Ukrajina Part II
Ukrajina Part II
enemon je izjavil:
Zeleni Vol še straši po ulicah Kijeva? Zadnje čase se bolj noter snema.
Tak kot Pahor, da malo posodobi instagram profil.
  • predlagalo izbris: l0g1t3ch ()
-vx- ::
PrihajaNodi je izjavil:
Ukrajina je samo 34% pocepljena
To razlozi vse. Trmoglavi idioti, ki ne razumejo nicesar.
Ukrajina: freedom's just another word for nothing left to lose.
PrihajaNodi ::
-vx- je izjavil:
točno, +1
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
-vx- je izjavil:
Aja, si le ugotovil? Da SU-34 ni namenjen za unicevanje tarc na tleh, ampak je njegova naloga dogfight. :))
Bohpomagi.
Sukhoi Su-34 @ Wikipedia
The Su-34 is designed primarily for tactical deployment against ground and naval targets (tactical bombing/attack/interdiction roles, including against small and mobile targets) on solo and group missions in daytime and at night, under favourable and adverse weather conditions and in a hostile environment with counter-fire and electronic warfare (EW) counter-measures deployed, as well as for aerial reconnaissance.[6][12] The Su-34 will eventually replace the Su-24 tactical strike fighter and the Tu-22M long-distance bomber.[11]
Kje ti vidiš dogfight?
Okolico Kijiva so namenoma poplavili, to
https://twitter.com/TrentTelenko/status...
People asked in the Mud and Truck maintenance threads earlier what the Ukrainians could do to make the rasputisa mud worse.
They opened the Kyiv reservoir to accomplish just that.
The Russians pushed three Tank/Mech divisions into a flood plain the Ukrainians flooded
in to
https://twitter.com/Militarylandnet/sta...
As correctly pointed out by some of you, Ukrainian troops seems to flooded the area north of Kyiv. That's the reason why the Russian advance is stagnating there.
enemon ::
Veliki Zeleni Vol grozi Rusiji, ko pa dobi nazaj, gre pa jokcat EU in Natu, naj jih rešujejo. #heroj
gazibo ::
Zdej so ga pa cist na cedilu pustil LOL
  • spremenil: gazibo ()
-vx- ::
-vx- je izjavil:
Bohpomagi.
in to
Saj je vseeno, kot sem ze rekel, lahko pridejo tudi z baloni in trokrilci, bombe iz ww2 pa lahko mecejo iz njih "na roko". Za potrebe unicevanja mest, so dovolj ucinkoviti, pa se na radarju jih ne zaznas. Zakaj za vraga bi si delal stroske z neko visoko tehnologijo?
  • spremenilo: -vx- ()
Voss ::
-vx- je izjavil:
-vx- je izjavil:
Bohpomagi.
in to
Sej druzga nimajo :))
TezkoDihanje ::
Civilne tovornjake vozijo v Ukrajino :))
saj ne moreš verjet...
GupeM ::
Baje da ukrajinski begunci ne rabijo met kovid potrdil pa testiranj za Slovenijo. Zakaj?
Zato, ker od 19. februarja to ni več potrebno.
https://www.gov.si/teme/koronavirus-sar...
Voss ::
TezkoDihanje je izjavil:
Hahahaha svašta...
Mislim, da je EU/NATO storil napako pri pomoči Ukrajini. Več kot očitno je, da donacije potrebuje Rusija.
enemon ::
GupeM je izjavil:
Lepo se je poklopila epidemija in uvod v WW3.
-vx- ::
Voss je izjavil:
Naivec. :)) Ampak konec koncev je vseeno, najboljsa resitev je vedno tista, ki vsaj pribljizno izpolni zahteve. In baloni in trokrilci jih, v dani situaciji, naravnost briljirajo. Da sploh ne omenjam, da je vsak stinger vec vreden od njih.
dice7 ::
Saj sta vx in nodi lepo razlozila. Zaceli so s starim zelezom, sedaj pa prihaja moderna oprema na vrsto
TezkoDihanje ::
antimolotov obramba:
boh se usmil...
enemon ::
gazibo je izjavil:
Nima veze, on je najjači. :D
TezkoDihanje ::
dice7 je izjavil:
-vx- ::
dice7 je izjavil:
Ne, ravno zdaj ne prihaja na vrsto. Vse kar je bilo modernega so uporabili, da so Ukrajino zbili v kameno dobo. In zdaj se bojujejo proti kamenodobnim primitivcem, ki jim se vedno ni potegnilo, da so popusili. Torej, balonski napad na Kijev. 10000 balonov (za ceno enega SU-*) z odsluzenimi bombami, ki so tako ali tako za odpad. Pa naj izstreljujejo stingerje.
