Ukrajina Part II
Ukrajina Part II
redo ::
Cepimose je izjavil:
Napočil je čas, da se tele rusofile prijavi zaradi sovražnega govora, pa da vidimo.
Mislim, da je bolj čas, da se jih pošlje nazaj, od koder so prišli. So praviloma glasni, kako Sirci ne delijo naših vrednot in jih je treba zato poslati nazaj. Putinovi ritolizniki tudi ne delijo naših vrednot, naj izvolijo nazaj.
Ni važno kaj misli Evropa, vazno je kaj mislijo zatirani Rusi v Ukrajini. Umorjeni itak ne morejo vec.
redo ::
A ne Putin "čisti" svoje vrste?
TezkoDihanje ::
IL_DIAVOLO je izjavil:
Vidimo v Mariupolu, kako gre zatiranim Rusom. Predstavljajo polovico prebivalstva, pa po treh tednih Ukrajinci še vedno držijo mesto. Ta fama, da se je Rusom godila strašna krivica je budalija na nivoju srbske matice na Hrvaškem leta 1991. Zakaj vam je treba to sploh razlagat??
VladarP ::
🇷🇺🇺🇦⚡ Russian ministry of defence:
▪️During the night, operational-tactical and army aviation of the Russian Federation hit 62 military facilities of Ukraine;
▪️Russian air defense systems shot down one Ukrainian Mi-8 helicopter, six unmanned aerial vehicles, including one Bayraktar TB-2;
▪️ Caliber missiles launched from the Black Sea hit the workshops of the Nizhyn repair plant, where Ukrainian equipment was being repaired;
▪️The Russian air defense system shot down a Ukrainian tactical missile "Tochka-U" at night near the city of Izyum, Kharkiv region;
▪️The Russian Armed Forces destroyed six Ukrainian mobile electronic warfare systems "Bukovel" with artillery fire;
▪️Caliber missiles launched from the Caspian Sea and Kinzhal missiles hit a large fuel storage base in the Nikolaev region;
▪️In total, since the beginning of the special operation in Ukraine, 207 drones, 1,467 tanks, 148 multiple rocket launchers have been destroyed.
dice7 ::
Koncno realni podatki potrjeni s strani velikega kremlja
TezkoDihanje ::
VladarP je izjavil:
Ko bi za vsaj 10% tega, o čemer Rusi fantazirajo, predstavili slikovni/video material, ampak nope.
V zadnjem tednu so Ukrajinci dobili nazaj precej več ozemlja, kot pa Rusi novega zasedli.
VladarP ::
"Zgodovina je pokazala, da je uvedba sankcij kontraproduktivna, poslabša razmere in 'prilije olje na ogenj'," je dejal namestnik kitajskega zunanjega ministra Le Yucheng. Omenil je, da zdaj politiki "ne prizanašajo športnikom, predstavnikom kulture, umetnosti, zabave". Le Yucheng je poudaril, da se Peking zavzema za to, da ZDA in Nato vodita dialog z Rusijo o razmerah v Ukrajini, pa tudi o temi varnosti nasploh.
korenje3 ::
TezkoDihanje je izjavil:
VladarP je izjavil:
a trpiš? bogi revček
VladarP ::
Pusti ga korenje, na vsak nacin hoce konverzacijo in kreg. Trola treba ignorirat.
Akhmat sila, Bog je velik
Pimoz ::
Ni vidt. https://liveuamap.com/
korenje3 ::
Po moje ni trol, bi rekel da je plačanec. Da si tolk vztrajen s fake propagando... ni druge razlage
nejclp ::
Je hecno, da so, v trenutku, ko jih je NATO začel bombardirat, Srbi postali pacifisti. Po desetih letih hujskanja, junaškega pobijanja civilistov in boja za izgradnje Velike Srbije. Potem pa kar čez noč.
VladarP ::
Ameriška novinarka in dobitnica nagrade Emmy za novice in dokumentarec Lara Logan je dejala, da so bili zahodni mediji prisiljeni lagati o posebni operaciji v Ukrajini in obsojati rusko invazijo.
dice7 ::
VladarP je izjavil:
Wow, trumpelj je nenadoma bad guy ko se ni uklonil in je nabil kitajski sankcije?
