Forum » Omrežja in internet » Težava pri pošiljanju na @siol.net
Fukomuko ::
Pri pošiljanju emaila na enega izmed siolovih računov sem prejel tole napako:
V čem bi lahko bil problem?
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed:
xxx.xxx@siol.net
SMTP error from remote mail server after RCPT TO:<xxx.xxx@siol.net>:
host mailhub.siol.net [213.250.19.150]: 554 5.7.1 <xxx.xxx@siol.net>:
Recipient address rejected: Blocked - Your IP [91.185.xxx.xx] has no corresponding reverse (PTR) address. Ask your Internet Service Provider to assign you IP with valid reverse (PTR) record.V čem bi lahko bil problem?
- spremenil: Fukomuko ()
wini ::
Zavrača ker tvoj mail server nima ptr recorda ... sej ti piše
Po domače povedano to je kontra od A recorda se pravi je reverz dns
če narediš poizvedno ti ptr record vrne tvoj naslov
primer:
ping 91.185.xxx.xx ti resolva addresso na mail.tvojadomena.com
primer:
Bakunin ::
kaj ima to veze s POŠILJANJEM e-pošte ?
od KOD si pošiljal oz. kateri poštni strežnik za POŠILJANJE e-pošte si uporabil ?
problem je v (neobstoju) povratnem IP naslove TEGA strežnika.
Fukomuko ::
Pošiljal sem iz email računa, ki ga imam na enem izmed slovenskih web hosting gostiteljev. Sem jih kontaktiral, tako da so nastavili rDNS, kar bi naj odpravilo napako, vendar se sedaj pojavlja druga napaka pri pošiljanju na siol.net račune:
Morda kdo ve, kje je težava?
This message was created automatically by mail delivery software. A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed: xxx@siol.net SMTP error from remote mail server after RCPT TO:<xxx@siol.net>: host mailhub.siol.net [213.250.19.150]: 550 5.1.1 <xxx@siol.net>: Recipient address rejected: siol.net
Bakunin ::
5xx napaka na MX strezniku za domeno ponavadi pomeni, da ta naslov cisto zares ne obstaja...
| » | avtomatsko vrnjen emailOddelek: Pomoč in nasveti | 2642 (2437) | Spajky |
| » | Mail na strežnikuOddelek: Omrežja in internet | 2157 (1885) | Malajlo |
| » | Maili iz SiOLa ne preidejo na Yahoo mailOddelek: Omrežja in internet | 2716 (2511) | BlueRunner |
| » | Mail relay v okviru .dsl.siol.netOddelek: Omrežja in internet | 4733 (4372) | McBoby |
| » | Čudn email - Mail delivery failedOddelek: Pomoč in nasveti | 1772 (1614) | Kaboom |
