Ukrajina Part II
Ukrajina Part II
Vanich ::
GTX970 je izjavil:
Kam spada pokop vojakov v neoznačene grobove ?
Ter da potem post mortem dobijo medaljo za hrabrost, ki jo lahko dobijo samo v boju (in so bili uradno nekje globoko znotraj RF) ?
Kot drek od človeka lahko označiš kvečjemu Ruse, Vladota za začetek.
Kot drek od človeka bom jaz sedaj označil Ukrajince, z Porkošenkom na čelu - za začetek in konec.
SimplyMiha ::
Zheegec je izjavil:
They seem to be amassing a few troops
To delajo že vse od začetka ukrajinske krize. Nič novega, tam stalno furajo vojaške vaje, da ja ne bi NATO ne Porošenko postala predrzna.
SimplyMiha je izjavil:
Zakaj pa? Da ne bi Ukrajina, ki ne more premagati niti "upornikov" v Donbasu, naredila invazije jedrske velesile in zasedla Volgograda in Moskve?
SimplyMiha ::
Ne. Da ne bi Ukrajina slučajno začela izvajati etničnega čiščenja.
Vojaške vaje, kjer letijo rakete in granate iz Rusije via Ukrajina, večina vojaške opreme na vajah je brez taktičnih oznak, sem in tja se pa kakemu vojaku celo uspe izgubit na teritoriju sosednje države? Pajade, maskirovka.
https://www.bellingcat.com/news/uk-and-...
When screening for possible firing positions from this trajectory, the Bellingcat investigation team found a firing position 14.6km from the crater field. Burn marks are visible at this location, which is on Russian territory and approximately 750m from the border near the Russian village of Seleznev at the coordinates 47°38'13.52´´N 38°28'9.69´´E.
On 17 July 2014, a series of videos were shared on YouTube and VK showing an attack with MLRS launchers. The attack occurred on 16 July 2014 in the vicinity of Gukovo, Russia. This attack has already been located by a number of blogs and articles, for example by the Interpreter Magazine.
The Bellingcat investigation team has found six videos on social networks that show the events of 16 July 2014 near Gukovo. Two of these videos were captured from the edge of the Kovalevsky pond on the afternoon of 16 July 2014.
On the satellite image below, taken 8 August 2014, the intersection of the lines clearly shows two visible burns, marking the firing position.
 The intersection of viewing directions and the location of Grad firing positions
The calculated trajectories of the burn marks point towards two different crater fields on Ukrainian territory (image below). After analysis of the individual craters in the artillery strike site, we found that the calculated trajectories of the firing positions fit almost exactly the two trajectories determined from the artillery crater analysis of the crater field near Dolzhanskaya-Capital mine.
 Trajectories from the firing position north of Platovo to the target area around the Dolzhanskaya-Capital mine
Thus, from the evidence of crater field analysis, social media geolocation, and local media reports, the Bellingcat investigation team has determined that the artillery attacks on the Ukrainian armed forces positions near the Dolzhanskaya-Capital mine were conducted on 16 July 2014 from firing positions near Gukovo, within the territory of Russia.
On 12 August, the separatists, via their so-called "Information and Analysis Agency South East" posted two videos entitled "Destroyed position of the 'heroic' 72nd Brigade APU near Sverdlovsk, Lugansk region."
The Bellingcat investigation team has located the camera position of these videos as being in the crater field in the vicinity of the Dolzhanskaya-Capital mine.
Na povezavi je vsega še več
  • spremenilo: Pac-Man ()
SimplyMiha ::
Žal bellingcat ni kredibilen, in to ironično dokaže najbolj nekredibilni novinar na svetu: Bellingcat - Caught Up, and Out in Yet Another MH17 Falsification
Nekoliko manj ironičen link:
https://wikispooks.com/wiki/Bellingcat
Napaka je na strani Correctiv-a.
Bellingcat je Krasnoprošina uporabila samo za povezavo med konvojem Buk-ov iz Kurska do ukrajinske meje in 53. brigado zračne obrambe.
Npr.:
 On the left: a truck in the convoy to Alexeyevka on the 24th of June. On the right, the same truck photographed by Sergeant Ivan Krasnoproshin of the 53rd Buk brigade in Kursk. The license plate reads 0639AH50.
SimplyMiha ::
Dobro, to ni edini primer - tale Graham Phillips do beilingcata ne čuti preveč ljubezni (malo pobrskaj po njegovem blogu).
Phillips je popolnoma nesposoben - današnji primer je že drugič, da je "outal" ruske enote v Ukrajini.
SimplyMiha ::
Tudi slepa kura kdaj zrno najde.
s1m0n ::
Tudi, če je kdo kredibilen bodo vedno našli poti kako vir naredit ne kredibilen!