  • spremenil: dice7 ()
nejclp ::
VladarP je izjavil:
Si pozabil omenit, da dela za Fox News.
VladarP ::
Ruska vojska nudi pomoč prebivalcem regije Černihiv
Prebivalcem enega od naselij regije Černihiv je bilo predanih približno 300 paketov hrane s skupno težo več kot 3 tone, pa tudi zdravila. Organizacijo in dostavo pomoči prebivalcem izvaja koordinacijski center za zagotavljanje pomoči civilnemu prebivalstvu Ukrajine skupaj z upravami regij Bryansk in Kursk. Skupno so ruski vojaki od začetka operacije prebivalcem regije Černigov predali 16 ton hrane in nujnih potrebščin. t.me/rusvesnasu
  • spremenilo: VladarP ()
VladarP je izjavil:
Ukrajinci so bolj vesci internet fightov kot Rusi. Kar preprica ovcke iz zahoda.
redo ::
VladarP je izjavil:
A to preden so "radirali" ali po tem?
TezkoDihanje ::
Ahaha. Ko pogledam ta spisek, se samo na glas krohotam.
https://www.oryxspioenkop.com/2022/02/a...
Srbski monglodoidi, res ste patetični.
Če niste slučajno opazili, fronta praktično stoji zadnji teden. A ni to malo čudno, glede na to, da vse poteka po planu?
Par 30mm patronov v skladišče streliva in iz tanka nastane bakla, video
https://twitter.com/RALee85/status/1505...
Video from the Azov regiment showing BTR-4 30mm cannon fire on Russian BTR-82A and a T-72B3 tank presumably in Mariupol. Note how they target the tank’s tracks.
Jaz mislim, da so tam pri tanku zadeli nekje sod goriva, ki je bil pri tanku ali na tanku. Ker drugače tank ne zagori na ta čuden način. Ta BTR-4 ima res spretnega operaterja, ta je že sesul še en transporter in poškodoval še eden T72 tank.
Meni so Rusi čudni. Na vseh posnetkih so statični, skrivajo se po nekih luknjah. Tudi ko dobijo 'incoming' ogenj, bi morali vračati strele. Četudi počivajo, nimajo požarne straže, nič. Nimajo prednje straže.
Tam je bil en posnetek, da T72 ima cev rahlo navzgor ter se počasi pelje skozi mesto. To je več kot butasto.
Če je tako, da se moraš peljati skozi mesto, narediš Američani temu rečejo 'thunder run'. Šibaš skozi mesto, preden pešadija nasprotnika zgrabi RPGje.
Ne vem. Resda so to ukrajinski posnetki (nimamo dosti ruskih), samo pri Mariupolu so imeli Rusi premoč 30.000 proti mislim da 2000 Azovcem. Zdaj so Rusi izgubili 15% oklepnikov. Danes si Rusi ližejo rane, popravljajo opremo, une helikopterje ki so bili poškodovani pri Hostomelu šlepajo na popravilo v Rusijo. Poročajo o bojih v središču Mariupola, čeprav ne intenzivnih. Ukrajinci so končno dobili okrepitve na severu zunanjega obroča Mariupola.
Danes je nedelja, vsi so vkopani - ta teden se bodo verjetno na smrt stepli pri Mariupolu.
Ah, da. Kitajci opozarjajo, da naj se nuklearno velesilo ne stiska v kot. Ukrajinci so do sedaj sesuli 13 ruskih generalov in polkovnikov (mislim da 4 generale ali 5 morda):
https://www.businessinsider.com/ukraine...
Generalov v tej operaciji je 20, od tega jih je bilo 6 na ruski strani, ostali na terenu v Ukrajini.
To je nenormalno dosti ubitih generalov tudi za Stalinove pojme. Še Čujkov, general ki je branil Stalingrad - je ostal živ.
VladarP ::
Smrt visokih oficirjev na obeh straneh samo govori o temu, da so slovanski oficirji operativci na terenu. Ne komandirajo iz toplih sob tako kot Vesli Klark.
dice7 ::
VladarP je izjavil:
Ne komandirajo izza dolgih miz?
