednji R 1850X (al 1900X) moj moj. mark my words, razen ce bo modri prisel vmes
skibidi
AapocalypseE ::
d3m, kaj pa ti veš kaj bi jaz vzel?
Če bi šal ryzen že 4.5GHz bi pojedel Intela, tako da, če bi šel 5GHz bi pa kar dva nabavil in ju dal v CF
Isotropic ::
znalo bi biti, sam na proper refresh (oz. TOC - prilagoditev procesu, arhitekturne optimizacije) boš mogu čakat do 2019.
bral sem sicer neke napovedi, da amd nima šans s profitabilnostjo do GLOFO 7nm procesa.
pa te fore, go slednji izpusti kakšen proces, tut niso fajne za AMD, ker morajo biti potem dlje časa na obsoječem nodu ali farmat waferje kje drugje, za kar pa morajo plačati (amd) glofo-ju kazen za vsak kupljen wafer.
Tole bi pa rad prebral.
Težko verjamem, ker cene Ryzenov so kar dobre, kar se marž tiče (sploh R7 serija).
Vem pa ne.
- spremenilo: FireSnake ()
Ne obremenjuj se.
Sej ga niti ti ne bos![]()
Seveda, da bom.
Takoj, ko bo na trgu Lenovo z Zen APU.
AapocalypseE ::
To pa je sramota za Nvidio, če gledamo GTX 770 vs. 280X, ki sta bili kartici včasih tam tam.
Nvidia je zelo potrošniško naravnana.
Te hitro prepriča, da menjaš vsako generacijo.
HD 7790 > GTX 950
Aja pa, da malo zasolim.
Fermi je DX 12.
HD 7790 > GTX 950
Fermi je DX 12.
- spremenil: D3m ()
