Boot problem pri laptopu Toshiba Satellite C55-A-1RG
aljaz92 ::
Zdravo, dobil sem prenosnik Toshiba Satellite C55-A-1RG brez operacijskega sistema. Rad bi si posnel Win7 vendar imam težavo pri branju DVD pogona. Računalnik nikakor ne prepozna da je DVD not, windowse sem ok posnel na dvd, ker mi jih na drugih računalniki prepozna in jih tudi zažene. Bral sem da imajo ti prenosniki dosti težav z branjem dvd-jem zato sem našel da je potrebno v BIOS-u spremeniti določene stvari da ti normalno prebere DVD (https://aps2.toshiba-tro.de/kb0/TSB2C03....
Težava pa je naslednja, pod Security lahko nastavim Secure Boot na Disable, potem pa ko grem pod Advanced > System Configuration nimam nikjer prikazane nastavitve za Boot mode, ki bi jo bilo potrebno spremeniti. Prikaže mi Built-in LAn, Web Camera, Power on Display, Function Keys mode. To je tudi vse kar mi prikaže.
Je mogoče kdo imel isto težavo in kako jo je rešil ? Hvala za pomoč.
s6c-gEL ::
http://forums.toshiba.com/t5/General-Tr...
Med bootanjem pritiskaj tipko f12 (boot order), če mogoče zagrabi.
Anyway:
http://forums.toshiba.com/t5/Satellite-...
My guess is that this was either done on purpose or by mistake.
04-17-2014 01:26 PM - edited ?04-17-2014 01:31 PM
Hello, my computer is Satelite C55-A-1RM. I have just downloaded and updated new BIOS ISO file (version 1.30-ISO) from toshiba support http://support.toshiba-tro.de/tools/eul...
and then in BIOS appeared new "Boot mode" option "UEFI Boot" or "CSM Boot". Now installing windows 7
Naredi enako za svoj model, v trenutnem biosu ne moreš prestaviti na csm !
Kot uefi + gpt bi se maloli win7/8 namestiti
http://www.eightforums.com/tutorials/15...
  • spremenilo: s6c-gEL ()
s6c-gEL ::
spodnji post:
http://forums.computers.toshiba-europe....
Your notebook was equipped with an Intel Mobile Celeron N2815 CPU which belongs to the Bay Trail-M family.
The Intel new technology called BayTrail is the newest kind of chip designed especially for mobile (tablet) usage. Such chips support only the UEFI capable devices and systems (Win 8, Win 8.1) and therefore the UEFI / CSM boot mode option isn't available in the BIOS settings.
You can install only UEFI capable system like Win 8 or Win 8.1
Installing Windows 7 on UEFI based computer
http://blogs.technet.com/b/askcore/arch...
aljaz92 ::
Hvala za odgovor, on forum link ki si ga dal na začetku sem probal pa ni šlo nič. Sedaj sem pa hotel posodobiti BIOS sistem posnel zadevo na dvd kot iso file vse vredu posname dam not f12 in preberem dvd drive in vseeno napiše "No bootable device - Please restart system", tako da mi tudi bios sistema noče posodobiti. :(
Nikonja ::
zakaj sploh inštaliraš windowse z dvd-a. Dej ih na USB ključ in bo ziher delalo pa še hitrejša instalacija bo.
Potegni si tale programček http://www.microsoftstore.com/store/msu... in z njim se kreira boot USB z windowsi.
KTr1sk ::
ali pa s tem http://rufus.akeo.ie/
aljaz92 ::
Sem poiskusil tudi z USB ključem pa tudi to ne dela. Sem tudi nastavil v BIOSU da naj USB ključ bere začne brati potem pa takoj zaključi in ponovno izpiše da naprave ki bi jo lahko prebral.
Nikonja ::
Sorry ampak neki narobe delaš potem, ker je nemogoče da ne prebere dvd ali usb.
solatko ::
Na instalacijskem DVD-ju nimaš možnosti instalacije na UEFI. UEFI spusti skozi samo legalne verzije OS, travniških verzij ne zazna.
Uporabit moraš Legacy mode, katerega ima pa vsak bios malo drugače. Legacy ti ustvari normalne MRB particije, Uefi pa GTP, MRB particij pa ne prepozna, zato ti stalno piše no boot media.
Poišči v navodilih, kako se postavi sistem na Legacy.
Delo krepa človeka
Težave z bootanjem iz USB
Oddelek: Operacijski sistemi
81251 (1183) tadoo
UEFI - kako ponovno namestiti windows 8
3612556 (10070) krepki
Sistema ni mogoče namestiti na disk
198149 (7786) Mare2
Ubuntu na UEFI
141785 (1623) jype
NOV prenosnik - Toshiba Satellite --- pomoč lepo prosim!
427986 (6530) Matej Marinč
