Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
AapocalypseE ::
Se lepo vidi, da 10400F z 2.66GHz ramom komot konkurira 3600 in je tudi kje celo hitrejši.
Ne rabiš Z490 plate in tudi za 180€ 3600 pri nas ni za dobit.
AapocalypseE je izjavil:
Primer 1 : Core i5-10400 vs. Ryzen 5 3600, Sub-$200 CPU Battle
Primer 2 : Do Not Buy: Intel i5-10400 CPU Review & Benchmarks vs. 3300X, 3600, 10600K (ft. 2666 & 3200 RAM)
Cue in: zvočna in slikovna sporočila so za tiste, ki ne znajo brati...
(sorry, ampak s temi "poglej ta video da spoznaš resnico" ste že tečni)
AapocalypseE ::
Primer 1 :
That being the case, the typical out of the both experience won't be power limited and therefore we'll be testing the Core i5-10400 on a Z490 board with no TDP restrictions in place.
Since this is a locked part, we'll include a DDR4-2666 memory configuration as that is the maximum memory speed you’ll get access to B and H-series motherboards..
But when you factor in the platform and board cost, it's a bleaker picture for Intel. A decent Z490 board like the Tomahawk will set you back $190, whereas the B450 Tomahawk costs just $115 -- a $75 price disparity.
For Intel to compete in terms of value, it will need to drop the i5-10400 down to ~$150 and of course upcoming Intel B460 boards will have to prove their worth as well. Opening up memory overclocking would certainly help Intel’s case as well, this is something they absolutely need to do at this point.
Primer 2 :
The Core i5-10500 has the higher turbo frequency, but don’t forget this is Zen 2 vs Skylake, and Zen 2 has the higher IPC, so that turbo deficit in frequency might actually still be a win for AMD. The fact that the base frequency is in AMD’s favor considerably, plus the DDR4 support and PCIe support, means that the AMD chip is likely the option here. The i5-10400F is in a similar boat, but at least the deficits it does have come with a price reduction.
Sedaj pa najdi I5 10400F testiran na H410 Matični plošči...
Cene nemčija... pač ne gledam Slovenije...:
Procesor :
144€ Intel Core i5-10400F, 6C/12T, 2.90-4.30GHz, boxed (BX8070110400F)
180€ AMD Ryzen 5 3600, 6C/12T, 3.60-4.20GHz, boxed (100-100000031BOX)
Plosca :
110€ Gigabyte Z490M ne pričakuj da boš notri dal pozneje nextgen 11 ali K proc.
80€ Biostar B550MH
110€ Gigabyte B550M Aorus Pro : Če boš pozneje nadgradil na Zen 3
Da ko boš našel test i5 10400F na H410 matični pa bovo govorila o ceni. Jaz testa nisem našel...
10400F je in verjetno bo kar dober OEM deal za nezahtevne uporabnike. Zaenkrat skupaj s kakšno GRX 1650S, GTX 1660S ali RTX 2060.
Dokaj boljši od i5 9400F, ki je pariral zen+ ponudbi.
AapocalypseE ::
B-ju se stemni pred očmi, ko nekdo pohvali Intel omg.
Pa saj vidiš v videu kako se obnese proti 3600. Je lahko ram na 2.66GHz in je lepo na nivoju 3600 oz. še hitrejši zna bit.
Pa postaj še milijon linkov, če ti paše.
Ne govori tega!
Sem jaz to naredil pa sem bil kregan!
Vidim, ja.
Lepi se samo igre kot, da so najbolj pomembne. Ker kaj drugega se pa z računalnikom ne da početi.
Prav sitni ste že.
Prav sitni ste že.
mahone ::
Tukaj imaš 10400F testiran na 2.66GHz ram, proti 3600 3.2GHz ram.
Torej je možno sestavit poceni CPU, plato in rame pri Intelu.
Bo zdaj?
Z490 plate se začno pri 120€ . V to plato ZAGOTOVO ne boš pozneje usple dati 10600k ali še kaj drugega na K. Po drugi strani B550 plate se začno pri 70€ in za 120€ dobiš plato kamor zagotovo vtakneš tudi R7 5800X
R5 3600 pride 180€ I5 10400F pa pride 150€. Ne ni računice... F proc na ne Z490 plati, pa dela na .... no poglej teste kaj pomeni 2666...
my god
Kwa ti bluzis
Horas ::
pa sam teži z tto nezmžnostjo nadgrajevanja cpujev na matičnih. briga to vlko večino uporabnikov i5 non K! tisti ko kupi K kupi tudi Z plato.
8700k+z390, 32gb 3600mhz, 1080ti, 700w gold, 512gb+2x250gb m.2 nvme + 2tb hdd
8500+b360, 32gb 2666mhz, rx 6600, 600w bronze, 512gb+250gb ssd m.2 + 2tb hdd
Za nezahtevne uporabnike je i3 10100, ki je cca 105€ in je v bistvu i5 9400f.
