Ukrajina Part II
![](https://static.slo-tech.com/stili/avatar_gray.gif)
RedDrake ::
PrihajaNodi je izjavil:
Bencin gre danes spet gor. 10 posto baje. Ampak mamo pa hamburgerje pa ikeo, ki pa se jih itak kmalu ne bo mogoel nihce privoščit s to bedno slovensko colngo.
Akcija: 4 doza boster, gorivo -5% !
Jaz sem iz virov blizu vodstva enega večjih slovenskih črpalkarjev slišal da se pričakuje cena nad 2,5 EUR / l za 95 že naslednji torek.
HITRO NA ČRPALKE!!!!!
![](https://static.slo-tech.com/stili/bel_non_grata.png)
PrihajaNodi ::
Mene bolj zanima kaj bomo naredili z vsemi temi necepljenimi Ukrajinkami, k iprihajajo? V UKR je precepljenost 35% a pri nas so cepiva na voljo v velikih količinah, so varna in UČINKOVITA. Pošpikajmo njih!![]()
Mogoče je pa to plan. Da se zaneti vojna v državah z nizko precepljenosti pa se begunce pošlje na zahod pa jih tam pol špikajo.
Zame se nic ne spremeni ker vedno isto tankam za 25 eur.
#StaiAcasa
#SpikajmoSEvsi
- predlagal izbris: Unchancy ()
Video ambasadorja na povezavi.
The Russian Embassy of the Netherlands is sharing a video where its ambassador repeats the false claim of crisis actors being used in the Mariupol maternity hospital bombing on the same morning AP reports one of the women and her unborn child died.
Russia's ambassador to the Netherlands uses comments from random internet users that include "Bloody comedian, how much did you get paid" as evidence to support his allegations. Russian diplomats literally using internet trolls to deny war crimes. It's difficult to imagine the Russian diplomatic core debasing themselves further than appearing on television to repeat internet conspiracy theories, but it's something they've done for years. They're such shameless cretins they can't even come up with their own lies.
Kot zapisano, po poročanju AP naj bi nosečnica na nosilih in njen nerojeni otrok umrla. Danes so prišli tudi dodatni videoposnetki, vidi se rana v področju medenice.
https://apnews.com/article/russia-ukrai...
Obstaja boljša kvaliteta, tu je pa več materiala
Pregnant mother and baby die in Mariupol bombing
Eno ZELO resno vprašanje glede Krima:
Zakaj se ne gleda opcije, kjer Krim ostane Ukrajinski, ampak se naredi mejo okoli širšega ozemlja pomorske baze pri Sevastopolu? Tako kot Zadar/Zara pod Italijani med obema vojnama? Se pravi Rusija ima ozemlje na delu Krima okoli baze Sevastopola, se pravi izhod mornarice na topla morja, Krim kot celota pa ostane v Ukrajini in se ohrani ozemeljsko neodvisnost Ukrajine. Most pri Kerchu se ohrani za ruski dostop, ampak se postavil mejno kontrolo, isto se ohrani dobava vode iz UKR za rusko bazo. Win-win za obe državi.
Neka taka rešitev bo. Bo pa moralo biti zapisano v meddržavni pogodbi, ki jo bosta ratificirala oba parlamenta.
Verjetno je smiselna rešitev, da je ozemlje od Ukrajine. Ker je že bilo rusko, pa ni laufalo (voda, elektrika, dobrine). Tisti most je boljkone - je samo...
Pa saj ni samo voda. Elektriko ta trenutek imajo tako, da laufajo Siemensove plinske turbine. Pa lastninska razmerja, pa telekom storitve. Pa dobava materiala. Ta most se sedaj privzema, da zdrži vse dobave.
Pa čisto tako... Dobava iz Ukrajine je dosti cenejša. To mora ta hip (iz Rusije) nekdo subvencionirati.
Ta Krim je fail za Ruse iz 100 ozirov.
Je pa eno dejstvo. To je (zaenkrat) edino toplomorsko pristanišče (Sevastopolj) za Rusijo in je super strateškega pomena. To bi pa predvsem Ukrajinci morali vzeti na znanje, ker so se doslej obnašali neprimerno glede tega vprašanja.
Saj podobno je v EU (Nemčiji). ZDA imajo bazo, če pa majo kako robo na carini ali karkoli, če je označena za ZDA bazo, to spustijo skozi brez pregleda. Carinska pošta pa je v bazi, tam pa potem zaposlenci baze naredijo kontrolo, obračunajo carine ipd.
