Kako predelati naslednjo PHP kodo
Penny ::
Pozdravljeni,
Zelo rad bi uporabail naslednji meni v svojem CMS-u, da bi deloval dinamično:
http://apycom.com/menus/15-olive-drab.h...
html menija izgleda takole:
<div id="menu">
    <ul class="menu">
        <li><a href="#" class="parent"><span>Home</span></a>
            <div><ul>
                <li><a href="#" class="parent"><span>Sub Item 1</span></a>
                    <div><ul>
                        <li><a href="#" class="parent"><span>Sub Item 1.1</span></a>
                            <div><ul>
                                <li><a href="#"><span>Sub Item 1.1.1</span></a></li>
                                <li><a href="#"><span>Sub Item 1.1.2</span></a></li>
                            </ul></div>
                        </li>
                        <li><a href="#"><span>Sub Item 1.2</span></a></li>
                        <li><a href="#"><span>Sub Item 1.3</span></a></li>
                        <li><a href="#"><span>Sub Item 1.4</span></a></li>
                        <li><a href="#"><span>Sub Item 1.5</span></a></li>
                        <li><a href="#"><span>Sub Item 1.6</span></a></li>
                        <li><a href="#" class="parent"><span>Sub Item 1.7</span></a>
                            <div><ul>
                                <li><a href="#"><span>Sub Item 1.7.1</span></a></li>
                                <li><a href="#"><span>Sub Item 1.7.2</span></a></li>
                            </ul></div>
                        </li>
                    </ul></div>
                </li>
                <li><a href="#"><span>Sub Item 2</span></a></li>
                <li><a href="#"><span>Sub Item 3</span></a></li>
            </ul></div>
        </li>
        <li><a href="#" class="parent"><span>Product Info</span></a>
            <div class="columns two">
                <ul class="one">
                    <li><a href="#"><span>Sub Item 1.1</span></a></li>
                    <li><a href="#"><span>Sub Item 1.7</span></a></li>
                </ul>
                <ul class="two">
                    <li><a href="#"><span>Sub Item 2.1</span></a></li>
                    <li><a href="#"><span>Sub Item 2.2</span></a></li>
                    <li><a href="#"><span>Sub Item 2.3</span></a></li>
                    <li><a href="#"><span>Sub Item 2.4</span></a></li>
                    <li><a href="#"><span>Sub Item 2.5</span></a></li>
                    <li><a href="#"><span>Sub Item 2.6</span></a></li>
                </ul>
            </div>
        </li>
        <li><a href="#"><span>Help</span></a></li>
        <li class="last"><a href="#"><span>Contacts</span></a></li>
    </ul>
</div>
Php koda za menije, podmenije v mojem cmsju pa izgleda takole:
{** block-description:text_links **}
{if $block.properties.show_items_in_line == 'Y'}
	{assign var="inline" value=true}
{/if}
{if $items}
	<ul class="text-links {if $inline}text-links-inline{/if}">
		{foreach from=$items item="menu"}
			<li class="level-{$menu.level|default:0}{if $menu.active} cm-active{/if}">
				<a {if $menu.href}href="{$menu.href|fn_url}"{/if}>{$menu.item}</a>
				{if $menu.subitems}
					{include file="blocks/menu/text_links.tpl" items=$menu.subitems}
				{/if}
			</li>
		{/foreach}
	</ul>
{/if}
Bi mi znal kdo tole predelat, da bi mi deloval zgornji meni.
Bil bi zelo hvaležen.
Tenks!! LP
  • spremenil: Penny ()
t3hn0 ::
Hja...Cisto na hitro, najprej potrebujes neko rekurzivno funkcijo, ki ti prebere strukturo (rekurzivno zato da ti pod vsako stranjo izpise se podstrani), nato pa to rabis podati tvojemu template sistemu. Seveda je vse odvisno od strukture baze in template sistema.
<?php
function mojMeni($ParentID) {
	$query = mysql_query("SELECT ID, Url, ParentID, Title, ... FROM tabela WHERE ParentID = {$ParentID} ORDER BY ID ASC", $link);
	$out = array();
	while($row = mysql_fetch_array($query)) {
		$child = mojMeni($row['ID']);
		if($child != false) {
			$out[]['subitems'] = $child;
			$out[]['href'] = $row['Url'];
			$out[]['Title'] = $row['Title'];
	if(count($out) > 0)
		return $out;
	return false;
$items = mojMeni(0);
Parsanje grdega JSON-a
Oddelek: Programiranje
162536 (2021) Spura
[ASM] Pomoč, ne najdem napake
51443 (1319) c0dehunter
Dodajanje slik (galerije) na spletno stran
Oddelek: Izdelava spletišč
61738 (1567) martincek1
[C#] toString ne dela
51627 (1517) rokpok
VB in String
91200 (1138) mov ax 0x7c0