Bo zdaj?
my god
Kwa ti bluzis
Glede na t , da nisi postregel z množico testov kombinacije H410 + i5 10400F , po vse vse o tvojih blodnjah.
- predlagal izbris: AapocalypseE ()
mahone ::
MSI Z490-A Pro dobis za 130€ in je med boljsim budget platam
https://geizhals.de/msi-z490-a-pro-7c75...
https://www.techspot.com/bestof/intel-z...
10700f te pride 290€ na MF
Pa imas super gaming system do DDR5
100x raje gledam dejanski gameplay kot pa napisane številke v grafih.
Ja, ker na 30 Hz youtube videju se ful vidi, kaka je igra na tistem hardveru.
KAVINSKY ::
Vidim, ja.
Prav sitni ste že.
In kaj se da početi z AMD, kar se ne da z Intel in obratno? Če delaš za hobi je popolnoma vseeno ali ti projekt rendira v 90, 85 ali 60 sekundah. Kot je skoraj vseeno če imaš 120 ali 132 fps.
Če delaš za denar pa verejtno tega ne boš počel na budget procesorju. V vsakem primeru kupiš za tisto kar rabiš. Razen če si tak, kot en naš znan član.
- spremenilo: KAVINSKY ()
klinker ::
Vidim, ja.
Prav sitni ste že.
Tej bi se tu pobili med sabo, zaradi 5% razlike v nekem benchu
 Vrtec
 Vrtec
i5 9400F je performančno res blizu i3 10100, malce boljši morda.
6c proti 4c/8t, realno same thing.
Nezahtevni uporabnik je relativna zadeva, zato sem napisal dober deal, ker bo čez obdobje še vedno sposoben vse po vrsti goniti nad 60FPS glede na cpu.
Praktično v slogu i7 8700(K).
Poznam pa folk, ki je obtičal na kakih starejših i5 procesorjih. i5 10400F je cenejši od takratne i5 ponudbe.
Še slikica kot referenca:
https://static.techspot.com/articles-in...
Določeni zahtevni uporabniki so/smo stavili na zen arhitekturo...
Zaenkrat kar dobro kaže.
Msi b550a pro dobis pa za 110€ https://geizhals.at/msi-b550-a-pro-a229...
in kaj si hotel povedat... da z490 plate niso tako drage ?
Preden zacnes s sanjami o ddr5 itd... najprej na intlovi strani najdi napisano da z490 podpira Pcie-Gen 4.
S tem da bos lahko nadgradil z490 le na 8 jedernika, ker novi gen intel zaradi izbolsanega ipc-ja ne more izdati i9 proca... bgebn 11 seveda...
AapocalypseE ::
What?!
Pomembne so številke zgoraj levo.
mahone ::
A res kaj pa 10900 nonk? smrdi? 10c/20t za 400€
Ti tolk ovinkaris, da me prov glava boli brati tvoje poste. AMD je cool, Intel je shit we get it.
Intelov i9 10900 (408€) je za čudne Intel fane, no joke. PL1 je slab v productivitiju, PL2 pa je naporna zadeva. Problem je tudi, da se potem raje vzame i7 10700K (339€) ali i9 10850K (439€), kjer je PL1 kar v redu, navijati pa v bistvu ne rabiš ali pa prefinjeno naviješ.
mahone ::
Ne rabis K modela sploh. Drgac pa kaj se dogaja s cenami 5000 serije? A niso nekaj govorili da bo vec kot dovolj zaloge?
AapocalypseE ::
Scalping Locust Swarm Takes Out Ryzen 5000 Inventory, Same Fate Awaits Radeon RX 6000
https://www.techpowerup.com/274397/scal...
Predator X ::
R5 5600x je malce hitrejši od 10700K v gamingu.
Funtech
R5 5600X 348€
i7 10700KF 390€
i7 10700K 415€
R7 3800X 360€
MT perf R5 5600X je kr na nivoju.
https://www.guru3d.com/articles_pages/a...
Da ne bi še koga prepričal, K modeli so malce dražji, ampak predvsem imajo optimiziran p/w pri PL1. Pri recimo i9 10900 lahko procesor uporabiš na dva načina. Pri PL1 bo porabil 65W in bo zadaj za cenejšim i7 10700K v igricah in večnitnih programih, če pa odkleneš porabo na PL2, pa bo pečka pila do 250W, kakor se ji bo zazdelo. Če se kakšnemu gimcu da s tem jajcat nekaj let, tudi dobro.
Ne moraš pa si zmišljevat, da bi imel kak PL1.5. Ali PL1 ali PL2.
Če se bo kdo z i9 10900 na desktopu zdel sam sebi pameten "kolko je prišparal" pri trenutnih cenah, potem bo šlo za čudnega intel fana.
- spremenil: Jarno ()
Wrop ::
Skalpa tudi Mimovrste. 5600X za 402 €. Za to ceno dobiš 3900X pri Mindfactory. Že 300 € je veliko, 400 €?, pa kje ti živijo?