- spremenilo: bbbbbb2015 ()
PrihajaNodi ::
#StaiAcasa
#SpikajmoSEvsi
Krim je podobno kot za Slovenijo piranski zaliv.
Ahahah.. Dobro da si povedal, ne bi se sam spomnil. Ne vem edino kako parkirajo borbene rušilce klase Kirov. Zasidran v Piranskem zalivu, krma pa moli v hrvaško morje in tam preko v italijansko. Ali pa je rušilec pol na kopnem, pol v morju?
Ni res.
Novorossiysk @ Wikipedia
In 2003, President Vladimir Putin signed a decree setting up a naval base for the Black Sea Fleet in Novorossiysk. Russia has allocated 12.3 billion rubles (about $480 million) for the construction of the new base between 2007 and 2012. The construction of other facilities and infrastructure at the base, including units for coastal troops, aviation and logistics, will continue beyond 2012.[16] Russia planned to move the Black Sea Fleet with 80 warships and its headquarters from Sevastopol to Novorossiysk base within 2020.[17]
PrihajaNodi ::
Nevem o cem govoris samo ta dva slovenska colna P-08 in P-16 opravljata svoje delo vec kot odlicno.
Koji k ma slotech probleme...
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
Pac-Man - Novorossiysk to nisem poznal. V bistvu se potem Rusom to bolj splača.
Razen če ne bi trošili keša za novo bazo in bi radi obdržali Krimsko. Cost benefit.
blay44 ::
Z obkolitvijo, malimi žukovimi kleščami, zaokrožujejo okrožja,
Nikolajev, Zaporožje, Mariupol, Doneck, Lugansk, Harkov, Černigov.
Sicer avijacija še deluje, protizračna tud, sam bo pa hudo.
To nakazuje zadnje dejanje pred pogajanji. Nimajo več resursov.
@holger_r and I spoke to "Karl," an Estonian expert on Russia's military, for an update on the situation in Ukraine. Karl's observations follow.
His previous assessment is here: https://newlinesmag.com/argument/putins...
No significant developments over the weekend. The frontline around Kyiv remains similar. Ukraine has regained 70% of Irpin or the little that has remained of it.
In some areas there is a tiny advance of Russian units.
Finding a compromise between Ukraine and Russia is still hopeless. Russia's minimum would be full control of the two "people's republics" and land access to Crimea.
Ukraine won't go for that unless Kyiv is in real danger of falling. Every day that the war continues brings Russia's minimum demands lower.
Talks of Russia bringing additional troops from the Far East and Armenia: They have only around 6,000 troops in Armenia and they can't take them all away.
This wouldn't change the overall picture in Ukraine.
No imminent signs that Belarus is going to send their military into Ukraine. Lukashenko is doing what he can for it not to happen.
Question is, how much maneuvering space does he have?
Russia has managed to recruit up to 3,000 Syrians who should arrive in Ukraine shortly.
This is not considered a serious deployment.
Reports are that Russian troops have started digging trenches. This indicates positional warfare.
Russians are "very far" from encircling Kyiv. This encirclement would need to be 300km long and very tightly sealed.
Morale, which we have heard so much about, is continuing to fall.
Reports of Russian troops surrendering for food and self-inflicted injuries to get out of the war.
Reports about Xi having been aware of a "special operation" but not about a total war. Xi feels that Putin wasn't honest.
Generally there isn't much optimism about the idea of China coming to assist Russia.
Even if China promises equipment, it would be a question of months not weeks to happen. That said, the U.S. is very concerned about China's decisions.
Revealing the info about Russia's request goes in line with U.S. tactics in the case: reveal to hinder or stop from happening.
FSB lacks resources to control occupied areas (Kherson). FSB needs their manpower to repress back home.
Ni res.
Ahahah. Ma glej. Lahko da je dekret podpisal - v Rusiji je korupcija taka, da za vsako stvar moraš tri ali več ničel pripisati pa potem morda dobiš pravo cifro. Morda pa tudi ne. In nimaš nič.
Kolikor vem, se je za Sevastopolj pogodba o najemu iztekla (ne vem,tam malo pred zasedbo Krima) in Rusi so verjetno hoteli/želeli/morali/se jim je sanjalo/jim je šlogarica iz kugle prečitala to premakniti iz Sevastopolja.
