[Delphi] Koda za pisanje v executable file
pr25012 ::
Razumem kako naj bi koda iz članka:
(http://edn.embarcadero.com/article/2797...
delala ampak je ne zmorem kompletirati.
In povezava za download code ne dela.
Tu so error-ji...
Next are the errors..
Pomagajte mi jih prosim razrešiti in potem bi predpostavljal bil sposoben nadaljevati sam.
[Error] licenseexe.pas(63): Undeclared identifier: 'TExeBuf'
[Error] licenseexe.pas(77): Incompatible types
[Error] licenseexe.pas(112): Undeclared identifier: 'EExeBuf'
[Error] licenseexe.pas(116): Incompatible types
[Error] licenseexe.pas(131): Incompatible types
[Error] licenseexe.pas(137): Incompatible types
[Error] licenseexe.pas(138): Incompatible types
[Fatal Error] PRlicenseexe.dpr(5): Could not compile used unit 'licenseexe.pas'
unit licenseexe;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, StdCtrls, ExtCtrls;
type
  TForm1 = class(TForm)
     private
    { Private declarations }
       (* procedure SetExeData (ExeName : String; ExeBuf : TExeBuf);
    procedure GetExeData (ExeName : String; var ExeBuf : TExeBuf);
    procedure StringToExeBuf (const S : String; var ExeBuf : TExeBuf);
    function ExeBufToString (const ExeBuf : TExeBuf) : String;
  public
    { Public declarations }
  end;
  const
  //our ExeBuffer signature
  ExeBufSig = 'EB1.0';
type
  //the Footer for our executable format
  TExeBufFooter = record
    OriginalSize : Integer;
    Sig : Array[0..4] of char;
end;
  var
  Form1: TForm1;
        //exebuf:TExeBufFooter   ;
implementation
{$R *.dfm}
var
  F : File;
  BufSz,OrigSz : Integer;
  Footer : TExeBufFooter;
begin
  AssignFile (F,ExeName);
  Reset (F,1);
  try
    //obtaining the original file size
    OrigSz := FileSize(F);
    //go to the EOF of the file
    Seek (F,OrigSz);
    //Writing our custom data beyond the EOF
    BufSz := Length(ExeBuf);
    BlockWrite (F,Pointer(ExeBuf)^,BufSz);
    //Writing our footer
    FillChar (Footer,SizeOf(Footer),0);
    Footer.OriginalSize := OrigSz;
    Footer.Sig := ExeBufSig;
    BlockWrite (F,Footer,Sizeof(Footer));
  finally
    CloseFile (F);
  end;
end;
var
  F : File;
  CurrSz, BufSize : Integer;
  OldFileMode : Integer;
begin
  //Saving the old FileMode
  OldFileMode := FileMode;
  //Setting the FileMode to ReadOnly
  FileMode := 0;
  try
    Reset (F,1);
    try
      //Getting the current file size
      CurrSz := FileSize (F);
      //Seeking to the footer position
      //and reading it
      Seek (F,CurrSz-SizeOf (Footer));
      BlockRead (F,Footer,Sizeof(Footer));
      //if there's no signature, boom!
      //no data in this executable!
      if Footer.Sig <> ExeBufSig then
        raise EExeBuf.Create ('No Data in EXE!');
      //calculating the buffer size that was written
      //to this executable file
      BufSize :=CurrSz-Footer.OriginalSize-SizeOf(Footer);
      SetLength (ExeBuf,BufSize);
      //seek and read!
      Seek (F,Footer.OriginalSize);
      BlockRead(F,Pointer(ExeBuf)^, BufSize);
    finally
      CloseFile (F);
    end;
  finally
    //returning to the previous saved
    //FileMode
    FileMode := OldFileMode;
  end;
end;
begin
  SetLength(ExeBuf,Length(S));
  Move (Pointer(S)^,Pointer(ExeBuf)^,Length(S));
end;
begin
  SetLength (Result,Length(ExeBuf));
  Move (Pointer(ExeBuf)^,Pointer(Result)^,Length(ExeBuf));
end;
end.
sas084 ::
Sicer nimam pojma o Delphi-ju, sklepam pa da nimas nikjer deklariranega TExeBuf. V linku je definiran kot:
TExeBuf = array of char;
pr25012 ::
Ok, se bom lotil.
Hvala.
Rešeno, še enkrat hvala.
  • spremenil: pr25012 ()
[NALOGA][Java] Branje vsebine datoteke vzvratno
Oddelek: Programiranje
71941 (1883) SkIDiver
[C] MySQL
293254 (2276) Tutankhamun
[C++] Portabilna funkcija za kopiranje datotek
172686 (2342) Gundolf
[Delphi] Unit za EXIF metadata (jpg)
141517 (1446) b0B3k
Pointer-ji v C-ju
292134 (1832) rokpok