TezkoDihanje ::
VladarP je izjavil:
A lahko kaj napišeš o izgubah visokih oficirjev na strani Ukrajine.
VladarP je izjavil:
Mrtev general je mrtev general. Morala in bojna pripravljenost je precej odvisna od generala. Slika mrtvega generala, ki ima zmaličen obraz in je ves krvav po trebuhu ne pripomore k višji borbeni morali.
Tudi Rommel je bil na fronti, hodil med vojaki. V bitki pa se je vseeno umaknil v zaledje.
To je ultra fail Rusov.
Nič posebnega, samo direktor Roscosmosa salutira na fašističnem zborovanju, video
https://twitter.com/KremlinTrolls/statu...
Dmitry Rogozin @ Wikipedia
Dmitry Olegovich Rogozin (Russian: Дми́трий Оле́гович Рого́зин; born 21 December 1963) is a Russian politician who is Director General of Roscosmos since 2018.
Previously he was Deputy Prime Minister of Russia in charge of the defense industry from 2011 to 2018. Prior to that, he was Russia's ambassador to NATO from 2008 to 2011.[1]
več:
https://news.pn/ru/politics/153236
cel video, salutiranje @2:30:
Rogozin on a Nazi march: "I don't want to live on Kadyrov Street! Moscow is a Russian city!"
cias ::
TezkoDihanje ::
8-O oh wow.. saj ne moreš verjet...
To ni Rogozin. Ali je fejk ali je nekdo podoben Rogozinu. Bil je intervju z njim, pa ena oddaja Rusov "Rdeča zvezda", kjer so predstavljali orožje, tam je on komentiral orožje. Podobno kot Military Channel na drugi strani.
Rogozin je tehno-general. Vedno se je motal po politično-inženirskih pozicijah. On razlaga, kako deluje ta oklep, pa uni, pa če je zadetek tako ali drugače. Pa counter-strike. Pa to.
Dopuščam možnost, da je obupal nad tehno-orožjem in se sedaj vlači po mitingih resnice.
cias ::
Kaj si v Kremlinu da veš kakšen je plan?
Ker mi amaterji še zmeraj mislimo da gre za:
A pocket refers to combat forces that have been isolated by opposing forces from their logistical base and other friendly forces. In mobile warfare, such as blitzkrieg, salients were more likely to be cut off into pockets, which became the focus of battles of annihilation.
A nam lahko podaš ti tvojo profesionalno analizo prosim? Zmanjkalo bencina, nimajo več ljudi, vikend off... ?
VladarP ::
Visoki oficirji niso samo generali, temveč tudi polkovniki, majorji itd....
To je Rogozin. Na sceno se je prisvaljkal kot vodja nacionalistične stranke, Rodina.
Rogozin fought in the Transnistria war against the Moldovan forces.[5] He is also a vocal supporter of Transnistria's independence from Moldova.[6][7]
In 1993, Rogozin joined the recently created party Congress of Russian Communities led by General Alexander Lebed and, after its founder died in a 2002 helicopter crash, Rogozin became joint leader with Sergey Glazyev of what became the Rodina party, which was described by Novaya Gazeta liberal journalist Anna Politkovskaya as 'created by the Kremlin's spin doctors specifically ... to draw moderately nationalist voters away from the more extreme National Bolsheviks'.[8]
Under Rogozin, Rodina shifted towards the right wing of Russian politics and became the second largest and one of the country's most successful parties. A number of controversies on Rogozin's policies culminated in it being banned in 2005 from standing for election to the Moscow City Duma for using what was considered as chauvinist slogan 'Let's Clean the Garbage!'.[9] Many analysts believe it was made illegally to prevent Rogozin becoming a candidate at the Russian presidential elections in 2008.
in seveda tale reklama
Dmitry Rogozin racist ad. English subtitles.
cias ::
Intedresting.
dice7 ::
cias je izjavil:
Koncno nek sposoben clovek, ki zna drzavo vodit ucinkovito, kot podjetje, in ne kot tisti, ki nimajo dneva delovne dobe
cias ::
Ma daj ne se ti it naci lovca, ko še v celi Ukrajini ne najdeš enega. Ostani pri postanju Bond reklam in se deri kako so Rusi aretirali ansambel ker je imel besedo mir v pesmi.
