AMD ZEN - nova X86 Jedra
mahone ::
Predator X je izjavil:
Odkrijta še toplo vodo.
Dobr se ve, da ima ryzen problem z latenco DRAMA. IMC je kull, jedro prav tako. Me res zanima kolk bi bil hiter i7 8700K, če bi mu dal 70-80ns latence.
Dokler ima NB na 3,7-4,3GHz je kr hitr ja.
Ne i7 8700K ni vreden svojega denarja, ker če naviješ R5 1600 170EUR na 3,8GHz ter daš hiter ram 2933MHz+ in GTX 1080Ti imaš super kombo. Če igraš starejše špile in ti pomeni samo ST imaš pa i3 8350K za 170EUR.
A se hecas? A se zavedas da Ryzen 7 bottlenecka 1080ti?
Heavy ::
mahone je izjavil:
Odvisno od igre in resolucije. Recimo glej test Doom in GTA V.
http://www.ign.com/boards/threads/intel...
#TeamFelix
karl ::
Heavy je izjavil:
LOL, z višjo resolucijo dosežeš rob zmogljivosti grafe ne procesorja. To bo jok in krik pri 2080ti, ko bo Ryzen na koncu repa pri 4K :D Conspiracy!!!
Predator X ::
mahone je izjavil:
Ta tvoj bottleneck je čist relativen.
Tud i7 8700K bo bottleneckal.
karl je izjavil:
Heavy je izjavil:
Aja, i7 8700K bo pa čudežno lahko normalno poganjal?
Predator X ::
Master_Yoda ::
karl je izjavil:
Heavy je izjavil:
Tega posta ne razumem: Zakaj bi Ryzen pogrnil pri 4K, ce smo ugotovili da z visjo resolucijo dosezes rob zmogljivosti grafe in ne CPUja ?
Because....muh Intel.
mahone ::
http://www.legitreviews.com/cpu-bottlen...
Deus EX - MD
It looks like the AMD Ryzen 7 1700 processor at 4GHz on all cores is actually bottlenecking the platform and therefore we get no performance scaling whatsoever by moving up to a GeForce GTX 1080 Ti FE graphics card.
GTA V
This is yet another game title that shows the new GeForce GTX 1080 Ti and even the GeForce GTX 1080 can be bottlenecked to some degree by the processor. In fact, it looks like we are actually CPU-bound or CPU-limited at both 1080P and now even 1440P with the Ryzen 7 series processor. The Intel Core i7-7700K doesn't appear to have any major CPU limitations at 1440P or at least very minor.
Pa ne pozabit, da je AMD ob launchu R7 zelel od reviewerjev, da testirajo cpuje na visji resoluciji.
AMD's response to Ryzen's sub-par 1080p showing is to encourage reviewers and users to test at higher resolutions,
http://www.eurogamer.net/articles/digit...
Zdaj si pa predstavljaj, kupis ryzen 7 1700x ob launchu za skoraj $400 z namenom, da ga bos uporabljal vsaj 5 let pa ti bo cez 2 leti ze bottlenecku najnovesji gpu ;((
gddr85 ::
a to je bilo še pred meltdown/spectre? dober je bil tale 7700k..:))
TOP ::
gddr85 je izjavil:
V igrah ni razlike.
filip007 ::
Že spet AMD cvetke, potem je Core i3 8100 boljši kot R3 1200 za 1080p. Še bolje bo, ko bo Intel naredil nove popravljene varnostne revizije CPUjev.
Zero games, zero talk.
Truga ::
spekter/meltdown arch fixa ne bo se vsaj ene 3-4 leta.
filip007 ::
Rečeno je bilo še letos.
https://wccftech.com/intel-hardware-cha...
TOP je izjavil:
gddr85 je izjavil:
V igrah ni razlike.
To je zato, ker sploh ni nič še popravljeno.
Meltdowna se še dotaknili niso (in popoln popravek tudi ni mogoč).
TOP ::
Ja ma kaj razumeš kaj ti pravim,da na igre ne upliva tale nepaka,kar se tiče fsp toliko kot si jih prej imel.jih maš tudi sedaj,pozna pa se če uporabljaš za virtualno mašino potem tam se pozna napram prej.
_koki_ ::
filip007 je izjavil:
Intel je za to vedel še pred izdajo 8xxx serije, pa so kljub vsemu izdali "defektne" procesorje, ker si niso mogli privoščit da bi jim konkurenca odžrla cel mainstream ter server market, glede na to da so te zadeve prišle v javnost več kot 3 mesece kasneje!
Truga ::
V manj kot letu bojo popravili arhitekturo? Hahaha, koga zafrkavas. Od dezajna arhitekture do trga traja 3-5 let. Intel bi mogoce lahko stisnil to na 2 leti ker imajo svoje fabse in lahko hitreje prototipirajo. Dvomim, sicer.
