Ukrajina Part II
Ukrajina Part II
korenje3 je izjavil:
MojaDežela je izjavil:
v dnevniku: posnetek: ruska vojska strelja na protestnike zarad okupacije v Zaporožju...kdo je zdaj nacist?
propaganda. Uporabili so solzivec, ker so zborovanja v vojnem času prepovedana.
To je bila tudi provokacija zahoda?
PrimoZ_ ::
Še raje pa imam ko Rus beži, ko mu tank gori.
MojaDežela ::
Niti enega dokaza ni, da so rusi ubijal civiiste. Niti enega posnetka.
Ohjej.
Tudi, 18+, fotografije trupel in množičnega grobišča.
https://twitter.com/Neo_Right_UA/status...
https://defence-ua.com/minds_and_ideas/...
These include Puma drones and laser-guided missile systems. And even people far from the military may have a question: why the United States is handing over drones to Ukraine, the Ukrainian Armed Forces allegedly do not feel the lack of them. But Puma has one extremely important feature.
However, the main thing is really in the details. Namely - a suspended electron-optical system - Mantis i45. This system, both in the daytime and thermal imaging versions, is equipped with a laser illuminator.
It makes it possible to use the most common type of high-precision weapons in the United States - missiles that use guided laser beams.
But now the only UAV with such a system in the service of the Armed Forces - Bayraktar TB2. Therefore, the appearance of an additional drone "lower" level is not superfluous. Especially since laser-guided missiles are also going to be delivered to Ukraine in the same aid package.
It should be emphasized at once that the US Department of Defense has not named a specific system of missile weapons with laser guidance. The original document used the term Laser-guided rocket systems.
And for the definition of weapons, most likely, the key word should be rocket , because it severely limits the list of weapons. Because most of the missiles we are used to in the United States use the term missile. For example, the Hellfire II rocket is a missile.
But the unguided Hydra 70 rocket is already a rocket. And the only program to convert NURS into a laser-guided missile system is the AGR-20 Advanced Precision Kill Weapon System (APKWS) from BAE Systems.
But it should be noted at once that APKWS in practice was actively used only from air platforms - aircraft and helicopters. Its integration into Ukrainian aircraft is quite a difficult task.
However, in 2020, BAE conducted a series of successful experiments with the launch of APKWS from terrestrial platforms.
The result is a rather interesting ground-based high-precision ground-to-ground system.
Therefore, as one of the options, Ukraine may become the first baptism of fire of this system in a real battlefield.
torej ni čudno da rusi bežijo ko kure brez glave iz severnega dela UA...to so neke vrste AIRTERMINATORBOMB...
PrimoZ_ je izjavil:
Jaz imam rad korenje.
Skoraj vsak dan pojem enega svežega.
Zdaj si mi pa dal idejo. Jutri bom pripravil rižoto z naribanim korenjem.
PrimoZ_ ::
Seveda!
Deloval je proti Rusiji... Putin je tako rekel.
APKWS je kit, ki se pritrdi na obstoječe rakete, podobno kot JDAM. Genialen pristop, kar se mene tiče.
Advanced Precision Kill Weapon System @ Wikipedia
MojaDežela ::
PrimoZ_ je izjavil:
--pri nas če gori avto ne bežimo ampak (odklopimo akumulator če je možno) GASIMO!
MojaDežela ::
PrimoZ_ je izjavil:
pa zmeraj eno korenje ostane-hehe
mackilla je izjavil:
PrimoZ_ je izjavil:
--samo da ni ruski BORŠČ.
PrimoZ_ ::
Zdej jemo ukrajinskega
Poldi112 je izjavil:
Pa si ti sploh prebral kdaj so bile te vojne?!
Seveda - povsem na začetku kitajskega padca, po tisočletjih dominacije, nakar je sledilo obdobje, ki mu danes pravijo stoletje ponižanja. In potem so imeli še 20 let brutalnih sankcij, nato pa je končno prišlo obdobje, ki je kapital končno premagal ameriški ideološki boj pred komunizmom ter se smel vrniti na kitajsko.
Zate je očitno relevanten zgolj ta povsem zadnji del, ko naj bi zahod "pomagal kitajcem".
Dej pomiri si, za zacetek si preberi kaj jo vojnah med Japonsko in Kitajsko, da se ne bos smesil, da so revezi imelu nadesetie mrtvih, ker so bili na zavezniski strani med drugo svetovno vojno.
