proxy PAC configuracija?
Pesimist ::
gledam te primere kot ta spodaj vendar jaz bi rabo kontra. Vse direkt razen enih par komadov.
Example PAC File
function FindProxyForURL(url, host) {
// If the hostname matches, send direct.
if (dnsDomainIs(host, ".intranet.domain.com") ||
shExpMatch(host, "(*.abcdomain.com|abcdomain.com)"))
return "DIRECT";
// If the protocol or URL matches, send direct.
if (url.substring(0, 4)=="ftp:" ||
shExpMatch(url, "http://abcdomain.com/folder/*"))
return "DIRECT";
// If the requested website is hosted within the internal network, send direct.
if (isPlainHostName(host) ||
shExpMatch(host, "*.local") ||
isInNet(dnsResolve(host), "10.0.0.0", "255.0.0.0") ||
isInNet(dnsResolve(host), "172.16.0.0", "255.240.0.0") ||
isInNet(dnsResolve(host), "192.168.0.0", "255.255.0.0") ||
isInNet(dnsResolve(host), "127.0.0.0", "255.255.255.0"))
return "DIRECT";
// If the IP address of the local machine is within a defined
// subnet, send to a specific proxy.
if (isInNet(myIpAddress(), "10.10.5.0", "255.255.255.0"))
return "PROXY 1.2.3.4:8080";
// DEFAULT RULE: All other traffic, use below proxies, in fail-over order.
return "PROXY 4.5.6.7:8080; PROXY 7.8.9.10:8080";
harmony ::
Jaz se tudi ravno s tem ukvarjam.
Dejansko kar jaz hocem je proxy enabled za vse uporabnike, ko pa pridejo z laptopi ven da se jim proxy onemogoci in omogoci normalno surfanje brez proxy-ija.
videc ::
In kaj ni jasno iz zgornje kode?
Mikrotik - OpenVPN
Oddelek: Omrežja in internet
62305 (1953) mrsmoke
Openvpn (strani: 1 2 )
Oddelek: Programska oprema
6518591 (10158) Blisk
VPN povezava dveh PIX 501
141760 (1581) jl
Gajba piva za rešitev mrežneag problema Vista-W2K
303610 (2734) just_a_cook
inet nekaj zajebava v Linuxu.
Oddelek: Operacijski sistemi
211995 (1796) weishaupt