Isotropic ::
to ni celotna nova arhitektura
bi pa verjetno res trajalo kakšne 2-3 leta, da bi naredili proper hw bugfix.
_koki_ ::
Definitivno bi to na hw bazi zrihtali prej kot v pol leta, namesto da flikajo že pol leta na sw bazi, pa niso niti na pol poti! Ampak si enostavno niso mogli privoščit, da bi se ryzni prodajali leto dni brez njihovega odgovora "defektnih" procesorjev!
TOP je izjavil:
Za 100% odpravo meltdown ranljivosti bi bilo potrebno v celoti izklopiti medpomnilnik. Kaj bi pa to pomenilo za tvoj preljubi FPS?
Sploh pa: še za vse "popravke", ki so jih sedaj izdali, se je izkazalo, da ranljivosti sploh ne odpravijo.
Je treba videti, kaj so zdaj nazadnje sploh naštrikali.
_koki_ je izjavil:
V pol leta?
Če bi se to dalo (pa se ne da) bi oni to storili.
Še enkrat: če bi se to dejansko dalo tako hitro rešiti bi rešili. Tako pa ne gre to tako hitro.
V enem letu ne rečem (take so tudi informacije na internetu). V pol leta pa ni osnovnih pogojev.
  • spremenilo: FireSnake ()
TOP ::
Mater kake se eni ukvarjaste stem meltdownom kot da je nočna mora jaz ne vidim v igrah prav nobene razlike.Pa tudi testi na spletu so pokazali.In zakaj bi moral sklopit medpomnilnik,če mi ga ne rabi.
Vidim, da si si zelo podrobno prebral.
A meltdown ti ne naredi razlike v (pazi) igrah? Bejž no, bejž. Kako to? Daj, razloži nam to.
Kake teste si ti našel za meltdown? Sprašujem, ker se peteliniš glede stvari o katerih, več kot očitno, nimaš pojma.
Čakamo...
TOP ::
Jao ti jih maš sigurno into res rabiš,zato pa nonstop omenjaš,kot da te motijo čeprav nimaš Intela.In če se ne motim smo v temi AMD,tak oda bi morali rajši se ukvarjat stem kaj bo novega izdal AMD,ker nova revizija ni prinesla nekaj velikega,kar se tiče same zmogljivosti proca.
Nisi mi odgovoril na vprašanje!
Namenoma ali ne znaš?
zekolaro ::
seveda ne zna!
blodnje...
gremo dalje
Če jim tole rata pa kapo dol:
AMD's Ryzen 2 chips could finally take the gaming crown from Intel's Core processors
Ne gre se toliko za gamerje (čeprav so zelo glasni hence echo efekt) ampak je dejansko še veliko (preveč) programov, kjer je single core performance še vedno pomemben.
Jaz sem tako mnenja, da so Ryzeni že zdaj več, kot konkurenčni. Napoved je povsem verjetna, če gledamo kako stvari tečejo.
zekolaro ::
lepe napovedi, ampak vprašanje kaj bo pokazala realnost
prvi ryzen se je na trgu lepo prijel in sigurno se bo tudi prihajajoči
na realnih tleh je vsak današnji in tudi malo navit stari 6- jedrnik več kot dovolj še za nekaj let
zekolaro je izjavil:
Se strinjam. S tem, bi naslednik znal imeti manj težav (predvsem s popravki v OSu), ker je pot že tlakovana.
Tudi res. Vsak se sam odloči, če bo nadgradil.
Enim paše več zmogljivosti in še vedno tih računalnik.
Iz tega razloga sem si včasih lastil 4790K (pa sploh ni bilo potrebe po navijanju, zadeva je letela).
zekolaro ::
sam sem imel i7 920, i7 980x, 3770k, 4770k, 4790k in sedaj 8700k...vse od lepo navitega i7 920 do današnjega 8700k praktično ni bilo potrebe menjat, ker je vse epo delovalo brez zatikanj
kar se pa ryzenov tiče pa glede na napovedi ne bo ravno odveč zamenjat, ker se bo poznal napredek - glede na napovedi
ampak ja, realnost bo pokazala pri izidu, kater je na žalost vedno enak za amd - najprej polno težav po nekem času se pa stvar šele pokaže kot se mora
Predator X ::
FireSnake je izjavil:
No way.
Nima šanse, da znižajo latenco DRAMA za toliko. To je tisto kar ubije ZEN jedra (če govorimo o gaming mašini).
Seveda, ti že veš. Več, kot vsi drugi mediji.
Drugič bomo tebe vprašali.... NOT :))
Predator X ::
Več vem?
Zakaj zelo rad napihuješ AMD?
Če pogledaš primer i7 4770/90K napram i7 6700K, kjer je bil kljub IPC izboljšavam i7 6700K počasnejši. Samo zaradi latence DRAMA.
Kaj že napihujem? Konkretno, prosim!
In seveda, samo zaradi latenc je to bilo. Ker arhitektura je tudi ista, ane?
