Forum » Pomoč in nasveti » Štekanje
Štekanje
PurplePapet ::
Odkar sem iz windows 7 prišel na windows 8 mi računalnik zmeraj počasneje dela, ali je to kriv windows ali kaj drugega? Šteka mi med igranjem Minecraftom, ko sem imel windows 7 je boljše delalo, včasih mi pa tudi internet vn vrže ampak na drugem računalniku dela:
Field Value
Computer
Computer Type ACPI x64-based PC
Operating System Microsoft Windows 8 Professional
OS Service Pack [ TRIAL VERSION ]
Internet Explorer 10.0.9200.16750
DirectX DirectX 11.0
Computer Name THOMAS-PC
User Name Smooth
Logon Domain [ TRIAL VERSION ]
Date / Time 2014-01-23 / 20:26
Motherboard
CPU Type DualCore AMD A6-5400K, 3819 MHz (38 x 101)
Motherboard Name Asus F2A55-M LK (1 PCI, 2 PCI-E x1, 1 PCI-E x16, 2 DDR3 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset AMD A55, AMD K15.1
System Memory [ TRIAL VERSION ]
DIMM1: Kingston 99U5403-067.A00LF 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Type AMI (11/08/2012)
Communication Port Communications Port (COM1)
Communication Port Printer Port (LPT1)
Display
Video Adapter AMD Radeon HD 7540D (512 MB)
3D Accelerator AMD Radeon HD 7540D (Trinity)
Monitor Sony SDM-S51 [15" LCD] (4587796)
Multimedia
Audio Adapter Realtek ALC887 @ AMD Hudson-2 FCH - High Definition Audio Controller
Storage
IDE Controller Standard SATA AHCI Controller
Storage Controller Microsoft Storage Spaces Controller
Disk Drive ST250DM001 HD256GJ (250 GB, 7200 RPM, SATA-II)
Disk Drive Verbatim STORE N GO USB Device (14 GB, USB)
Optical Drive ATAPI iHAS122 C (DVD+R9:8x, DVD-R9:8x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Network
Primary IP Address [ TRIAL VERSION ]
Primary MAC Address 08-60-6E-D4-91-75
Network Adapter Realtek PCIe GBE Family Controller (84.4 [ TRIAL VERSION ])
Field Value
Computer
User Name Smooth
Motherboard
Display
Multimedia
Storage
Network
| » | Kaj bi se splačalo nadgraditi na osebnem računalniku?Oddelek: Pomoč in nasveti | 1199 (1119) | MIHAc27 |
| » | Problem pri računalniku !Oddelek: Pomoč in nasveti | 1344 (1198) | ziga1990 |
| » | Nova grafična karticaOddelek: Pomoč in nasveti | 1445 (1290) | Leprechaun |
| » | Zamenjava operacijskega sistema ! (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 14175 (12386) | Assass1n |
| » | navijanje E7500Oddelek: Navijanje | 3281 (2164) | grobar |
