Route preko specifičnega adapterja
Lombi ::
Hoj. Potreboval bi malo pomoči pri določevanju route add.
Imam dva mrežna adapterja, oba se povezujeta v splet, 192.168.1.x ima ločen zunanji IP, 192.168.2.x pa skupnega, ki ga ne želim uporabljat, vendar omogoča dostop do lokalnih tiskalnikov in SMB shareov.
Torej, kako definirati "route add", da dostopa do notranje mreže z adapterjem 2 in do zunanje mreže z adapterjem 1?
Vnaprej se najlepše zahvaljujem!
Route print:
Interface List
 18...00 0a cd 17 27 ca ......HighSpeed USB-Ethernet Adapter
 17...00 ff 8f a2 84 b4 ......WeOnlyDo Network Adapter 2.5
 11...00 24 81 84 94 0d ......Intel(R) 82567V-2 Gigabit Network Connection
  1...........................Software Loopback Interface 1
 13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
 15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
 19...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #6
 20...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #7
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.1.1    192.168.1.100     20
          0.0.0.0          0.0.0.0      192.168.2.1    192.168.2.133     20
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      169.254.0.0      255.255.0.0         On-link     169.254.0.198    276
    169.254.0.198  255.255.255.255         On-link     169.254.0.198    276
  169.254.255.255  255.255.255.255         On-link     169.254.0.198    276
      192.168.1.0    255.255.255.0         On-link     192.168.1.100    276
    192.168.1.100  255.255.255.255         On-link     192.168.1.100    276
    192.168.1.255  255.255.255.255         On-link     192.168.1.100    276
      192.168.2.0    255.255.255.0         On-link     192.168.2.133    276
    192.168.2.133  255.255.255.255         On-link     192.168.2.133    276
    192.168.2.255  255.255.255.255         On-link     192.168.2.133    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link     192.168.1.100    276
        224.0.0.0        240.0.0.0         On-link     169.254.0.198    276
        224.0.0.0        240.0.0.0         On-link     192.168.2.133    276
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link     192.168.1.100    276
  255.255.255.255  255.255.255.255         On-link     169.254.0.198    276
  255.255.255.255  255.255.255.255         On-link     192.168.2.133    276
moja video predavanja za adobe in wordpress: 321.si
moje slike in animirani filmi: lo.si
crniangeo ::
spremeni prioriteto mreznih kartic :)
http://support.microsoft.com/kb/2526067
2. opcija: za interno mrezo nastavi static ip brez gatewaya :)
Convictions are more dangerous foes of truth than lies.
aleksander10 ::
Ali pa na na network adapter, ki ima default GW povečas metriko (iz 20 na 30).
Aleksander
"A friend is someone who gives you total freedom to be yourself. (J.M.)"
Lombi ::
crniangeo je izjavil:
Hvala za odgovor.
Spremenil prioriteto in si definiral staticni IP brez gatewaya, so far so good.
aleksander10 je izjavil:
Erm, kako pa to storis?
  • spremenil: Lombi ()
SeMiNeSanja ::
route CHANGE 0.0.0.0 MASK 0.0.0.0 192.168.2.1 METRIC 30
Lombi ::
Najlepsa hvala za pomoc, so far so good :)
aleksander10 ::
Za default GW ni potrebno v CLI. Greš kar na interface card in spremeniš.
Primer tu:
http://blog-rat.blogspot.com/2011/06/ho...
Aleksander
Mikrotik - OpenVPN
Oddelek: Omrežja in internet
62349 (1997) mrsmoke
Misteriozni IP
82941 (2741) Brane22
Openvpn (strani: 1 2 )
Oddelek: Programska oprema
6518862 (10429) Blisk
Win 7 routing dveh mrežnih kartic
62124 (2020) Spc
vista in dve mrežni kartici - problem
63067 (2893) sosko1
