Forum » Mobilne tehnologije » NOKIA E7 koda za zaklepanje se pojavlja
djforever ::
lp,od kolega sem dobil da ima problem z Nokio e7.In sicer se mu je pojalvjala ikona ANTI THEFT,sem nokio resetiral (hard reset),zdaj mu gre da lahko z drugo kartico vstopi v nokio,samo je problem da se tu pa tam pojavlja ta koda za zaklep,pa nimam pojma kako to odstranit!
Prosim za pomoč!
HVALA
Prosim za pomoč!
HVALA
Hayabusa ::
Naredi hard reset:
http://www.justanswer.com/cell-phones/7...
http://discussions.nokia.com/t5/Eseries...
F-Secure ne more odstraniti ?
B. Press and hold Menu Key, Down Volume Key and Camera Key together and press the Power button on the top till the phone vibrates , restarts and goes to XXXXX
You can't get rid of it unless you do a hard reset, but don't ever try HR just get rid of this app you will lose OVI store and there is no way you could get it back. "Lock when SIM changed" option should be diabled in the phone itself under security settings.
Because it's a phone and sim security password you need to have the sim that was present with the phone when you entered the password. I hated F Secure and removed it within a week of getting the E7, simply turned it off and deleted like any other app ! Did the same with World traveller, but had a nightmare getting rid orf the locked internet access point
First uninstall Security Engine, then uninstall Mobile Security.
- spremenilo: Hayabusa ()
| » | Okvara telefona Nokia - izgublja omrežjeOddelek: Elektrotehnika in elektronika | 1477 (1239) | cegu |
| » | Nokia E51 se ne prižgeOddelek: Pomoč in nasveti | 1152 (1102) | ...:TOMI:... |
| » | Ni zvoka ali pa je popačenOddelek: Zvok in slika | 1786 (1747) | chunky |
| » | Utripajoče pismo na Nokii E5Oddelek: Mobilne tehnologije | 1898 (1539) | smesnoje |
| » | Nokia 5800 pomnilnik poln! poskušajte zapreti nekaj aplikacij...Oddelek: Mobilne tehnologije | 4057 (3822) | amigo_no1 |
