Ukrajina Part II
-vx- ::
TezkoDihanje je izjavil:
Oni se grejo napad na vojaske cilje. Ker je debil od Zelenskega naredil iz vsake stavbe vojaski cilj (ce se spomnis pozivov, k izdelovanju molotovk?), ne rabijo vec targetiranega orozja.
samo sanjaj
https://twitter.com/nytimes/status/1499...
Mislim, da se moras predvsem ti zbuditi:
https://casebook.icrc.org/glossary/civi...
Any object which is not a military objective.
A civilian object must not be attacked unless it is used in a way that renders it a military objective. It may not be the target of reprisals.
In case of doubt whether an object which is normally a civilian object (e.g., a place of worship, a house or other dwellings, a school) is a military objective, it must be considered as a civilian object.
https://casebook.icrc.org/glossary/mili...
“Military objectives” are limited to those objects which:
- by their nature, location, purpose or use make an effective contribution to military action, and
- whose partial or total destruction, capture or neutralization, in the circumstances ruling at the time, offers a definite military advantage.
Ukrajina: freedom's just another word for nothing left to lose.
BlaY0 ::
Jaz samo upam da pade ena bomba na center moskve. Da rusi malo vidijo lepote vojne.
Kot ze povedano si psihopat, ki v vojni uziva in si zeli samo cimvec zrtev.
Ne, samo želim si da moskovčane doleti isto kar delajo sedaj oni v Ukrajini ko uničujejo človeška življenja.
Zakaj? Oni nimajo blage veze s tem. Oni so samo zavedeni...
razfukajte že en konvoj rusom da se klanje malo ustavi.
In se izjave psihopata nadaljujejo. Seveda se ima za pacifista.
Kaj ti ni jasno. Rusi namenoma koljejo civile. Življenje ruskega invaderja ki pobija civile je vredno 0. Niti dvomim ne da cecenske živali mass rapeajo
- spremenil: endelin ()
korenje3 ::
Evropa ima zelo malo nafte. Nekaj je pokrademo libijcem. Za nas jo američani kradejo v iraku in siriji. Sam ne vem če bo dovolj. Bo treba zatehni pasove.
-vx- ::
Kritiziras Putina, hkrati pa se obnasas enako. Zanimiv pristop.
korenje3 ::
Dokumenti o kemičnem orožju v ukrajini:
Koncno je pobijanje upraviceno!
Upravičeno je bilo že ko je azov obesil ljudi iz donbassa na križe in jih žive zažgal.
Seveda boš podal vir.
Putin ima škarje in platno da se to ustavi. Morda se trenutno še da omiliti sankcije.
TezkoDihanje ::
dice7 ::
PrihajaNodi je izjavil:
EUR pa kar pada
Mhm. Ampak raznim hippijem tukaj ni jasno, da zivijo v EU in ne v ZDA.
EU je samozadostna, ima zlate rezerve, trguje med samo z evri, izvoze pa itak prodaja v dolarjih
BlaY0 ::
[Drkanje zahoda, ala mi smo našli kemčno orožje, vi ga pa niste v Iraku.
Mhm. Ker vojna v Iraku se je tudi "baje" bojevala zaradi kemicnega orozja, daj spomni me, kaksne sankcije so doletele ZDA?
Kaj ti spet ni jasno? Sankcionira nasprotna stran če to želi! Kaj bi ti rad, sam sebe sankcioniral?
Kako pa veš,da so to Ukrajinci?
Pimoz ::
A to je posneto s strani kakšnega lokalnega dramaturškega krožka?
Ja, tko kot k so arabci rezal glave. Folklorna skupina.
kgtjera ::
IL_DIAVOLO je izjavil:
Ker begunci ki so prišli v Slo so bili sila nezadovoljni in bili celo pripravljeni iti nazaj v Ukrajino.
Ukrajinci niso kompatibilni z evropsko kulturo
Resno? A so ukrajinci iz arabskega sveta? Ukrajinci so čisto isti kot mi slovenci, avstrijci ipd. Edino nekateri ga radi cukajo .. no, saj to ni nič takega, mamo štajersko, pa dolenjsko, ki je že 0,5 promila v luftu, korenci pa itak tudi že prekašajo počasi oni dve regiji ....
Ko osebno spoznaš par gold diggerk in pijancev, se mogoče premisliš. Definitivno pa bolj kompatibilni kot kamelojebci.
-vx- ::
Saj ti imas tudi skarje in platno, pojdi na Ukrajinsko ambasado in se pojdi borit v Kijev. Daj AK-47 tja kjer je tvoj jezik.
korenje3 ::
JUST IN - NATO countries have "green light" to send fighter jets to #Ukraine, says U.S. Secretary of State Antony Blinken.
https://twitter.com/disclosetv/status/1...
Jaz pa berem da bo dal "US" green light. Aha torej NATO je samo orodje za ZDA. sam tolk da vem da so ostali vazalne države...
https://twitter.com/ASBMilitary/status/...
Pošteno bi bilo,da bi jih Rusi sankcionirali. Zakaj jih niso pa bog ve.