To tako ne bo šlo. V Sevastopolju živi kup Rusov (pravzaprav pretežen kup), ki od črnomorske flote konkretno živi. Najmanj oni ne bodo šli nikamor. Tako da je (po moje) ta plan padel v vodo. Imam sodelavko iz Ukrajine, Tetyano, ona pravi, da ima (ruske) sorodnike v Sevastopolju in bo črnomorska flota šla iz Sevastopolja samo preko njih mrtvih.
Glej, tam je ogromno vsega, neko akademijo imajo, pa nek raziskovalni inštitut. Pa remontne zavode. To vse dvigniti in nesti 100+ km daleč, težka bo.
111111111111 je izjavil:
Verjamem da bi se večina cepila če bi rekli da bo Putin nehal nagajat potem. Iz solidarnosti bi rekli...
Jaz se ne bi. saj nisem numen da bi si vnašal neko snov po kateri mi lahko zrastejo rogovi.
si zgolj tako zabit, da verjames v take bedarije.
Saj to je to. Ta "full control" še spustijo ven, pa so zmenjeni. Land access pa so Rusi že prej imeli. Bodo se zmenili, zgleda.
Ker prej je bilo neko "priznanje suverenosti" na mizi. To je no-go za Ukrajince.
fikus_ - ne morajo biti ker bo Ukrajina vojaško nevtralna.
Kaj pomeni vojasko nevtralna? Ker to seveda ni res. Rusi tega nikoli ne bodo dopustili.
Rusi so že 100x rekli, da bi to šlo. To buffer cono imajo z Finsko in Švedsko. Zat sta ti državi ne-NATO (in oboroženi do zob).
To bi recimo Rusom pomenilo, da AWACS sniffer letalo nikoli ne more krožiti v osmici pred mejo. Nobenega materiala ne morejo prepeljati, nič ustreliti čez nevtralno državo.
To Rusom precej olajša stvari. V tem delu so Ukrajinci zeo kiksnili. Lahko bi mnenje Rusije akceptirali (kot so to storili Finci in Švedi). Samo je pa tako, da moraš biti oborožen do zob.
Vsakemu s pol mozgani je jasno, da beseda "nevtralnost" pomeni, da ne smejo ogrozati Rusije, ampak je dovoljeno le defenzivno orozje. Pa se to z omejitvami. Skratka, drzava ne bo suverena.
- spremenil: kow ()
BlaY0 ::
Kitajska se še kar bori s kovidom.
Jap:
https://fortune.com/2022/03/14/china-sh...
voss_ ::
Zakaj pro-russia stance tu ni ni sprejemljiv.
Russia | Why Ukraine Really Changes Everything
Pro rusija ne smeš biti ker to ni skladno z našimi demokratičnimi, neodvisnimi pro amerika stališči.
To je čisto vse kar rabiš vedet o tem konfliktu.
TheBlueOne ::
Ti malo mesas. Ti si b.p. lahko proti marsicem kar delajo ZDA. Problem je, da diktatorji napadajo demokracije. Problem je, da dikratorji dobivajo na moci s tem, da deloma kradejo demokracijam. Sedaj pac demokracije rezejo sisteme, ki so jasno pokazali, da so agresivni.
Kar se mene tice ne dovolim, da mi v blizini sarijo diktatorske in represivne drzave. Imam prevec rad svobodo in da smem bentit cez kar mi ne pase. Sem vesel, da lahko kritiziram ZDA in EU, ce delata napake in da me ni strah, da me bodo zaprli, ko se ne strinjam.
- spremenil: TheBlueOne ()
voss_ ::
Mimogrede, baltske drzave so leta 1938,1939 razglasile nevtralnost. Za nagrado so jih okupirali. Edina smiselna nevtralnost je jedrsko orozje po vsej ruski meji, usmerjeno na njihova vecja mesta.
Isto rabijo jederska orožja Iran, Afganistan, Sirija, Somalija... Usmerjeno na izrael in večja ameriška mesta.
PrihajaNodi ::
Jap:
Se zdalec nismo zakljucili s kovidom. Takoj ko se tale ukrajinsko ruska propaganda konca bo kovid nazaj. Nova mesanica cepiva je ze tu.
Podobno kot v nekaterih drugih državah Evrope pa tudi Francija znova opaža postopno naraščanje števila okužb. Premier Jean Castex je tako starejšim in kroničnim bolnikom svetoval, da še naprej nosijo maske. Obenem pa lahko starejši od 80 let dobijo četrti odmerek cepiva proti covidu-19, če je od tretjega minilo najmanj tri mesece.
