Ukrajina Part II
FilipF ::
Ne napadamo civilov press
Pa saj to je isto kot Stalingrad. Poglejte si slike
Rusofili vss ni nič sram da podpirate vožda ki uničuje in načrtno pobija civile?
Da ne bo to isti blok, kjer je civil z teleobjektivom slikal tank, potem pa se je pritoževal, da streljajo na civile.
Ni slikal, mu je padel teleobjektiv na tank, ker niso hoteli tvegati svojih življenj kot naborniki - mirovniki, so pač opravili svoje delo.
Pridejo naborniki-mirovniki... vojska totalno nesposobna, se predaja.
Pridejo vojaki... zločinci.
Pridejo specialne enote... nima kdo več poročat, zgleda, da hočete takšno rešitev.
- spremenilo: FilipF ()
pirat ::
Pogajanja končana, žal brez pravega napredka... Naj bi vzpostavili koridorje za umik civilistov, ampak nič dorečeno kdaj...
Talks end, Ukraine disappointed with results - negotiator
The second round of negotiations between Russia and Ukraine has ended, and Kiev is not satisfied with its results, negotiator for the Ukrainian side and Adviser to the Head of the Office of President of Ukraine Volodymyr Zelensky Mykhailo Podolyak said on Thursday.
The two sides have agreed to coordinate on establishing humanitarian corridors, and vowed to suspend hostilities to allow for evacuations to take place at times that will be designated at a later point, he added in a tweet.
The third round of negotiations is expected to occur "soon," Podolyak said without elaborating. The Russian side confirmed the agreed-upon points and stated that there has been "substantial progress" in the talks.
Putin pravi da so rusi in ukrajinci en narod. Identično je govoril Hitler za avstrijo...
Ce norca ne ustavijo bo Putin drugo leto v Parizu
Zakaj bi ga ustavljali drugi. Zakaj ga ne ustaviš ti?
Poglej hrvati so jih že poslali 200. Torej, za kanon futer boš že dober.
Bela_Krajina ::
Kako gre ze tisto, ko pravijo, naj vrze kamen tisti, ki je brez greha. Torej gospoda tukaj, ste vi brez greha, da lahko na druge mecete take kritike? Ste vi nedolzni mogoce, brezmadezni, angeli? Ste sebe ze zbrcali, ce ste slucajno kaj zagresili? Ali pa ste morda prevec pristranski glede sebe?
Maxlos ::
Bela_Krajina je izjavil:
Please stahp.
Maxlos ::
Na Telemachu več ni ruskih programov.
02.03.2022 18.03
Prekinitev predvajanja ruskih programov
Obveščamo vas, da pri Telemachu ruskih programov ne prenašamo na podlagi določil Uredbe sveta Evropske unije z dne 1. 3. 2022, ki operaterjem oddajanje teh programov prepoveduje.
https://telemach.si/prekinitev-predvaja...
Sn preveril in res več ni RT med kanali.
Skačeš do plafona?
Ukolikor ne, zakaj ne?
Saj pa RT.com je ena sama velika laž.
/s
Ali počasi celi ti vohaš, da tukaj nekja smrdi?
Ja sem že pred nekaj časa ugotovil, da ruske države medije ne mislim poslušati ali gledati. Če pa tebi paše brati ruski RT katerega so ustanovili na idejo/predlog Putina ga pač beri. Jaz ga pač ne bom.
Važno da gledaš samo tistega pravega. Pač enoumje, je blagoslov za produkt kapitalista.
nejcek74 ::
da da, še vedno ista pesem, baba naj razpre noge da bo FilipF opravil delo, potem pride še vx-, pa še Solecus, pa Valvoline, cela parada enih in istih izmečkov pod vedo novimi nicki, vsi se bo zvrstila na njej, vsi ti troli, ki trobijo eno in isto zgodbo. Vse je kul, če bo pa baba zajamrala, jo boste pa počili, prebutali, kaj se pa dere, sama je kriva. Naj bo vesela tehle junakov iz ruske stepe. Potem naj odide v kuhinjo in jim skuha večerjo. Naj bo vesela, da ji pustite živeti.
Meizu ::
Bela Krajina je pozabil en večer sklopit šparget in mu je scvrlo kalkulator v glavi, zdej pa meče ven 404 error.