-vx- je izjavil:
Namerno uničevanje mest je vojni zločin.
Danes so zaradi metanja ceglov izgubili 2 Su-34 s štirimi člani posadke, čez 70 mio $. Šparat je treba pa naj stane kar hoče logika.
enemon ::
boh se usmil...
Proti vojski z molotovkami bo to zadostovalo. Če jih pa #heroj Zeleni Vlado dobi v roko, bo pa težka.
l0g1t3ch ::
l0g1t3ch je izjavil:
enemon je izjavil:
Mislite, da bo JJ izkoristu šanso in mal preprodaju orožje gor?
Mogoče bi lahko lifral kake stare zaloge gor še od juge, če že nismo zmetal stran.
Pač da se ponuca staro železo.
Baje bodo čoln poslali gor. Tisti ki se ni na dražbi prodal od policije.
Kaj pa tista ruska brkača?
PrihajaNodi ::
Tale vojna je kot bi šla Bosna napast kosovo.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
He(Jens Stoltenberg, the secretary-general of NATO) said helping Ukraine protect its skies from Russian missiles and warplanes would require NATO forces to shoot down Russian aircraft, a move that could result in a "full-fledged war in Europe involving many more countries".
"We are not part of this conflict," he said.
"We have a responsibility as NATO allies to prevent this war from escalating beyond Ukraine because that would be even more dangerous, more devastating and would cause even more human suffering.
NATO pluje v pravo smer. We good guys ;)
PrihajaNodi ::
enemon je izjavil:
Mislim da je na popravili al pa se še čaka da pride.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Voss ::
Hahahhahahahaha
l0g1t3ch ::
-vx- je izjavil:
Predal se verjetno ne bo, je preveč psiho.
Upanje ostaja da ga pihne kdo od lastnih.
Katerih "lastnih"? Vecina premoznih v Rusiji, so tam zato, ker jih je Putin nastavil, vecina pa je njegovih "sosolcev" v KGB. Kdo ga bo pihnil?
Putin ne bo večno.
Ali čakaš naslednika, ki ti mogoče ne bo povseci ali pa vse skupaj malo pohitris.
Sploh v trenutni luči.
dice7 je izjavil:
Rusko sranje so Američani uničili v vsaki vojni zadnjih 60 let. Fani so pa potem jokali,da ima Rusija super duper robo doma v skladiščih.
-vx- ::
-vx- je izjavil:
Prav briga jih. Ukrajina je pa izgubila nekaj sosesk za trikratnik te cene. Zaradi lastnega idiotizma se bojo pobirali iz tega sranja se 20-30 let, cetudi se Rusi v tem momentu obrnejo in se nehajo bojevati. Tolazba za bogove.
Voss ::
-vx- je izjavil:
-vx- je izjavil:
Nevem, če si zasledil koliko milijard pomoči bo namenjenih za obnovo Ukrajine.
Rusi bodo pa še brez te stare krame, ki jo imajo ostali :))
PrihajaNodi ::
-vx- je izjavil:
-vx- je izjavil:
Je kdo razmišljal kako bo ububožala evropa ko to vse te ukrajinke prišle v evrope se oženile z evropejci in jim vse pobrale?
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
-vx- ::
mackilla je izjavil:
Seveda, idioti pa niso dojeli, da ne glede kaksno orozje je uporabljeno, sesuto mesto je se vedno sesuto mesto. Ne glede na "modernost" orozja.
LightBit ::
-vx- je izjavil:
-vx- je izjavil:
Ukrajina je Rusija po Putinovo. Sebi uničuje. Razen če namerava izgubiti.
enemon ::
-vx- je izjavil:
-vx- je izjavil:
Evo to je strateško razmišljanje.
-vx- ::
Voss je izjavil:
Ne vem, ce si zasledil, da bos te miljarde placal ti. In to za vojno, od katere EU nima nic, je bila inscinirana s strani ZDA in tudi oni vlecejo vse profite, EU pa samo pusi kurac.
enemon ::
-vx- je izjavil:
Voss je izjavil:
Ukrajini je treba pomagat, model! Pa če vsi pocrkamo zaradi tega.
-vx- je izjavil:
dice7 je izjavil:
Kameno dobo bodo imeli Rusi doma počasi, če bo Putin še malo pameten, pa jih bodo ekonomsko uničili... Ruski vojaki bodo pa streljali v Ukrajini, dokler bodo rublji na računu in hrana na bojišču... potem pa pa pa in gotovo!
l0g1t3ch ::
enemon je izjavil:
To da rečes bivšemu da ti mi več za biti z njim je sedaj grožnja?