Izkoristite svobodo dokler rusom ne zmanjka orozja in ljudi. Mark my words in shranite napisano
#StaiAcasa
#SpikajmoSEvsi
Če Rusi mislijo, da se tu lahko vmešavajo, se jim bodo tudi na mednarodnem parketu vsi režali.
- spremenilo: Malidelničar ()
Jap:
Kaj tebe boli, če cepiš se tak ne, cepljenje pa tudi ne bo obvezno? Tisti, ki pa se cepimo, pa si želimo, da dajo minimalno morfija zraven, da bo lep in sončen dan!
- spremenil: fur80 ()
PrihajaNodi ::
Bo obvezno. Samo vprasanje casa je. Bodo ze nastimal da bodo sle cifre gor. Podlaga pa je ze nastimana z novo sprejetim zakonom
#StaiAcasa
#SpikajmoSEvsi
- predlagal izbris: nejcek74 ()
Ne bo obvezno, ker je Putin naredil slabo reklamo represiji! ;) Tonin je pa rekel, da sbovoda nima cene! :D
Nič ne bojo "naštimal", v bolnišnicah se stanje ni čisto nič spremenilo (informacije iz prve roke), še vedno majo horde covid pozitivnih. Samo zato ker covida ni na prvih straneh ne pomeni da je magično izginil.
PrihajaNodi ::
Represija je bila tudi ko se je izlocevalo necepljene, pa se noben ni pizdekal, se vec, celo podpirali ste to.
A niso rekl da je omikron novi prehlad? A stroka laze?
#StaiAcasa
#SpikajmoSEvsi
kow - ja v bistvu ne vem kako je z nevtralnostjo, ampak država je pa lahko defenzivno oborožena do zob (in še čez). In mislim, da tu ni zdaj nekih fint kot za Nemčijo po WWI. Avstrija verjetno ima tanke, tudi protizračne sisteme, topništvo, raketne sisteme za obrambo na lastnem ozemlju? Švica isto. Če je Ukrajina nevtralna tudi to ne pomeni, da Rusija potem določa kdo jo lahko oborožuje in kdo ne, to tako ne gre. ZDA, VB, Kanadčani , vsa EU, lahko vojaško nevtralno Ukrajino oboroži v nulo.
Ja, bol mal ti stekas - vidim.
Če pa je tu tema o Ukrajini, ti pa sprašuješ za recept o makaronih!
PrihajaNodi ::
#StaiAcasa
#SpikajmoSEvsi
Avenger ::
Zdaj, v Rusko - Ukrajinski vojni so vse vlade enako usklajene pri sankcijah do Rusije, mediji pa spet usklajeni do popolnosti, v absolutni nedopustnosti kakršnega koli drugega kot negativnega mnenja glede Rusije. Črno ali pa belo, brez nians. Na koncu pa ni opombe z vprašajčkom, ampak je vedno lepo klicaj, dejstvo!
Poglejte samo primer drona, ki je padel dol na Hrvaškem. V člankih je vedno govora o "Ruskem" dronu ali dronu "Ruske izdelave" z insinuacijami, da so ga Rusi tudi poslali. Priletel pa "naj bi" iz Ukrajine. Ni besed o tem, da so jih Rusi nehali uporabljat eeeem.. v 90ih letih in da so jih potem uporabljali le še Ukrajinci.
V vsem skupaj je treba iskat nianse, preverjat pri več virih, upoštevat, kakšne interese ima ta, ki objavlja nekaj... do resnice je težka pot in nič ni samo črno ali belo.
111111111111 ::
Tudi če bi bili rogovi bi s tem preprečil vojni spopad. Solidarnost in to
Jaz in ti se ne bi cepila, ti ker nimaš solidarnosti, jaz pa ker bi to tvojo agresijo podprl.
Vsak ki pripelje necepljenega v cepilni kotiček dobi 10 kilogramov moke brezplačno! Bodimo solidarni do nas in ostalih. Ostanimo ljudje z roko v roki z begunci.
Hitro po moko Nodi. oz. pošlji svojo mamo.