TezkoDihanje ::
Jaz samo upam da pade ena bomba na center moskve. Da rusi malo vidijo lepote vojne. Putler bo tezko nekoga obdolžil
Verjetno se ne zavedaš, da to pomeni, v najboljšem primeru, da boš živel še nekaj ur, če bo pa slabše zate, pa nekaj dni, mogoče tednov.
- spremenilo: fikus_ ()
-vx- ::
Jebes Rusijo, mene zanima zakaj jih EU ni.
BlaY0 ::
EUR pa kar pada
Z energetskimi viri še zdaleč ne.
To še bo veselo, če bodo američani dali ukrajincem reaktivce ... Hitlerju se bo zmešalo. Mogel bo pohiteti do Kijeva, če ne bodo moglo pohiteti nazaj domov ...
so ameriški lovci kej posebnega?
Glede na to, da američani v kitajskem morju niso dovolili priti niti blizu strmoglavljenega f35 v morju, ko je padel iz letalonosilke, potem veš, da nekaj posebnega že je. In glede na to, da so ga dokaj hitro dvignili iz morja američani, očitno res niso hoteli, da pride tehnologija nekomu v roke. Sicer pa, od kar jim je v srbiji strmoglavil neviden bombnik, imajo rusi tudi stealth tegnologijo, katero so skopirali od bombnika, ki jim ga je podarila srbija ... Tako kot atomsko bombo, isto so mogli skopirati od američanov, ker sami je niso bili sposobni sestaviti - dva ameriška državljana oz. ruska vohuna sta takrat sovjetski zvezi predala načrte za izdelavo jedrskega orožja ... ko sta bila spoznana za kriva, so ju kmalu obsodili na smrt.
Če ne kdo reče d je "neviden" še ne pomeni da je to res. Američani so "masters of deception". Ko se bodo spravili na kakšne, ki imajo zares protiletalsko obrambo bodo vidl kako so "nevidni".
Ti si res nerazgledan ... Neviden se reče zato, ker je vseeno viden radarjem, s tem, da je na radarju to letalo vidno v velikosti ptiča, zato ni jasno kaj je, dokler ni prepozno. A razumeš zdaj bistvo nevidnega letala? Namesto, da bi na radarju pokazalo kot eno veliko piko, jo prikaže tako majhno, kot da bi šlo za velikosti ptiča.
Malo se bolje pozanimaj kaj je stealth tehnologija za radarje ...
-vx- ::
Verjetno se ne zavedaš, da to pomeni, v najboljšem primeru, da boš živel še nekaj minut, če bo pa slabše zate, pa nekaj dni, mogoče tednov.
Seveda se ne zaveda, on plameni za ideale, zahodne fake news, socialna omrezja, nizko samopodobo, pravico! Realnost je tukaj nepomembna.
- spremenilo: -vx- ()
BlaY0 ::
Ne, narobe bereš. Vsi se morjo strinjat. Je pač tako, da je USA med zadnjimi, ki se je strinjala.
Voss ::
1. Azov bataljon je neonacističen bataljon in mora biti v sramoto Ukrajinski vojski.
2. Vsaka država v Evropi ima neonaciste v svoji vojski
3. Rusija je v Ukrajino poslal neonacističen Wagner Group. Torej bodo z neonacisti izvajali denacifikacijo
4. Kje je sicer kakšen dokaz, da je to res Azov bataljon (se sicer nebi čudil, če bi bil res).
5. Limal si tudi posnetke, ko naj bi Ukrajinci usmrtili 4 psa, očeta in sina, ker so želeli zapustiti državo. No... izkazalo se je, da je šlo za Čečence.
TezkoDihanje ::
https://twitter.com/OstapYarysh/status/...
Antony Blinken: The U.S. has given the "green light" to NATO countries if they choose to provide fighter jets to #Ukraine.
-vx- ::
Na kateri frekvenci?
No dajmo "razgledanec"?
Ker, ce se prav spomnim, so Srbi rekli "Izvinite, nismo znali da je nevidljiv".
Verjetno iz istega razloga kot Rusi.
Prastar fejk, ki so ga obudili od mrtvih. Pun intended.
https://mythdetector.ge/en/disinformati...
One day after the release, the Azov Battalion responded to the video. According to their statement, the video serves to discredit them and is an example of information warfare against Ukraine. According to them, the uniforms of the persons shown in the video is different from that of the fighters of the Azov Battalion since the shoulder mark is much larger than it should be, while the weapon looks like it’s pneumatic. They also point out that the person nailed to the cross does not scream while lifting the cross, and the video stops shortly after the fire is set for the cross, therefore it is unknown whether the person really died. A statement from the Azov Battalion on Facebook also said that the individuals in the video were speaking broken Ukrainian.
Ubožčki, delujejo mi na robu živčnega zloma. Kaj bi bilo, če bi jim celo noč na glavo padale bombe? Videi na povezavi, ampak rabiš VPN.
https://www.thedailybeast.com/vladimir-...
On Thursday’s episode of The Evening With Vladimir Soloviev, state TV propagandist Vladimir Soloviev complained that he and editor-in-chief of RT Margarita Simonyan are being terrorized by unknown individuals, receiving endless calls and texts about Russia’s military activities in Ukraine. He griped: “Margarita and I can show our telephones to demonstrate that we’re getting a thousand calls and texts per hour.”