V-i-p ::
PrimoZ_ je izjavil:
Daj, naj te nekdo že blokira. Dosadan si s tem, sorry.
MojaDežela ::
Danes okrog 10.10 na autocesti A3 na Hrvaškem -Kutina prišlo do požara tovornjaka ki je prevažal devet automobilov. Policija pravi da je do požara prišlo zaradi predrtja pneumatike na priključnem vozilu, zarad tega je pršlo do trenja kolesa ob asfalt. V požaru so zgorela vsa vozila katera so bila naložena na tovornjaku slovenskih registerskih tablic.
--no, pri nas gorijo avti v UA pa tanki.
V-i-p je izjavil:
PrimoZ_ je izjavil:
-- oziroma: kar lahko narediš danes naredi le polovico, polovico pusti za jutri, oz. če ni nujno za pojutri....
Ukrajinci zajeli KA52
Enkrat za spremembo ne z nevodenimi raketami, ampak z lasersko vedenimi Vikhri, ki so razmeroma solidno protioklepno orozje.
PrimoZ_ ::
V-i-p je izjavil:
PrimoZ_ je izjavil:
Tank gori, Rus beži!
Hvala, hvala.
Andy9 ::
Ali se kaj pripravlja?
Gledam na Flightradarju. Vsa Nato letala, ki se vseskozi nahajajo ob Moldaviji in Ukrajini imajo kar naenkrat ugasnjene sledilce.
Andy9 je izjavil:
Prihajajo pošiljke orožja?
Še kdo zagovarja Ruse?
New Srebrenica. The Ukrainian city of Bucha was in the hands of ?? animals for several weeks. *Local civillians were being executed arbitrarily*, some with hands tied behind their backs, their bodies scattered in the streets of the city.
https://twitter.com/DefenceU/status/151...
PrimoZ_ ::
Vpras korenje3, ti bo povedal da Rusi uporabljajo lisice, tak d to so se ljudje sami zvezali in pobili...
  • spremenilo: PrimoZ_ ()
Andy9 je izjavil:
Možno, dans so vojaška letala vozila iz UK do Poljske, vsak tak je Flightradar kazal.
To izgleda srhljivo.
:D
https://twitter.com/iAmTheWarax/status/...
starting a non profit that buys plane tickets for online authoritarianism stans to the ruthless dictatorship of their choice on the condition that they enlist in their preferred ruthless dictatorship's utterly shitty army
Ukrajinski hujskaci 100-tic
https://www.zurnal24.si/svet/nevarno-se...
IL_DIAVOLO je izjavil:
Zaključujemo vojaške vaje.
Lp, Putler
Voss ::
tikitoki je izjavil:
And just like in #Srebrenica (many) western European countries r accessories to this mass murder. They cuddled Slobodan Milošević in the 90's & they are cuddling Putin now.They prevented Bosnians from arming themselves then &they r doing the same now.SHAME
IgorCardanof ::
endelin je izjavil:
Lp, Putler
Putin bo napadu moldavijo, pa potem se stepu še z Japonsko za tiste otoke. Pa failal povsod :D
Dvomim da si lahko privošči kakršnokoli novo vojaško operacijo.
Ne odgovarjam na DM.
NATO Commander Increases Prediction to 550 F-35s in Europe by 2030
https://www.airforcemag.com/nato-comman...
Verjetno bo številka na koncu blizu 650 (Španija in Portugalska). Verjetno bo pa končna številka preko 1000 bojnih letal samo v Evropi. Pa potem še 2500 s strani ZDA...
strawman ::
Kdaj pričakujemo, da Rusija zapre meje in dovoli izhod le z začasnimi delavskimi vizami?
Po nekaterih ocenah je Rusijo zapustilo že 70k+ IT-jevcev, v tem mesecu pa naj bi jih odšlo še 100k, sploh če se EU zgane pri lažjem podeljevanju viz.
