Forum » Programiranje » [Delphi] Problem pri MP3 Playerju z ID3 Tag Update-om
blackfly666b ::
Pozdrav
Takole je definiran record za ID3 tag:
type
TID3Rec = packed record
Tag : array[0..2] of Char;
Title,
Artist,
Comment,
Album : array[0..29] of Char;
Year : array[0..3] of Char;
Genre : Byte;
end;
Tole pa imam pa spreminjanje:
procedure ChangeID3Tag(NewID3: TID3Rec; mp3FileName: string; Title,Artist,Album,Year,Genre,Comment:TEdit);
var
fMP3: file of Byte;
OldID3 : TID3Rec;
begin
NewID3.Tag:='TAG';
StrPCopy( @NewID3.title[0], string( title.text) );
StrPCopy( @NewID3.artist[0], string( artist.text) );
StrPCopy( @NewID3.album[0], string( album.text) );
StrPCopy( @NewID3.comment[0], string( comment.text) );
StrPCopy( @NewID3.year[0], string( year.text) );
NewID3.Genre:=4;
try
AssignFile(fMP3, mp3FileName);
Reset(fMP3);
try
Seek(fMP3, FileSize(fMP3) - 128);
BlockRead(fMP3, OldID3, SizeOf(OldID3));
if OldID3.Tag = 'TAG' then
BlockWrite(fMP3, NewID3, SizeOf(NewID3))
except
else
Seek(fMP3, FileSize(fMP3));
BlockWrite(fMP3, NewID3, SizeOf(NewID3));
end;
finally
CloseFile(fMP3);
end;
end;
Tole je pa akcija:
procedure Tform1.Image5Click(Sender: TObject);
var NewID3:TID3Rec;
mp3filename:string;
begin
ChangeID3Tag(NewId3,mp3filename,edtitle,edartist,edalbum,edyear,edgenre,edcomment);
end;
zadeva se mi sesuje, ko kliknem na sliko "Update" (image5)... nimam pojma zakaj, s tem se ukvarjam ze pol dneva...
type
Title,
Artist,
Comment,
Genre : Byte;
end;
var
fMP3: file of Byte;
OldID3 : TID3Rec;
begin
NewID3.Tag:='TAG';
NewID3.Genre:=4;
try
Reset(fMP3);
try
except
else
end;
finally
CloseFile(fMP3);
end;
end;
Tole je pa akcija:
var NewID3:TID3Rec;
mp3filename:string;
begin
end;
blackfly666b ::
Aja no, se to: Ce ID3 tag obstaja, mi izpise "I/O Error 6", ce pa ID3 Taga ni, se sesuje in izpise "Access ViolatioN" ...
Taras_Bulba ::
Uf mislm, da je i/o error 6 napaka pri branju datoteke in ma nekej zveze z seek(). Sem mel isti problem, ampak je že kako leto od tega... Poglej v help kaj pomen i/o error 6
iBojan ::
http://www.torry.net/apps/utilities/mme...
Tule maš en mp3 player z izvorno kodo pa lahko vse lepo vidiš kako je narejeno ;)
| » | oracle 12 identity (the old way)Oddelek: Programiranje | 1396 (1201) | detroit |
| » | [SQL] InsertOddelek: Programiranje | 2418 (2020) | greentech |
| » | Program, ki ti izpiše naslove vseh mp3 v določeni mapi ; izpisek skladbOddelek: Programska oprema | 1682 (1479) | RealSlimShady |
| » | CD textOddelek: Pomoč in nasveti | 1702 (1504) | DrSergioDJ |
| » | php, mysql SELECT MAX(id)...Oddelek: Programiranje | 1564 (1460) | Gre-Gor |