In če deklina dobi plav uč si je pač zaslužila ane.
Novemu tipu pa zagrozis da ga boš ustrelil če bi si drznil deklini kaj pomagat.
A tako torej delate rusofilski macoti
-vx- ::
enemon je izjavil:
-vx- je izjavil:
Voss je izjavil:
Ne. Iraku nismo pomagali, nismo pomagali Libiji. Za koji kurac bi zdaj pomagali Ukrajini? Ker je Z porn star socialnih omrezij?
Nimam problema s sprejemanjem beguncev, s humanitarno pomocjo. Vse ostalo je over the edge.
Voss ::
-vx- je izjavil:
Voss je izjavil:
Na žalost bomo mi pokrivali stroške tvojega Hitlerja ja... Mislim Rusija je itak bankrot, jih ne bi mogli pa četudi bi želeli :))
PrihajaNodi ::
Recimo, dober napad na američane ukrajincev pa rusov je bilo oglaševanje: Russian/Ukrainian brides. Kjer so potem stari cepci hodil tja iskat žene in v stari dobi pa izgubili vse. Kao da so to pridne in tradicionalne žene.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Maxlos ::
-vx- je izjavil:
Comandante je izjavil:
-vx- je izjavil:
Zato pa z njihovimi SU-34 (ki so relativno dobra letala) letijo na 300m in so hrana za Stingerje. Ker iz 3km visine z navadno bombo ne mores zadeti nicesar. Uporabljajo tehniko bombardiranja iz druge svetovne vojne.
Neumnost. To je pribljizno tako, kot bi rekel, da A-10 letijo na 300m zato ker uporabljajo tehnologijo iz ww2. Ne. SU-34 je podobno kot A-10 namenjen za unicevanje zemeljskih tarc in ne za bombandiranje iz stratorsfere.
A-10 in SU-34 sta dve popolnoma razlicni letali, za popolnoma razlicne naloge.
Aja, si le ugotovil? Da SU-34 ni namenjen za unicevanje tarc na tleh, ampak je njegova naloga dogfight. :)) Me veseli, da ne mesas teh dveh letal (tako kot jaz /s)
Verjento si SU-34 zamnejal z SU-25. Su34 nima za burek, ko danes, ko več ali manj konkretno sneži, oblaki so pod 1000 metrov, manpad pa na vsak kilometer fronte nekaj kosov.
Z na smrt bolno frocarjado se gredo flashmob v podporo "specialne vojaške operacije".
-vx- je izjavil:
A si retard? Putin si hoče priključit Ukrajino zdaj jo bo pa zravnal z zemljo. Kdaj bo pa sploh uporabil moderno orožje? Pet minut preden mu bodo eksplodirale ameriške jederske bombe?
enemon ::
enemon je izjavil:
Dogovorjeno je bilo ob razpadu SZ, da Ukrajina in ostale postsovjetske države ne bodo rinile v Nato. A tako se vi držite dogovorov, ukrajinski heroji.
-vx- ::
-vx- je izjavil:
Ne zeli si jederskih bomb, ker bos jedel lublje naslednjih 10 let. Bedak.
enemon je izjavil:
Kot da bi užaljeno mono poslušal, tik preden spusti krokodilje solze.
Maxlos ::
-vx- je izjavil:
Pac samo bedak bo metal na nasprotnika nekajkrat drazje bombe, ce pa stare in poceni ravno enako dobro pocijo. Se enkrat, za ravnanje mest z zemljo ne rabis natancnosti.
Kera logika. Ej, za uničenje cilja rabiš bistveno več dumb bomb, kot pa pametnih.
Ti kar vzameš, da z eno dumb bombo narediš tisto, kar narediš z eno pametno.
Poleg tega razbiješ vse naokrog, da je lokacijo lažje branit.
Povej nekaj ameriških opracij, ki so se izvajale v takem vremenu... Verjeno nazanje v Korejski vojni, pa še to ker so bili tam, ne da so imeli izbiro vremena..
PrihajaNodi ::
-vx- je izjavil:
-vx- je izjavil:
Jst sm si Jod kupil. Imam sedaj jod pa ivermektin. Nikol ne veš kdaj in kje je hudič
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
l0g1t3ch ::
-vx- je izjavil:
Voss je izjavil:
Jaz sm slišal da je NWO.
Pa reptili.
enemon ::
Pacman, pejd telefon nafilat, baterijo maš na konc.
341 / 859