Mogoce smo premajhni in bodo znukal slovenije. Po drugi strani pa imajo tolk jederskih konic, da ni problema vseh prestolnic drzav zveze NATO znukat.
Puti pa je navaden psihopatski zlocinec. Njega in ostale kleptokrate bi bilo potrebno dati pred strelski vod, pa zaplent vse premozenje, da tudi njihovi morebitni potomci ne bi imel koristi od nakradenega.
Zakaj pa ne dokazes, da si ti boljsi, da si dober clovek, ki drugim zeli dobro, ki drugim zeli vse najboljse. Preberi svoj komentar, pa bos hitro ugotovil ce to pocnes. Ali pa pocnes kontra? Kaj pravis? Ali ima kdo pravico se pritozevat, ce tudi sam ne zeli dobro drugim?
Mislim, da imas ti zmesane pojme. Kaznovanje zlocincev je nujno potrebno, prav tako je potrebno prepreciti, da bi imeli kakrsnokoli korist od nakradenega. Lahko pa mi poves kje da te brcnem ven in se vselim in pokazes kako se nastavi se drugo lice.
A si tudi mnenja, da je potrebno kaznovat tiste, ki se vsak dan lazejo? Bi brcnil recimo laznivca, ki vsak dan laze?
Kaj zelis povedati?
kuall ::
Je rekel hitler, da so ukrajinci in rusi en narod .. je kdo razbral skrivno geslo te izjave?
Ko je šel Hitler na Rusijo, je bilo udeleženih 180.000 kolaborantov iz Ukrajine
Ni čudno, poglej kaj jih je doletelo: suženjstvo pod komunajzarji 100 let, ki se še danes ne neha. hitler, putin, same shit.
Blo je zraven še precej hrvatov, pa še pol evrope kolaborantov. l.1941.
Tud Napoleon je zbral v bistvu l. 1812 vseetropsko vojsko ko je še na Rusijo.
Tud zaj se cela evropa štuli zraven. Evidentno je, tud, da če napade Slovenija z svojimi letečimi mopedi, bomo vsaj na začetku zmagali, ker bojo celi bataljoni rusov umrli od smeha, ko bojo to vidli.
Še posebej izpostavlja preobrat Nemčije. "To, da je Nemčija začela pošiljati protitankovsko in drugo orožje Ukrajini, je moralno izjemno sporno. Nemci ne bi smeli nikoli pozabiti, da so nacisti med 2. svetovno vojno pobili 27 milijonov Rusov. Tega madeža se ne bodo nikoli rešili. Zato ne ne morejo zdaj obrniti krmila, to je moralno izjemno sporno."
Haha rtvslo bo vozila samo rusofile komentirat dogajanje?
 Lepo relativiziranje vpada rusov na ukrajino ;)
Lipuscek je kolaborant
- spremenil: endelin ()
Maxlos ::
No vidiš, Nečija je imela pred hitlčerjem vse v razulu, pa so začeli z vojaško industrijo, pa vemo kje se je končalo.
Zanima je tudi časovnica new deal.
nejcek74 ::
jp, tule mu je pa res ušlo izpod nadzora. Nekako ni mogel zdržat brez čustvenih besed. Škoda da ni še kaj o slovanski bratovščini, ki tako lepo skrbi druga za drugega navrgel. No, recimo da to, da mati Rusija tako rada zlorablja svoje sorodnike.
Maxlos ::
da govori se cca 1.6 mijona, moram preverit.
Bela_Krajina ::
Glejte, sem vam ze prej povedal, vec uspeha boste imeli, ce poskusite na lep nacin. Pac, en me je prej lepo prosil, ce lahko mal neham. Pa sem potem res kar nekaj dni, sem si vzel cas in nic nisem pisal. Za vojno v ukrajini, morm priznat, nisem se mogu vzdrzat, ker to je pac dost pomembno, saj je bliz slovenije. Tko, da upam, da ne zmaerite. Mal sem se razpisal o tem tukaj. Ampak, glej, lepo reces, ej prjatu, a lahk naredis eno mejhno uslugo, si nekaj dni vzames prosto pa ne pises tukaj. A je to tako tezko za narest?
Maxlos ::
Orožje ima tudi življensko dobo.
Nadgradnja tomahawk na bloc 4 je bilo ceneje kot demontaža block 3.