Predator X ::
No 10600K za 274€ res zgleda vredu in samo v gamingu (ker je dovolj hiter za 144HZ gaming)
Če pa primerjamo :
MT - 1460p vs 1900p (R5 5600X) vs 2020p (i7 1070K)
No o STju sploh nerabim govorit.
Nevem zakaj cenovno primerjajo nekateri 10600K z R5 5600X?
25-30% razlike v MTju in ST-ju
Razlika v ceni pa je 27% .... sepravi, če daš več .... dobiš več.
Če pa primerjamo :
AapocalypseE ::
Imamo tudi 10600KF, ki je še cenejši.
AMD vs. Intel
AMD vs. Intel
- spremenil: AapocalypseE ()
KAVINSKY ::
V isti sapi se hvali AMDjeve 6/12 jedernike, češ da so več kot dovolj, po drugi strani pa je 8/16 premalo.
10400f je še eden redkih intel procesorjev, kateri je smoteren nakup. Že z počasnejšim spominom konkurira 3600. Kar prihraniš pri procesorju pa lahko porabiš za z490 matično in si na isti ceni kot pri AMD kompletu. Na neko ceneno B450 matično pa verjetno tudi ne boš tlačil kaj več kot 8 jeder, še posebej pri trenutnih cenah nove generacije.
V roku par let se bo verjetno kaj dobilo na bolhi, takrat pa vprašanje kaj bo aktualnega na trgu.
Če gejmaš so že 4 jedra itak vrh glave, itak je poudarek na single thread performance. Tistih par procentov, ki dejansko počnejo kaj pametnega na kompih, tisti pa kar naj kupujejo 8 jedrnike.
Vuli ::
kaj se dogaja pa z MSI-jem. Prvo je CEO zletu skozi okno, zdej pa še fabrka zgorela.
https://www.tweaktown.com/news/76113/ms...
klinker ::
Ti zivis v letu 2010? 4 jedra so ze zdavnaj mimo, tudi v gamingu. 4/8 je minimum, 6/12 danasnji optimum p/p, 8/16 future proof.
Intela vec ne jebe cena, ampak poraba, ki je pri boljsih modelih ze bolana.
Pa trenutne cene Ryzenov 5xxx v trgovinah ne jemljite resno. To so trgovci navili vse v 3pm, ker je zaloga z en drek. Ce se mene vprasa, dogovor med Nvidio in AMDjem da se napihnejo cene in Intela malo po usesih, ki je isto pocel se pred kratkim.
AapocalypseE ::
AMD Ryzen 5000 Processors Allegedly Work With 300 Series Motherboards
https://www.techpowerup.com/274400/amd-...
Wrop ::
4 jedra samo za igre in res za tiste s plitko denarnico. Ostalo je no go.
Novejše igre že sedaj obremenijo 4 jedrnike na 80+ %. Kaj šele bo.
AapocalypseE ::
Dajte napisat točno koliko jeder in niti.
4/4 je no go.
4/8 je ok.
4/8 je čisti minimum za igre.
4/4 je no go.
4/8 je ok.
Horas ::
pa vseeno če nisi nek štefan al jože iz bogu za hrbtom, ne boš kupval i3 al r3. ampak vsaj i5 ane .
Wrop ::
4/8 vsekakor. Takega kupiš, če hočeš res minimizirati ceno CPU in prihranek, vsaj del, dati v GPU. Vsekakor z mislijo, da bo treba kmalu nadgraditi.
Ali pa 6/6, če recimo uvoziš 3500X.
R5 3500X zna biti zavajajoč procesor, ki je performančno med r3 3100 in r3 3300x.
Težava je tudi v tem, da so lahko na enem CCX-su hkrati aktivne največ 3 niti in je zato precej počasne komunikacije med jedri iz drugega CCX-sa.
R3 3300X (120$ MSRP) lahko na enem CCX-su naenkrat poganja vseh svojih 8 niti, počasne komunikacije med jedri ni.
Sicer je R5 3500X (157$ MSRP) tam tam z R5 2600X, tako, da v precej scenarijih ni tako slab.
To bi se pa res moralo počakati 3 mesece in pol bi se jim lahko prah nabiral na škatlah.
Horas ::
sreča da mamo take kot je jarno
Čudeži se ne dogajajo, žal.
Je pa zen3 arhitektura skoraj brez tovrstnega "drobnega tiska".
klinker ::
Horas ::
klinker jaz nisem nek debater, povem kak stavek dva to je to. zato sem pa napisal ker rad berem jarna in še koga podobnega kak sentinel ko se pojavi, pa da ne pozabim Darwina
- spremenil: Horas ()
Tak za komentar, stare zene je blo treba včasih v hrib porivat in študirat, zdaj pa je že na raketni pogon.
Na police so poslali veliko procesorjev, a so jih razgrabili:
https://www.pcgamer.com/uk/amd-zen-3-ry...
