Pinging mcafee.com [127.0.0.1] with 32 bytes of data
AIDS ::
Pinging mcafee.com [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Kako je to mogoce ?
Nikakor ne pridem na www.mcafee.com in se sel v dos prompt in dal ping... in dobim tole ... ??
Hvala za vse informacije
andrej ::
to je cudno. 127.0.0.1 je tvoj localni host. to je v bistvu shortcut nazaj na tvoj racunalnik....
AIDS ::
MA ja, nimam pojma ... pa sem dal vse nastavitve na default pa se kr ne dela ... in to sam tujina me zajebava
Pinging www.slo-tech.com [212.93.228.2] with 32 bytes of data:
Reply from 212.93.228.2: bytes=32 time=32ms TTL=58
Reply from 212.93.228.2: bytes=32 time=19ms TTL=58
Reply from 212.93.228.2: bytes=32 time=18ms TTL=58
To dela lepo...
Pinging symantec.com [127.0.0.1] with 32 bytes of data:
TA PA SPET NE DELA ?!?!?
DEJTE POMAGAT PROSM :)
rakusj ::
kaj ti pa tracert pokaže?
Imaš kaj vpisano v lmhost in host datotekah?
AIDS ::
Tracing route to symantec.com [127.0.0.1]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms localhost [127.0.0.1]
Trace complete.
AIDS ::
v hosts mam upisan tole:
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
AIDS ::
FIREWALL NIMAM NALOZEN; tud defalult firewall mam ugasnjen od XP...tko da nimam pojma zakaj mi ne dela ?
Tud na njihovo strane ne pridem, ne od mcafee ne od symantec ...
http://auto.search.msn.com/response.asp...
Kot da bi imel blokirano ... za 1x sem ugotovil da mi ne delata symantec in mcafee :)
Matek ::
Čist možno, da maš en domiseln virus.
DMouse ::
Dobi si programček dig (dobiš ga tut zravn bind serverja), pa mal raziskuj kakšne odgovore ti pošiljajo pristojni dns serverji. Najprej pogledaš z ipconfig /all katere dns serverje uporablja tvoj računalnik, pol pa z dig npr:
dig www.mcafee.com @ip_prvega_dns_serverja
če boš s pametjo delal boš kmal ugotovu kje je srž problema ;)
AIDS ::
Windows IP Configuration
Host Name . . . . . . . . . . . . : aids
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8029(AS) PCI Ethernet Ada
pter
Physical Address. . . . . . . . . : 00-00-B4-C5-B5-4C
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 169.254.212.49
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Disabled
PPP adapter SIOL:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 193.77.140.141
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 193.77.140.141
DNS Servers . . . . . . . . . . . : 193.189.160.11
193.2.1.66
AIDS ::
A JE TLE KEJ SUMLJIVGA ?
VIRUSA NIMAM...SPYWARE TUD NE ... tko da tole mi res zivce para :)
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 193.77.140.141 193.77.140.141 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
169.254.0.0 255.255.0.0 169.254.212.49 169.254.212.49 30
169.254.212.49 255.255.255.255 127.0.0.1 127.0.0.1 30
169.254.255.255 255.255.255.255 169.254.212.49 169.254.212.49 30
193.77.140.141 255.255.255.255 127.0.0.1 127.0.0.1 50
193.77.140.255 255.255.255.255 193.77.140.141 193.77.140.141 50
213.250.19.83 255.255.255.255 193.77.140.141 193.77.140.141 1
224.0.0.0 240.0.0.0 169.254.212.49 169.254.212.49 30
224.0.0.0 240.0.0.0 193.77.140.141 193.77.140.141 1
255.255.255.255 255.255.255.255 169.254.212.49 169.254.212.49 1
Default Gateway: 193.77.140.141
Persistent Routes:
None
A to je ok ? Gateway = MOJ IP ?
ABX ::
Tu zgleda vse ok
127.0.0.1 imaš samo za tvoj ip
Probaj še
ipconfig /flushdns
DMouse ::
Routanje ni problem, problem je v dns! Nek dns server ti dopoveduje (ali pa tvoj računalnik sam tko misl) da ma www.mcafee.com ip 127.0.0.1. Routanje pa pride pol v poštev, ko se hočš povezat s tem računalnikom (al pa ga pingat).
vasquez ::
Delovanje DNS lahko preveriš s programom nslookup:
nslookup mcafee.com
ali pa
nslookup mcafee.com kanin.arnes.si
če hočeš uporabiti arnesov DNS.
Imata pa datoteki hosts in lmhosts prednost.
AIDS ::
C:\Documents and Settings\A I D S>nslookup mcafee.com kanin.arnes.si
Server: kanin.arnes.si
Address: 193.2.1.66
Non-authoritative answer:
Address: 216.49.88.133
C:\Documents and Settings\A I D S>ping 216.49.88.133
Pinging 216.49.88.133 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 216.49.88.133:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Vasquez, evo sem probu in lej kaj dobim...
Dobil sem od mcafee ip in ga probu pingnt... spet request time out ?
A mas se kaksno idejo ? Ker meni jih je zmanjkalo.
ABX ::
Ni nujno da mcafee vrača ping request-e.
vasquez ::
Tole je OK. Ne pustijo se vsi serverji pingat (isto dobim jaz).
Problem je v tistem delu, ki pretvarja imena serverjev v IP številke. To je prvo kar se naredi če napišeš ping mcafee.com.
Najprej se preveri DNS cache in hosts datoteka, potem se šele uporabi DNS (nslookup). Lahko pa je vmes še kaj, kar mi ni znano.
Recimo kakšen virus. Glede na to, da dobiš fake IPje pri izdelovalcih protivirusnih programov, bi znalo biti to verjetno.
Zakaj mi ne odpre samo ene določene strani?
Oddelek: Omrežja in internet
288445 (4485) BorutK-73
Misteriozni IP
82930 (2730) Brane22
Odzivni čas v nanosekundah
51752 (1478) Spc
Prenašanje cookijev med poddomenami
202321 (2036) jype
Težava z modemsko povezavo v Win2003
61472 (1423) Alexius Heristalski