Ali pa končno pokaži tisti posnetek ko Drumpf lula po Obamovi postelji.
Potem zapravlja svoj talent. On razume, kako penetrator iz tungstern-karbida premaga ERA oklep in zdaj tu folk uči kako se čisti požrte ostanke lubenice. OMG
TezkoDihanje ::
cias je izjavil:
Kakšen pa je potem plan?? 8-O
A novačenje Sirijcev je tudi del plana?
Kdo pa je v pocketu? Ker tam na severu smo vsaki dan bliže temu, da bodo Rusi v pocketu. Ne pa obratno.
Zamešal si. S čiščenjem lubenic je prišel na sceno.
korenje3 je izjavil:
Ti se oglašaš?
TezkoDihanje ::
Srbski moglodoid, ki beblja o propagandi.
Ej, saj vem da trpiš. Ampak ti povem nekaj...
ŠE BOLJ BOŠ TRPEL.
dice7 je izjavil:
cias je izjavil:
Ne ti zdaj tega Zelenskega preveč obožuj. Namreč, vseeno je kar nekaj napak naredil. Za začetek ni hotel implementirati Minsk II protokola. Saj razumem, da ga je mučilo dosti stvari, na primer, da so njegovi politični predniki izgubili Krim za brezveze.
Samo, lajal je pod napačnim drevesom. Oziroma, njegova taktika je bila stiskati Donbas in ne narediti nič. Ta taktika je pripeljala k eskalaciji.
Podobno, kot si je denar nabral Janukovič, si ga je tudi Zelenski in kup enih ukrajinskih oligarhov.
Zelenski bi moral dati neko lokalno samoupravo Donbasovcem, jih vse pomilostiti. Vreči bi moral iz ustave, da bodo šli v NATO. Za EU bi se moral pogoditi, da to ne bi škodilo Donbasovcem. Krimovcem bi moral odpreti vodo, da ne bi gagali kot račke, ter se pač pogoditi, da se Krim vrne Ukrajini.
Ter seveda Ukrajino oborožiti do zob (nevtralnost se dobi z denarjem ali orožjem).
To je spisek failov Zelenskega.
Teorija podkve ali ko ustanoviš skrajno desno stranko, da vlečeš glasove stran od komunistov.
Rodina (political party) @ Wikipedia
The Guardian claims that Rodina was "set up by President Vladimir Putin's allies" in 2003 "to leach votes from the Communist party".[15]
Akira_ ::
cias je izjavil:
Intedresting.
Kdaj bomo od vas trolov videli kak drug link kot pa na 4chan* vsebino :)
*Stran narejena za drkanje mularije na animeje, danes pa greznica interneta
korenje3 ::
Zelensky Annual Income
Year Income
2021 $113 Million
2020 $90 Million
2019 $87 Million
2018 $55 Million
2017 $42 Million
2016 $29 Million
Kako lahko zaslužiš 113 milijonov dolarjev kot predsednik? wtf
Airborne tankovska kupola, video
https://twitter.com/Blue_Sauron/status/...
Reportedly a Russian tank blown off meters away from Ukrainian trenches.
dice7 ::
Year Income
2021 $113 Million
2020 $90 Million
2019 $87 Million
2018 $55 Million
2017 $42 Million
2016 $29 Million
Tako da ne igras vsak dan golf
cias ::
Zelensky se je pravkar oklical za absolutnega vladarja Ukrajine! Skenslal je vse konkur., hočem reči, vse Rusofilne stranke!
Now that's a democracy i can get behind! BASED!
Zelensky suspends 11 Ukrainian political parties with Russian ties
Se enkrat, Rusi ne rabijo slikovnega/video gradiva, da dokazejo svojo premoč in dominanco.
VladarP ::
Cena sečnine, ki je strateško pomembna v kemični industriji (pridobivanje gnojil), je podrla zgodovinski rekord.
korenje3 ::
cias je izjavil:
To je že pred letom 2014. Zaprli so vse iz opozicije in vse pro-ruske politike.
524 / 859