Izgleda se bo rtv spet obračala pač bedno.. . V času covida so se dobesedno norca delali ko je po studiu letal Zlatko z raztrgano masko, ko so promovirali antivaxerje, dokler slednii niso vpadli v Rtv stavbo. Sedaj bodo pa vodili same Lipušče in občasno celo kakšno mnenje, kjer bo kdo kritiziral Putina. ja, če 100x ponovite da bi se morali ukrajinci ulečt pred rusi bo resnica. Se več lipuscka prosim :/
 ja, če 100x ponovite da bi se morali ukrajinci ulečt pred rusi bo resnica. Se več lipuscka prosim :/ Zgodovina sprememb…
Maxlos ::
In par sto tisoč ruskih kolaborantov,če nisi vedel.
Sej boš brez problema našel tvoje vire. Pomagam ti , da ne boš preveč iskal "Operation Barbarossa", se imenuje invazija na Sovjet Union. Pač da ne bo preveč naporno.
Samo letnica je druga
https://old.delo.si/sobotna/kar-je-dovo...
Tomaž Mastnak ne pomni takega >>enoumja<<, kot ga je evro-ameriška globoka država vzpostavila v propagandni kampanji proti Putinovi Rusiji, hrvaška profesorica Jelena Jurišić pa poročanje glede krize v Ukrajini označuje za dokončno smrt novinarstva, >>ki je postalo zreducirano na nekritično povzemanje sporočil ameriškega State departmenta<<.
- spremenilo: sbawe64 ()
nejcek74 ::
ne bo treba, vsi vemo da je Putana ročno nalomil Hitlerja, nobene vojske ni bilo potrebne. To je samo zarota kuščarjev.
Russian Liberation Army. Za začetek,da se ne boš razpočil.
- spremenilo: mackilla ()
Močne eksplozije v Kijevu danes. NATO kaj točno čakaš? Daj že spreglejte ta jedrski blef in zbombandirajte okupatorje. Čas je, da to mirovno operacijo prekinemo.
Iščejo ruske podmornice. Zadnje čase Ameriške nehote zahajajo v ruske teritorialne vode, in Ameriške podmornice kot kaže že nekaj časa spremljajo letalonosilko floto kar z aktivnim sonarjem. Zgleda so te nove ruske cigare precej tišje, in kvalitetnejše narejeno kot T72 v Ukrajini.
Malo bolj se poduči ... vsaka ameriška letalonosilka ima spremstvo podmornice in bojne ladje. Tak je pač protokol. Zdaj, ko je ozračje napeto, še posebej, ker so rekli, da so zaznali premik jedrske ruske podmornice, pa itak, da bodo američani naredili vse, da bodo z vsem na tekočem nad in pod vodo.
FilipF ::
Si bil v vojski kot nabornik, koliko mesecev si se igral s pravim orožjem? Sicer nisem navijač nobene strani, kot vojni veteran si pa dovolim komentirati dogajanje, ki sem ga sam preživel.
Čenče s State of the Union, jemite s šleparjem soli. Verjetno mislijo Putina.
https://blindgossip.com/the-state-of-th...
The State of The Union address is an opportunity for all the Members of Congress to be together in one place.
When Senators and Congresspeople get together, what do they do?
They gossip!
The most interesting gossip coming out of last night’s gathering was about the mental and physical health of a famous male politician.
While there were varying opinions about his mental health, there was some agreement about his physical health.
There was some dissent about exactly what kind of cancer he has. One said stomach cancer, one said colon cancer and one said colorectal cancer.
Although there was some dissent, those are still fairly consistent diagnoses.
Could these illnesses explain his appearance and/or his behavior?
They gossip!
He is not a well man. I’m not talking about his mental state. I’m talking about his physical health.
According to [redacted] and [redacted] and [redacted], he has Parkinson’s and cancer.
Maxlos ::
To da si nerazgledan, ni potrebno potrditi. Drugače bi šptevilke že vrgel na plano in nam /mi zapru gobec. Kot kaže, ti je to že mentalni napor, ko moraš celo brati.
kje so bili levaki včeraj, ki tako radi protestirajo proti diktaturi in hitlerjem????
Plenicke so menjavali.
