Forum » Kaj kupiti » nakup novega tvja.
nakup novega tvja.
DarKel ::
Pozdravljeni,
Obadam se z nakupom novega tvja, pa me zanima kaj kj priporočate... cena do 700 - 800 EUR.. diagonala do tam 90 cm
hvala za nasvete
hvala za nasvete
- spremenil: DarKel ()
Tomson ::
Do 90cm je samo 32" - 82cm. V tem cenovnem rangu sta najboljši opciji Sony W605 in Samsung H6400, oba sta okoli 500€. Oba odlična.
Steampunk ::
500€ za 32" 1080p TV?! 32" računaj do max 300€.
npr. 100cm http://www.merkur.si/elektronika/video-...
Tomson ::
A ne bi raje max 220€? npr. Philips PHHH4309
Skratka, če je nekdo pripravljen odštet 500€ za preverjeno dober TV, ne vem zakaj bi bil 300€ max!?
Zato ker so 32" TVji danes samo še za na odpad.. :D
DarKel, kupi vsaj 119cm..
Če ni prostora, pa primi sekiro v roke in ga naredi.. (Pithlit, samo zate sem to dodal.
fpbs ::
Tomson ::
Kot rečeno, če želiš dober overall TV, Sony W705 (605) ali Samsung H6400. Če bi rad prišel ceneje skozi pa kot je predlagal Steampunk, kakšnega LGja ali npr. Samsung H5000/5500 ...
Tomson ::
Če gledaš samo na kvaliteto slike in ceno je dober nakup, sicer pa:
This TV is let down by ease of use issues. The standard remote control has too many buttons of similar sizes and shapes, plus its navigation keys are crowded and lacking in definition. There can be a lag between pressing a button on the remote, and something happening on screen.
Getting around the smart-TV features with the remote is particularly tiresome and repetitive. This TV doesn't feature LG's new webOS smart TV, and is instead stuck with the old system. The 'smart home' hub page is overly complicated and poorly presented, and typing in data on things such as the web browser is a slow and laborious chore.
You get a PVR if you connect a USB hard drive, but it's not as versatile as other sets and cannot record audio description or do more advanced tasks such as split recording.
Tomson ::
V trgovino pa sprobat, ni druge ...
ni prostora za večji teve nažalost..
Opiši situacijo..
1. Ni prostora, ker TV tiščiš v omaro, tako kot je bila praksa v prejšnjem tisočletju?
V tem primeru omaro seveda demoliraš in nabaviš kakšno nizko komodo za TV, oziroma TV zmontiraš na steno.
2. Ni prostora, ker so ovira vrata oz. okno?
V tem primeru lahko morda malce preurediš prostor oziroma kupiš stenski nosilec in TV namestiš v kot.
3. Ni prostora, ker gre za 2x2m majhno sobo?.
Ok, v tem primeru res ni prostora.
4. ?
| » | Samsung Led TV H6400 - vtisi, težave, zadnji firmware (strani: 1 2 3 4 5 6 7 )Oddelek: Zvok in slika | 79428 (24635) | Han |
| » | Kateri televizor (strani: 1 2 )Oddelek: Kaj kupiti | 21692 (11425) | Mirkokovačec |
| » | TV Sony - Philips - Samsung (strani: 1 2 )Oddelek: Zvok in slika | 34212 (30190) | Thunder wave |
| » | TV do 850€Oddelek: Kaj kupiti | 1788 (1621) | Thunder wave |