Vseh skupaj naj bi bilo v Rusiji leta 2020 nekaj čez 1,2M IT-jevcev.
coffeetime12 ::
RF je v enem zamahu odvzela 30% globalne vrednosti dolarju in evru. Indija, Pakistan, Kitajska, celoten globalni Jug nima pripomb. Ursula in Joe lahko tiskata cekine do onemoglosti, pa vendar ne bo šlo. Veter piha iz vzhoda. Mimogrede, je kakšen ruski tank obtičal v blatu? Vprašanje za Pacmana
PrimoZ_ ::
Upam da živiš nekje v tem ruskem raju :)
Pa hitro nastavi ramico, da te cepimo.
stratosD ::
NKFRZ aka Roman youtuber poroča da je v Gruziji (Tbilisi) najmanj 50k Rusov, cene najemnih stanovanj x 2 v enem mesecu
V Bakuju(Azerbajdžan) tudi par 10 tisoč, v glavnem ta bolj navadni srednji razred potuje/leti v te bivše sovjetske republike za kamor ne rabijo vize...z vlakom ki nehal voziti Moskva - Helsinki pred kakim tednom vsaj 700 ljudi dnevno...
Iber bogati pa v Dubaj, kupujejo po več stanovanj, plačilo tudi v zlatu... pa še bogve kam vse bežijo kamor lahko.
Še malo pogled z druge strani - ITA
Bruno Vespa @ Wikipedia
Bruno Vespa ima že več ko 25 let ene 4x tedensko pogovorno oddajo Porta a porta /Door to Door.
Zadnje cajte vedno pokliče koga v Moskvo, Italijane ki imajo tam kako pizzerio, odvetnike ki Rusom prodajajo luksuzne vile na Sardegni etc..
Zadnjič je poklical ta rusko-italijanski duo Bacio ki deluje v Moskvi.
Zgleda je zdaj mantra na Rossiya 1 in Rossiya 2 TV da je Putler napadel preventivno - ker bi itak Ukrajinci napadli zdaj zdaj..
Tudi nepremičninski odvetnik je naslednji dan gonil isto o preventivnem napadu....seveda je imel v studiu tudi begunko ki je pred par dnevi prišla iz Mariupolija...
"Putin made a preventive invasion because Ukraine was ready to strike"
https://twitter.com/grande_flagello/sta...
coffeetime12 je izjavil:
Če si morda spregledal, še enkrat. Tole bo zate. Edino odločit se moraš, Rusija ali Kitajska?
Programu pravijo Tickets for Tankies. :D
coffeetime12 ::
LOL, Hevka
Rusi v vsem svojem sijaju...
https://siol.net/digisvet/novice/grozlj...
korenje3 ::
BorutO je izjavil:
Je razlika, če to delaš na svojem ozemlju ali pa če to delaš v drugi državi. Kaj bi rekli američani, če bi Rusija proizvajala biološko in kemično orožje ma meji z ZDA?
Že ko so rusi poslali svoje vojake v venezuelo, da zaščitijo državo pred ZDA, so začel cvilit na ves glas.
Se pravi, da Rusi priznavajo, da je vojna? Ali so pa zborovanja prepovedana tudi v času "specialnih vojaških operacij"? No, v vsakem primeru, prepričan sem da znajo Rusi vedno najti člen po katerem so zborovanja prepovedana.
Evo, ze tretja nedelja od napovedi, da bo Mariupol padel cez dva dni. Kako kaze? Samo sto nije? In ta joke od vojske bi se lotil Kijeva?
Glede oborozevanja civilistov - ce bi civilisti severno od Kijeva pravocasno dobili kalasnikove, danes zagotovo ne bi gledali slik masovnih usmrtitev...
vaščan ::
Dejansko sploh noben točno ne ve zakaj se gre razen ljudi ki živijo tam pa še ti se vrjetno mal praskajo wtf. Mediji pa vsak v svojo stran nabijajo in zavajajo folk. Eni za ruse eni kontra. Kakor je vojna žalostna in neumna reč je smešno kako se bije vojna v medijih kako čim več ljudi prepričat kdo je angelček kdo hudič. Obsojam kakršnokoli vojno ter putina sem pa mnenja da ukrajinci niso ravno nedolžne ovčke. Ter zanimivo kako francoz anglež nemc američan igra rezervnega jezusa nedolgo nazaj so taisti imeli vojne ter sužnjili ljudi zdej bi pa cel svet komandiral kaj je prav in kaj ne. To so igre za oblast in dnar common folk je pa potrošna roba vse nebuloze o tem kdo bi rad komu pomagal so pravljice za rajo mogoče kakšne bolj umsko revne celo tolk napumpajo da prime za orožje bolano.
  • spremenilo: vaščan ()
vaščan je izjavil:
Ni neke hude filozofije, kdo je tu bad guy. Rusi so napadli suvereno drzavo Ukrajino, ne obratno. Za vso klanje so direktno ali indirektno odgovorni ruski fasisticni barbari.