Dokazov je na morje ampak nikogar ne zanimajo ali pa se po tiho pometajo pod mizo.
Poročilo atlantskega sveta "Hiding in Plain Sight: Putin's War in Ukraine" je zunaj
http://www.atlanticcouncil.org/publicat...
PDF:
https://www.dropbox.com/s/7uzlm8aspdls5...
Martin Krpan ::
A tako kot srbi v BiH?
Vanich ::
  • spremenil: Vanich ()
Vanich ::
Martin Krpan je izjavil:
Ne, ampak tako kot hrvati v Krajini. Ali pa še prej - v NDH.
Martin Krpan ::
Putka podatke o smrti ruskih vojakov v "miru" razglasil za vojno tajno.:O
Ziher zato ker ruski vojaki NE sodelujejo v bojih v ukrajini.:P
http://novice.najdi.si/predogled/novica...
Vanich ::
Najdi javne podatke o številu ubitih SAS-ovcev leta 1999 na Kosovu.
Ma; saj ni bilo nobenega. heheheee.:))
Martin Krpan ::
Vanich je izjavil:
Potem si lahko popolnoma brez skrbi. Če bo ukrajina začela izvajati etnično čiščenje ga bodo 100% izvajali kot srbi v BiH , ne pa kot hrvati v (u)krajini ? ali še prej v NDH.:D
Vanich ::
Vanich je izjavil:
Glede na že videno, se bodo Ukrajinci (še naprej) zgledovali na hrvate iz NDH.
ZaphodBB ::
Seveda ne. Bili so na dopustu.
Kaj ko bi prenehal z ad hominem napadi in se posvetil dejstvom?
Na, za začetek par strani iz poročila Atlantic Council-a
Avtorji so:
Maksymilian Czuperski
Special Assistant to the President, Atlantic Council
John Herbst
Director, Dinu Patriciu Eurasia Center, Atlantic Council and former US Ambassador to Ukraine
Eliot Higgins
Founder, Bellingcat and Visiting Research Associate, Department of War Studies, King’s College London
Alina Polyakova
Associate Director, Dinu Patriciu Eurasia Center, Atlantic Council
Damon Wilson
Executive Vice President, Programs and Strategy, Atlantic Council
Vanich ::
ZaphodBB je izjavil:
Saj pravim. Samo, Putin pa mora objaviti vse sproti, najraje v New York Times-u v osmrtnicah vsak dan. Čisto normalno, da se te stvari ne objavljajo in so skrivnost.
Martin Krpan ::
Vanich je izjavil:
Vanich je izjavil:
Dokazi ?
Vanich ::
Kje ti vidiš "ad hominem" napad? Kje?
Evo ti dejstvo, kdo sestavlja AC in kdo je naročil in to in vsa druga poročila:
Condoleezza Rice: Bush's second secretary of state—and Atlantic Council honorary director—hid her connections to Hamas by refusing to negotiate with it.
William Webster: The only man to ever helm the CIA and the FBI, Webster served under Presidents Carter, Reagan, and George H.W. Bush and is an honorary director at the Atlantic Council.
Robert Gates: Gates, an honorary director, was George W. Bush's last Secretary of Defense (and President Obama's first).
James A. Baker, III: An honorary director of the Atlantic Council, Baker served as a chief of staff for Presidents Ronald Reagan and George H.W. Bush.
Michael Hayden: Another honorary director, Hayden was a CIA director under George W. Bush.
James Woolsey: President Bill Clinton's CIA director is a member of the Atlantic Council's board of directors. You may have seen him at Big Journalism's sister Breitbart publication, Big Peace.
William H. Taft, IV: "Get on the raft with Taft" was the campaign slogan of this Council director's great-grandfather. You know who else used rafts?
George P. Shultz: Reagan's secretary of state for seven years is an Atlantic Council honorary director.
Henry A. Kissinger: President Richard Nixon's Secretary of State sits on the Atlantic Council board of directors, when he's not busy mentoring Sarah Palin on foreign policy and blaming Hamas for obstructing the peace process.
Rupert Murdoch: Murdoch was the winner of the Atlantic Council's 2008 "Atlantic Council Leadership Award,"
CIA, snajko, CIA. Upropastiše pola sveta.
(Balkanski špijun)
Oh, ja...
Ad hominem @ Wikipedia
An ad hominem (Latin for "to the man" or "to the person"), short for argumentum ad hominem, means responding to arguments by attacking a person's character, rather than to the content of their arguments.
Napadel nisi niti enega argumenta, samo Atlantic council posredno, kao "oni pa res nimajo kaj govorit". Ad hominem, sem že rekel.
