priključjitev cURL knjižnic v Qt [c++]
killa bee ::
Mogoče kdo ve kako bi vključil curl knjižnico v Qtcreator?
 *                                  _   _ ____  _
 *  Project                     ___| | | |  _ \| |
 *                             / __| | | | |_) | |
 *                            | (__| |_| |  _ <| |___
 *                             \___|\___/|_| \_\_____|
 * Copyright (C) 1998 - 2013, Daniel Stenberg, <daniel@haxx.se>, et al.
 * This software is licensed as described in the file COPYING, which
 * you should have received as part of this distribution. The terms
 * are also available at http://curl.haxx.se/docs/copyright.html.
 * You may opt to use, copy, modify, merge, publish, distribute and/or sell
 * copies of the Software, and permit persons to whom the Software is
 * furnished to do so, under the terms of the COPYING file.
 * This software is distributed on an "AS IS" basis, WITHOUT WARRANTY OF ANY
 * KIND, either express or implied.
#include <stdio.h>
#include <curl/curl.h>
int main(void)
  CURL *curl;
  CURLcode res;
  curl = curl_easy_init();
  if(curl) {
    curl_easy_setopt(curl, CURLOPT_URL, "http://example.com");
    /* example.com is redirected, so we tell libcurl to follow redirection */
    curl_easy_setopt(curl, CURLOPT_FOLLOWLOCATION, 1L);
    /* Perform the request, res will get the return code */
    res = curl_easy_perform(curl);
    /* Check for errors */
    if(res != CURLE_OK)
      fprintf(stderr, "curl_easy_perform() failed: %s\n",
              curl_easy_strerror(res));
    /* always cleanup */
    curl_easy_cleanup(curl);
  return 0;
Rad bi pognal ta program. Zanj potrebujem knjižnico curl ki se nahaja na http://curl.haxx.se/download.html. Z downlovdal sem 3ji link od vrha. Kako sedaj zdownlowdan .zip file povežem s Qtcreator-jem da mi bo program deloval.
  • spremenilo: killa bee ()
Senitel ::
Daj se že navadi. Qt je GUI knjižnica, Qt Creator je razvojno orodje. Tebe torej zanima kako v Qt Creatorju v svoj C++ projekt vključit CURL. Odgovor je tako.
killa bee ::
Tukaj piše "Adding Libraries to Projects".
kako pa narediš iz .zip file-a library ?
Senitel ::
Tko da razpakiraš zip? :8)
