Forum » Omrežja in internet » Misteriozni IP
Misteriozni IP
Kdo/kaj odgovarja na ping???
Ruter (192.168.222.1) namreč tega naslova (192.168.137.1) na pozna (ping od tam je brez odziva).
C:\Users\stein\Documents\progs>route print
Interface List
10...00 08 ca 41 16 4b ......Microsoft Hosted Network Virtual Adapter
4...00 08 ca 41 16 4b ......Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter
3...8c 89 a5 a4 7f 41 ......Realtek PCIe GBE Family Controller
25...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
26...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
27...08 00 27 00 78 8c ......VirtualBox Host-Only Ethernet Adapter
1...........................Software Loopback Interface 1
6...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
7...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #6
8...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.222.1 192.168.222.139 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.56.0 255.255.255.0 On-link 192.168.56.1 276
192.168.56.1 255.255.255.255 On-link 192.168.56.1 276
192.168.56.255 255.255.255.255 On-link 192.168.56.1 276
192.168.80.0 255.255.255.0 On-link 192.168.80.1 276
192.168.80.1 255.255.255.255 On-link 192.168.80.1 276
192.168.80.255 255.255.255.255 On-link 192.168.80.1 276
192.168.111.0 255.255.255.0 On-link 192.168.111.1 276
192.168.111.1 255.255.255.255 On-link 192.168.111.1 276
192.168.111.255 255.255.255.255 On-link 192.168.111.1 276
192.168.222.0 255.255.255.0 On-link 192.168.222.139 281
192.168.222.139 255.255.255.255 On-link 192.168.222.139 281
192.168.222.255 255.255.255.255 On-link 192.168.222.139 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.56.1 276
224.0.0.0 240.0.0.0 On-link 192.168.111.1 276
224.0.0.0 240.0.0.0 On-link 192.168.80.1 276
224.0.0.0 240.0.0.0 On-link 192.168.222.139 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.56.1 276
255.255.255.255 255.255.255.255 On-link 192.168.111.1 276
255.255.255.255 255.255.255.255 On-link 192.168.80.1 276
255.255.255.255 255.255.255.255 On-link 192.168.222.139 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
27 276 fe80::/64 On-link
26 276 fe80::/64 On-link
25 276 fe80::/64 On-link
4 281 fe80::/64 On-link
27 276 fe80::6549:62fb:842f:7c2c/128
On-link
4 281 fe80::b12d:89f:3b43:9c1f/128
On-link
26 276 fe80::bdbb:1822:25d2:3d66/128
On-link
25 276 fe80::c41a:ab9:49c6:f198/128
On-link
1 306 ff00::/8 On-link
27 276 ff00::/8 On-link
26 276 ff00::/8 On-link
25 276 ff00::/8 On-link
4 281 ff00::/8 On-link
Persistent Routes:
None
C:\Users\stein\Documents\progs>ping 192.168.137.1
Pinging 192.168.137.1 with 32 bytes of data:
Reply from 192.168.137.1: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.137.1:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Control-C
^C
C:\Users\stein\Documents\progs>Ruter (192.168.222.1) namreč tega naslova (192.168.137.1) na pozna (ping od tam je brez odziva).
- spremenil: MrStein ()
l0wc4 ::
VMWare ti odgovarja. Preveri VMWare Network konfiguracijo, kjer je NAT adapter in skoraj 100% boš ta rang IP adres našel prav tam.
LP,Davor
LP,Davor
Ne ni, saj se vidi iz ruting tabele.
Nekaj drugega je bilo.
Bom pustil pol ure, da se zabavate ob ugibanju, pa potem povem.
Brane22 ::
Zdaj nisem rpeveč v tem, ampak a je možno da si zadel en od 224.0.0.0/4 multicast routeov ?
Brane22 ::
Tko na prvi uč bi naj šlo, če nisem preveč pozabil.
Ima masko /4, kar pomeni da bi 192(168.137.1) šel skozi, saj je 0xC0...
Tudi če je to, je samo del zgodbe, ker potem mora biti še kje kaj zadaj na tem naslovu.
Po možnosti kak virtualni interni interface, da ga ni treba hranit v arp tabeli.
- spremenilo: Brane22 ()
Stvar je "preprosta".
Ethernet adapter je imel (statični) naslov 192.168.137.1.
V ruting tabeli pa ga ni, ker sem tedaj že izpulil LAN kabel.
Statični naslov pa je bil, ker sem preko tega vmesnika delil internet.
Gor sem priklopil ruter in hotel na web vmesnik, pa sem IP naslov NIC površno pogledal ("pobral" le prefiks 192.168.137) in "vzel" 192.168.137.1 kot naslov ruterja.
Po kaki logiki???
Po kaki logiki???
Brane22 ::
| » | Mikrotik - OpenVPNOddelek: Omrežja in internet | 2350 (1998) | mrsmoke |
| » | Povezava 2 računalnikov in medsebojni prenos datotek (strani: 1 2 )Oddelek: Pomoč in nasveti | 21434 (20114) | imagodei |
| » | Route preko specifičnega adapterjaOddelek: Omrežja in internet | 3273 (3109) | aleksander10 |
| » | Win 7 routing dveh mrežnih karticOddelek: Omrežja in internet | 2126 (2022) | Spc |
| » | vista in dve mrežni kartici - problemOddelek: Omrežja in internet | 3067 (2893) | sosko1 |