Several days earlier, two other state TV propagandists, Olga Skabeeva and her husband Evgeny Popov, also reported a barrage of calls. Skabeeva, who hosts the state TV show 60 Minutes, angrily yelled that Ukrainians or their supporters have been “endlessly calling everybody, everybody, all citizens of Russia, including me and Evgeny!” Later in the show, she loudly interrupted a panelist to grumble about being subjected to a “mass attack that started at 2 a.m... we started getting calls from the territory of Ukraine, two to three minutes apart, Ukrainian and Polish phone numbers calling nonstop... And then, text messages with threats to kill me and my family, and photos—endless photos—of corpses, which they say are the corpses of Russian soldiers!”
FilipF ::
....Ukrainian aircrafts attacking our troops are landing in Romania. The use of other countries airports will be recognized as their active participation in the conflict. -Russian Ministry of Defence....
Kolikor vem sta dve Ukrainski letali po napadu pristali v Romuniji. Eno naj bi bilo sestreljeno včeraj v romunskem zračnem prostoru, uradno je bilo tako slabo vreme, pa ga še niso našli. Zdaj smo pa v vojni z Rusijo... Bomo mobilizirali? Me prav zanima, kakšno bo veselje, ko bodo pričeli prihajati pozivi za mobilizacijo vojaških obveznikov 18 do 55 let. Pričakujem nagovor vrhovnega poveljnika vojske.
TezkoDihanje ::
https://twitter.com/Liveuamap/status/15...
Another video of an aircraft shot down over Kharkiv
Pravjo SU-25.
Samo zate:
-vx- ::
No pa smo pri bistvu. Vse skupaj je navadna hinavscina, takrat in zdaj. Samo, da zdaj bo imelo to ekonomske posledice za navadne civiliste. Cisto po nepotrebnem.
Tako kot ima preseravanje Zja posledice za Ukrajince.
korenje3 ::
ti si en ptič. Skoraj vsa letala se podobno vidijo na radarju, razlike so pa v nekaj 10% in ne več kot 30%.
dejstvo je da so zda toliko uspešni zaradi načina vojskovanja. Vse stare rakete so "dumb" rakete in se jih izstreli v smer letenja letala. Šele ko je raketa dovolj blizu začne letalu slediti. Torej če letalo spremeni smer preden raketa pride do letala ga raketa ne bo videla. Dober primer je izraelska vojska, ki velikokrat uporabi tako taktiko v siriji.
S400 za razliko ima feedback in lahko v zraku spreminja smer po informacijah iz matičnega radarja, zato je tudi tako nevaren. Karkoli že ameriška letala niso nič posebnega, samo še niso bila v vojni s pravim nasprotnikom (razen vietnam).
sej to je tisto. folk je zabit. Misli da če spustiš bombo na moskvo da bodo rusi kar gledali v luft da še kej prileti.
Po moje bi vse salvote spraznil na ameriških in evropskih mestih.
- spremenil: korenje3 ()
Tudi nemški flak bi sestrelil nevidno letalo,če bi se jim usralo.
TezkoDihanje ::
Bo že kaj na tem, glede na to, da vsa novejša napredna letala uporabljajo stealth tehnologijo. Ne samo ameriška.
Meizu ::
Preden ti prideš do šanse, da sploh streljaš na ameriška letala bo najprej treba povozit njihovo kopensko mašinerijo. Kar se mi ne zdi niti približno možen scenarij.
Aston_11 ::
Odkar so delili orožje med civiliste so vsi oboroženi, ki steljajo na naše ruse, tarča.Mejiš na genija. Da ima nekdo orožje in streljajo nanj, to mora biti nekaj posebnega, rabiš dovoljenje ali kako?
ST elita pravi, da ker je par civilistov oboroženih, lahko rusi vse civiliste streljajo.
Drugi del elite pa pravi, da niso več civili, če imajo rumen trak gor, ruski fašisti pa lahko vseeno civiliste streljajo.
Tretji del elite pravi, da če je vojak v civilni bajti, da lahko russki fašisti vse civilne bajte podrejo.
ST bo presegel sam sebe.
korenje3 ::
Kaj ti bluziš. Wagner neonacistični?
AZOV je od leta 2014 tudi del ukrajinske vlade, zato ima to toliko večji pomen. Gre za nacistično družbo (ostanke 2. svetovne vojne, ki so se razpasli po državi).
In putin jih je lepo pozval, naj se razorožijo, pa je tisti nacist zelinsky upal na pomoč amerike.
Aston_11 ::
EUR pa kar pada
Zato se vse draži. Zaradi samozadostnosti. Vse se bo ustavilo, ker EU rabi ruske surovine, ruski fašisti pa rabijo EU izdelke. PAT položaj.
Korenje verjame ruski propagandi še bolj kot povprečen rus.
Upam da si natankal svoj nemski BMW
DarkSite ::
RU letala pa kr ornk padajo dol zadnje dneve?
Koliko SU25 majo še? Wiki pravi, da jih je 193.