Še ni dovolj tega otroškega vrtca?
Predator X ::
Konkretno, da bo AMD proc hitrejši od Intela v gamingu.
Trenutno je takole :(dejstva)
- DDR4 latenca je glavni problem Ryzena pri gamingu. Ta problem nastane zaradi IF-ja, ki ima zelo nizko frekvenco
Sledi:
- Glede na odgovor/potrditev AMDJa : Ryzen arhitektura ima IF (NB) hard-linked to IMC
- 2400MHz DDR4 (IF 1200MHz) = ~95-100ns (AIDA 64)
- Tudi če to dosti izboljšajo bi nekak v najboljšem primeru videl pri tej frekvenci okoli 85-90ns (AIDA 64)
- Intel ima NB na 3,2-3,7-4,3GHz (CoffeeLake) in tudi pri počasnem ramu samo 50-60ns.
Tud, če izboljšaš IPC (pridobiš dobiš na STju), ampak kot si videl je še bolj imet pri ryzenu 3,6GHz ter DDR4 3466MHz kot pa 4,1GHz ter 2666MHz vsaj za gaming.
Primer
Zdej mi pa ti konkretno obrazloži tole:
Kako bo AMD veliko zmanjšal latenco DRAM brez velikih sspremem Ryzen arhitekture?
Mogoče IF clock 2:1 IMC clock? Pa bo IF laufal na 3000MHz+?
PS: Pa ne nekega otročjega odgovora.
Zato pa ima Ryzen konkretno zajeten kos L3 cacha, z razlogom.
Problem so tudi frekvence delovanja procesorja in ipc, ki daje intelu tistih 20% prednosti.
Seveda ima Intel (če odmislimo meltdown) caching bolje implementiran, saj gre za dolgo razvojno pot med core 2x00 in 8x00.
Potem pa je še tukaj AVX in če se optimizira za Intel, potem se spet pojavi razkorak.
The problem is that while intel "core" has two avx 256 units that can do both add and mul each, amd has split units, two can do only add and two only mul so in avx 256 mode one joined add and one joined mul, thus half the speed when the code isnt hand-optimized.
Kot si povedal, hitrejši pomnilnik Ryzenu zelo pomaga, ampak bi frekvence prav tako prinesle boost.
Ne pozabimo, cache miss situacija je malo verjetna...sekvenčne pomnilniške hitrosti Ryzna pa kar velike.
Predator X ::
Desktop coffeelake LGA 1151 ne podpira teh inštrukcij.
https://www.pugetsystems.com/labs/hpc/S...
Ne omenja se AVX 512, ampak razlike med AVX2 ("AVX 256").
Za AMD bi se moralo ročno optimizirati zgleda, da bi bila zadeva enako hitra kot na core arhitekturi.
Kompatibilno pa je vseeno.
AVX512 nekako ne paše v TDP 65/95W shemo, ker je zadeva pri višjih frekvencah dokaj potratna, vsaj pri Intelu.
Predator X ::
Jarno je izjavil:
Sej si videl te benchmarke.
Predator X ::
https://www.anandtech.com/show/11550/th...
glej corona AVX512 vs AVX 256 vs AVX 128
Videl, videl.
Deda straši...verjetno kaj pametnega počne s svojim pc-jem.
Naša realnost pa je bolj takšna...
 30 game battle.
30 game battle.
Merjenje ticev preneseno v gaming svet.
  • predlagal izbris: Jarno ()
Isotropic ::
ryzen+, ryzen 2 ali kako se zdaj imenuje, bo imel večji cache associativity
Citiraj me. V nasprotnem primeru STFU.
Čakam.
Predator X ::
Meh. Otrok en.
Predator X ::
tukaj je primer trenutne AVX 512 optimizacije
Meh. Otrok en.
Polagal si mi besede v usta, zakaj se zdaj delaš neumnega (še bolj, kot je potrebno)?
Predator X ::
Sebe raje to vprašaj. Nonstop ti že govorim, da IPC ali splošno ST ni tisti glavni faktor za ŠPILE pri ryzenu. IF je main bottleneck. Tud če bi zdej naredil izboljšavo 15% IPC nebi prav dosti pomagalo, če bo IF pri 2400MT/s ali 2133MT/s DDR4 samo pri frekvenci 1200/1066MHz.
Imaš slučajno ryzena?
IF težko doseže 2000MHz tud če bi IMC še višje kot gre sedaj bi se ustavil pri ~2000MHz @ IMC/IF
Priznam, Intel ima eno veliko prednost ... v javnost je dal bore malo informacij o prejšnjem ring busu in sedajšnji mesh tehnolgoiji, tako da razni forumaši ne morejo pametovati o tem :)
Predator X ::
pegasus je izjavil:
Sej so naredil test latence na pcper.
Skratka ring bus in mesh sta med jedri. NB dela za ram. IF dela vse.