- spremenilo: 111111111111 ()
PrihajaNodi ::
Samo vprašanje časa, kdaj bodo priznali, da imamo one world government. Zaenkrat so še v senci, ampak kakor je Kacin lepo priznal, so države med seboj "usklajevale" vse v zvezi z 'rono, in rekel, dobesedno, da še vedno želijo precepit 100% prebivalstva. Kljub novim, preverjenim podatkom. No in treba je priznat, usklajevali so se med seboj res dobro, vsaka država je imela malo drugačno "domačo nalogo", toliko, da jih nisi direktno mogel obtožit, da so kopirali od soseda, ali pa morda razlog tiči v tem, da je vsak narod malo drugačen in eni tolerirajo več, drugi manj nesmiselne represije. Vsi mediji so bili usklajeni do popolnosti, v absolutni nedopustnosti kakršnegakoli odklonilnega mnenja glede smeri, v katero nas je peljala vlada.
Tocno. Kdo je to MI Jelko Kacin?? NWO? Tale tema je rako brezpredmetna kot bo nova kovid tema, kjer bo spet neka super duper razlicica ubijala in kradla postelje. Vmes pa ne pozabimo kako fino so v teh krizah nekateri pokasurali. Jasno, bodo za vse krivi rusi
#StaiAcasa
#SpikajmoSEvsi
Izumljaš toplo vodo! To vedo pomoje vsi, problem je samo, da je nedopustno kaj dela Putin v letu 2022 in to na kak način in to v Evropi!
111111111111 ::
Heh, ti sarkazma ne bi razumel, če bi ti ga potisnil v gate.
PrihajaNodi ::
Nedopustno je marsikaj. Tudi analni brisi in zapiranje v domove pa se nad tem opice niso obregnile
#StaiAcasa
#SpikajmoSEvsi
Pred letošnjo vojno se bi dalo marsikaj dogovoriti, še več pred 8+ leti, ampak sedaj s kakršnim koli umikom Putin preveč izgubi oz. ne more doma to prikazat kot zmago in politično preživet.
Za pogajanja UA šteje v + to, da vojna traja dlje, kot je planiral Putin, da so skoraj zaustavili napredovanje RU vojske. Tako da iz tega naslova je velik pritisk na RU in njihovo pripravljenost na resna pogajanja, ki bodo dala rezultate.
UA vojsko na JV UA bodo Rusi poskušali uničit tudi zaradi maščevanja, ker so ti napadali rusko govoreče prebivalstvo na tem območju zadnjih 8+ let.
Unchancy ::
Sedaj ko jim ekonomija cveti zaradi covid in Ruskih sankcij je dosti za vojsko.
Upam da ne bojo skenslali bonov za gretje penzionistom. Sedaj ko smo jih rešili pred covid smrtjo.
Problem je da se nismo vsi pocepil. Če bi se celotna svetovna populacija pocepila bi Putin odnehal. Tko pa je in mamo kr mamo.
A ni debatiranje pod več nicki v isti temi prepovedano na ST? Pa še sam s sabo…
![:))](https://static.slo-tech.com/smeski/icon_lol.gif)
Proti ruskemu zelezju gotovo niso.
Bo potrebno preklopiti na Kitajsko, vsi vemo da Rusi niso NATU dozoreli, Kitajska bo na drugi strani vojaška velesila od leta 2040 naprej (po mojem mnenju še bistveno prej). Typhooni bodo takrat proti Kitajski samo še za v muzej. Nemčija, Francija in Španija naj bi delali na next generation fighter jetu ki naj bi bil (pazi) pripravljen leta 2045! Namesto da bi celotna Evropa kupila F-35 in da bi potem skupaj z Američani investirali v NGAD gremo mi raje po svoje. Vsi vemo da Rusi v zračnem spopadu proti NATU nimajo nobenih možnosti. Bolje da se že enkrat začnemo pripravljati na Kitajsko. Rusijo bo čez čas potrebno dobiti pod NATOVO krilo, drugače bomo proti Kitajcem težko dihali.
Itak smo preveč odvisni od Američanov, vse OK, če sami razvijemo lastno orožje.
Adijo mod Rdeči Kmeri.
- spremenil: Unchancy ()
PrimoZ_ ::
To pogovarjanje s samim sabo z različnimi nicki.
- spremenilo: PrimoZ_ ()
PrihajaNodi ::
#StaiAcasa
#SpikajmoSEvsi
Če so tebi delali analne brise, potem ti pa res ni pomoči! :D
PrihajaNodi ::
To zdej pride. Začeli so z maskami, pol palčkami, ene so šle bol gor v nos in so ble cenej - hitri test, potem smo imeli pcr, zdj naslednja runda pa masovno odvzemanje analnih brisov. Itak se narod vsega navad.
Isto je s podganimi in opicami. Hitri šok ni nikol dobr, je treba mal pavze vmes.
#StaiAcasa
#SpikajmoSEvsi
