Forum » Pomoč in nasveti » Nujno windows 8 zaklenjen
bela120 ::
Torej kupili smo nov računalnik naredila sem hotmail naslov in pozabila geslo seveda kot po naklučju nisem vnesla prave tel št za potrditev ne spomnim se poponoma nič od gesla.Računalnik se prižge in pokaže e naslov ter zahteva geslo torej ne pridem niti do namizja
- spremenilo: bela120 ()
https://login.live.com
Click the "Can't access your account?" link and follow the steps to reset your password.
bela120 ::
Ja to sem vse poizkusila ne dela nič pač vem samo e naslov in nič drugega kaj potem sledi na novo naložiti windowse ?
lahk probaš še tole prej:
1. Start your win 8 computer and press "F8" while the computer boots up. Scroll down to "Safe Mode with Command Prompt" with the arrow keys on the keyboard and press "Enter." Your computer starts in Safe Mode with Command Prompt.
2. Select the Administrator account that appear in the screen, then enter command prompt. Type: net user ****** 123456 and enter (****** is the account name which password you need to reset 123456 is the new password), it will show you a message that" the command completed successfully.
3. Restart your win 8 computer, then you can log in as ****** with the password 123456. You can go to control Panel to change your account password if necessary.
- spremenil: PacificBlue ()
| » | USB-samodejno zažčitil proti pisanjuOddelek: Pomoč in nasveti | 15766 (9924) | donvito |
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5614 (4162) | Gray_Warden_ |
| » | Reset biosa na HpOddelek: Strojna oprema | 2464 (2291) | RiNC |
| » | trdi disk hitachiOddelek: Strojna oprema | 2524 (2159) | kerrigh |
| » | 100%Cpe + ostaloOddelek: Pomoč in nasveti | 2793 (2463) | postar_si |