Valvoline ::
Ukrajinski predsednik Volodimir Zelenski je povedal, da je na poti v Ukrajino okoli 16.000 tujih borcev, ki so se prostovoljno javili za boj proti ruskim silam. Za "obrambo Ukrajine, Evrope in sveta".
V Kijevu vzpostavili Mednarodno legijo teritorialne obrambe
Thats the spirit!
 čeprav cifra je sigurno potegnjena iz riti. Vsak fura propagando valda
 čeprav cifra je sigurno potegnjena iz riti. Vsak fura propagando valdaSedaj bodo tudi ukrajinci imeli kar nekaj Wagner/cechen like psihopatov na svoji strani.
PrihajaNodi ::
Kje je Pithlit?
Ce hrvatje pridejo v Slovenijo jim recem vse vzemte skup s parlamentom
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
PrihajaNodi ::
Malo tu, malo tam, se kar zajebavajo s tem kovid papirji pa certifikati so pa ukrajinci tega upraviceni, ne rabjo nobenih potrdil. Pac se virus med njimi ne siri. Cluj bo dobil cel kup izbeglic. Vprasanje kam z njimi. To ni glih delaven narod. Najbrz bodo na socialni zenske pa vemo kaj bodo pocele.
Ps. Bil v cluju in Bukaresti.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
FilipF ::
Ruske podmornice so izplule pred dvema dnevoma z 800 bojnimi glavami, spremljajo tudi premike mobilnih jedrskih enot po Sibiriji. Za EU so v Belorusiji, da ne leti predaleč, da nimaš časa reagirat. Nam najbližje skladišče USA jedrskih bomb je Aviano.
Moje mnenje: rusi bodo napredovali in v naslednjih nekaj dneh pade vsaj eno veliko mesto.
PrihajaNodi ::
Ti po pravic povem nisem ne za ene ne za druge. So pa vsaj kovid ustavl
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
IgorCardanof ::
Sej ti se zavedaš, da so ta pogajanja samo zato, da se "popravi" sliko v javnosti kako Rusija izpade? Putin je že rekel, da hoče imet celo Ukrajino.
Ne odgovarjam na DM.
Samael ::
Čez 20 let bi znalo bit Ukrajincev več kot Rusov. Morda se pa tega Putin boji.
Seveda se boji, samo o tem še razmišlja. Sploh odkar se je naš Počivalšek prijavil na razpis za Ministra za delo, družino in socialne zadeve v Ukrajini. Veš koliko bo to Ukrajincev čez 20 let ...
Samael != Samuel
WallSreet ::
Ah, ATTEN-HUT!
Muthafuckas don't you move
I got what is takes to make your ass feel (?)
You don't wanna rest in this parade
No Limit soldiers throwin grenades!
Strictly, heavy artillery, calm and gunnin
I got your ground troops runnin from INCOMING!
Go, go go go, the fifty caliber
Bout to rip your (?) vest, split your capita
The ***** be marchin in the land camp
Bitch we ghetto soldiers, the streets is what made us!
No LBE's, no MRE's
But we kill our enemies, and drive humvees!
At ease when we rank, salute cause we scrap
Fools run they trap, soldiers bust caps
Fools die a million deaths, solider dies once
Put that on my gold teeth, my gat, and my blunt
Candy painted hummer, triple gold D's
We bout it, eyes hella red gone off green cause we rowdy
- spremenilo: WallSreet ()
Russian Liberation Army.It is estimated that anywhere between 600,000 and 1,400,000 Soviets (Russians and non-Russians) joined the Wehrmacht forces
FilipF ::
Sploh ne vem zakaj naj bi padlo kakšno veliko mesto. Verjetno je ta trenutek cilj, napotiti 5-7 milijonov beguncev v EU. Bodo EU sankcije prej prijele tudi v EU. No mi smo že pripravljeni na 180 do 200k.
IL_DIAVOLO je izjavil:
Quote ki pase v ta cas.
Humanity Invented the Atom Bomb. No Mouse in the World Would Think of Building a Mousetrap
"The difference between the humans and animals: Animals would never allow the dumbest ones to lead the pack!"
Putin res ni glih naglihan.
https://twitter.com/maxseddon/status/14...
Putin speaking to his security council.
"I will never abandon my conviction that Russians and Ukrainians are one people [...] but the way the battle is going shows we are fighting neo-Nazis."
He claims Ukraine is using civilians and foreigners as "human shields."