AtaŠtumf ::
En video za Pac-Mana:
TLDR po PrimoZ_evo: Tank se kaže, Ukrajina verjetno laže!
Pa še za vse ostale:
krucymucy ::
yansek je izjavil:
Še nekaj o naravnih bogastvih Ukrajine
Ukraine Sits On Raw Materials Worth Trillions. The Country's Chance for Reconstruction?
Obnovo Ukrajine bo krila Rusija. Odskodnine bodo visoke, precej ogljikovodikov bodo morali prodati samo za obnovo Ukrajine.
Ukrajina bo prosperiala, Rusija bo pac ostala shithole. Velika a nerelevantna.
BorutO je izjavil:
Saj ti je menda jasno,da noben nebi imel laboratorijev v državi kjer je možnost ruskega napada največja? To je tako kot,da bi Američani postavili tovarno F35 v Ukrajini na meji z Rusijo. Kje tu vidiš logiko?
TezkoDihanje ::
AtaŠtumf je izjavil:
Ta video sem jaz videl takoj ko je ven prišel. Hvala lepa za nič.
Ne, se ne.
Imamo tukaj zbirko:
https://www.oryxspioenkop.com/2022/02/a...
PS: Glede ugotavljanje duplikatov/geolokacij etc je Oryx cca 200-300 ruskih vozil odzadaj.
Motion ::
Aston_11 je izjavil:
PrimoZ_ je izjavil:
Ne vem a to izhaja iz čustev, kot posledica zahodne lažnive propagande, ali ste psihopati?
Ti podpiraš rusko agresijo.
Povej kaj te žene, psihična bolezen, denar,...?
dej že nehi psihopat.
8 let si bil tiho, ko so nacisti klali ljudi iz donbasa, ki niso hotel več živet v tej državi.
vse zato, ker so jim rusi zaprl pipico ker so kradli plin.
do leta 2021 rusi niso imeli nič z ukrajino, razen tega da so skrbeli za 1,5 milijona beguncev iz donbasa.
In sedej po 8 letih ste psihopati ugotovili, da so pokoli Ok, ker so tudi drugi to delali?
Rusi so 8 let opozarjal zahod na kriminal, ki ga ukrajina izvaja na tem območju, pa ni bilo odziva. To je bilo že vsaj 100x javno povedano.
Rusom je prekipelo zaradi vse te ignorance zahoda.
Sej so bli oboroženi civilisti, ki so streljali na ukrajince. Lahko bi odložili orožje pa se zmeli za mizo. Tako so se pa upirali. A rusi čečenom so dovolili odcepitev?
TezkoDihanje ::
Rusi so 8 let opozarjal zahod na kriminal, ki ga ukrajina izvaja na tem območju, pa ni bilo odziva. To je bilo že vsaj 100x javno povedano.Rusom je prekipelo zaradi vse te ignorance zahoda.
Obstreljevali so se oboji.
To je statistika civilnih žrtev skozi leta:
Iz leta v leto je padala.
TezkoDihanje ::
https://twitter.com/kemal_115/status/15...
The first Russian 1L262E Rtut-BM EW system lost in the war in Ukraine!
The system can be categorized as an "anti-artillery EW" asset, for its main tasks are to suppress enemy communications, jam enemy guided-munitions, and incoming radio-proximity fuses.
Notnow ::
Comandante je izjavil:
Tole je pa med top 5 butastimi komentarji tle...A si že slišal kdaj za it takes two to tango?
TezkoDihanje ::
Notnow je izjavil:
A če jaz pridem v tvojo bajto, pa te na gobec. Boš ti naredil kaj?
Two to tango?? WTF si zabit. ;((
Notnow ::
TezkoDihanje je izjavil:
HAhaha kake cifre so to,to morš bit mal zaostal da to vrjameš :D 18 mrtvih? 50? daj no...lol...
TezkoDihanje ::
Notnow je izjavil:
A so te že spet Rusi nasrali??
OHCHR
https://www.ohchr.org/en/ohchr_homepage
Notnow ::
Notnow je izjavil:
haha jajaja kr tak mal so to nardil seveda..en jutr se je putin zbudu pa reku gremo akcija jl...
a ko se z babnco doma kregaš,je vedno tisti kriv ko je prvi sprožu pogovor?
A ko se otroc stepejo doma,je samo vprašanje kdo je začel in on bo potem kriv za vse?
Pa kaj ste to 14 let star al 60 pa seniln...
647 / 859
