spremenjanje tipk na tipkovnici
dragoneye89 ::
kdo ve če se da spremenit pomen tipk na tipkovnici?recimo da nastaviš namesto 3 neko črko? in ko pritisneš 3 se pojavi x npr.?
dragoneye89 ::
dve črke mi ne delata zato sprasujem ;((
Kupi novo tipkovnico ...
Ali pa staro odpri in spucaj. Mogoče bo pomagalo.
dragoneye89 ::
na laptopu je zato >_>
mihibo5 ::
Spucaj, kot je bilo rečeno.
dragoneye89 ::
sm in je isto, nedela
Apple ::
Obstaja nek program, samo se ne spomnim imena... Jst bi ga tud rabil :)
S programom si lahko delal rošado tipk...
Men na Appleovi tipkovnici manjkata tipki PrtScreen ter Insert :)
LP, Apple
Cold1 ::
Microsoft Keyboard Layout Creator - MSKLC
Ever wanted to quickly and easily define your own keyboard layout for a language Microsoft doesn't support? Or define your own keyboard layout so you can quickly and easily enter your favorite symbols with a simple keystroke? Have the keyboard work on 64-bit platforms, or make use of custom locales in Windows 7 to provide new language names? Well, want no more: the Microsoft Keyboard Layout Creator is here!
The Microsoft Keyboard Layout Creator (MSKLC) extends the international functionality of Windows 2000, Windows XP, Windows Server 2003, Windows Vista, and Windows 7 systems by allowing users to:
- Create new keyboard layouts from scratch
- Base a new layout on an existing one
- Modify an existing keyboard layout and build a new layout from it
Spletna stran:
http://msdn.microsoft.com/en-us/gogloba...
MSKLC 1.4:
http://go.microsoft.com/fwlink/?LinkId=...
dragoneye89 ::
in kako vklopiš to da se črke spremenijo?
krneki007 ::
poglej na bolhi / ebay-u za rabljeno tipkovnico
joze67 ::
ali pa googlaj za keyboard remapper. Tak sw je precej enostaven in ga je zato kar veliko.
Engineer_ ::
tipkovnice za prenosnike niso tako blazno drage da se jih ne bi dalo menjat.
v skrajnem primeru naročiš eno na ebayu.
  • spremenilo: Engineer_ ()
dragoneye89 ::
joze67 je izjavil:
no tale pa dela ;D thx:D
Kaj se je zgodilo s slovensko tipkovnico?
467776 (6110) janig
Ergonomske miške in tipkovnice
305138 (4761) tony1
Zamenjava tipk na tipkovnici
1016076 (15940) IvoJan
kako narediti prtscr na nemški tipkovnici
136001 (5719) Domina
tikpovnica (razpored tipk) po lastni izbiri
61514 (1413) 5er-->