Atlantic Council lahko govori/piše, zagotovo pa niso nevtralen in kredibilen vir.
SimplyMiha ::
Evo, že razprodajajo državno premoženje: Yats To Washington: Please Buy Ukraine
Livestream s predstavitve Hiding in Plain Sight: Putin's War in Ukraine and Boris Nemtsov's Putin. War. če bi kdo gledal:
Vanich ::
..."neodvisno poročilo", ki ga je izdala "neodvisna organizacija":D , ki jo spet, čisto slučajno, sestavljajo najmanj trije bivši direktorji CIA, sekretar za obrambo in pa državni sekretar USA!!!;(( Da ostalih karakterjev sploh ne omenjam.
Res, "neodvisno" in "objektivno", da ne mora biti bolj. :))
s1m0n ::
To še ne pomeni, da navedene stvari ne morejo držati. Imajo 100% bolj zanesljive vire kot vsi tukaj.
Je pa drugo, če se stvari priredijo ali napihnejo.
SimplyMiha ::
Tega pa ne trdite, ko gre za ruska poročila. Hm.
Vanich ::
s1m0n je izjavil:
...diskreditira jih na celi liniji avtomatiš. A damo še malo virov od Putina gor? On ima tudi zanesljive vire.:))
s1m0n ::
Od kdaj bodo pa zanesljivi viri od Rusije? Ah dajte no!
  • spremenil: s1m0n ()
Vanich ::
s1m0n je izjavil:
I rest my case.:))
Vanich je izjavil:
Ti kar. Upam, da so tako huronsko smešni, kot tiskovka obrambnega ministrstva o MH17.
s1m0n ::
Pustimo ljudi pri miru, ki ne razumejo, da bo Rusija ponaredila/prikrila vse kar je možno za ta dejanja od MH17 (BUK SA-11) do zadnjega mrtvega Ruskega vojaka na Ukrajinskem ozemlju!
Vanich ::
Vanich je izjavil:
Čez tiskovke od Psaki, je ni bilo nobene. Škoda, ko so jo zamenjali.
Ma ne, boljše so od Nulandove, tala piškotke.
Algorithm complete, rebooting.
Psakijeva je pa na porodniški, bro.
Vanich ::
Lahko da, samo so jo pred tem "povišali" na drugo delovno mesto.
Vanich ::
PSA:
https://www.bellingcat.com/resources/20...
Upam, da bo konec debat kaj je in kaj ni T-72B3.
Ja, šur. :)
windigo ::
Tako, zdaj že čisto iz forumsko športnih vzgibov me zanima, kako je mogoče spervertirati pogled zunanjega opazovalca na trenutno stanje v Odessi na znane Putka-Putler slogane:
Restless in Odessa
Matako ::
Ruskih žrtev v Ukrajini je konec, saj jih je Vovo preprosto... prepovedal.
http://www.dnaindia.com/world/report-vl...
Konec preplaha, vse je pod kontrolo.
/\/\.K.
  • spremenil: Matako ()
s1m0n ::
Kakšne žrtve? saj jih nikoli ni bilo :)
Matako ::
s1m0n je izjavil:
No ok.. "nesreče na dopustu". Jbg. aktivnemu dopustniku se lahko vse zgodi, to je res.
/\/\.K.
Matako ::
Uf, konec je s simpatičnimi, nadvse mičnimi Medvedjevimi dekleti...
Sedaj prihajajo na net nazaj stari Putinovi troli. :8)
http://time.com/3901303/kremlin-trolls-...
/\/\.K.
Matako ::
Iz zgornjega članka:
She described how the trolls manage several social media accounts under different nicknames, such as koka-kola23, green_margo, PepcaKardelj, SimplyMiha and Funornotfun. Those in her department had to bash out 160 blog posts during a 12-hour shift.
NOT.... samo šala! Mal heca.:))
Ampak bolj resno... dejansko pa preseneča kako na industrijski ravni je vse organizirano. Kapo dol, bi rekel Katanec. Realno gledano je to sicer poceni zabava - vpašanje sicer koliko je učinkovito.
/\/\.K.
SimplyMiha ::
Matako je izjavil:
Pa ravno sem pri branju začel grabiti šop koprive, s katerim bi te oklofutal...
Zdaj me pa roka srbi! Res hvala :|
Velika galerija Milčakova, Slavjana in Karlamove - v bistvu cele zasedba slavnih iz Rusije uvoženih fašistov med naci-pogansko daritvijo v Donbasu. Skurijo en hleb kruha.
https://vk.com/dnrarmy?z=album205292010...
Ker je folk sprogramiran, da trza na dvignjene desnice, samo teaser:
in še Novorusija-Cola:
46 / 859
