Nekaj vprašanj o raid-u
Border ::
Lep pozdrav!
Imam Maticno plosco ASUS P4PE goldV., na kateri je RAID (vtikaci za RAID: 1x paralel IDE in 2x serial ATA)! Rad bi naredu RAID 0. Imam dva diska WD 80Gb (7200|8Mb| mislim, da so ATA100). Imam SATA kable vendar jih ne morem priklopiti na diska,...
1. Kaj se moram kaj kupiti?
2. Kaksni so vasi nasveti?
3. Mislite, da bi bila diska hitrejsa, ce bi bila vsak posamezno?
4. Kaksen naj bo "blockSize"?
5. V cem je razlika med ATA100 , ATA 133 in SATA150??
V NAVODILIH ZA MB PISE KAKO NAREDITI RAID:
Connect the HDD cables. Three connection options are avalible for creating a RAID 0 or RAID 1 array:
1. Connect one Parallel ATA HDD to PRI_RAID1 connector and one Serial ATA HDD to either one of the two SATA connectors, using separate parrallel ATA or serial ATA cables.
2. Connect one Serial ATA HDD to each Serial ATA connector, using separate Serial ATA cables.
3. Connect one Serial ATA HDD to PRI_RAID1 connector and one Serial ATA HDD to either one of the two SATA connectors, using separate parrallel/serial ATA cables.
ASUS P4PE MB GOLD VERSION
  • spremenil: V-i-p ()
Border ::
Kje naj kupim Sata konektorcke?
tisti pretvornikov se (se) ne da kupit.dubis jih samo zravn samostojnih kontrolerjih, pa se mi zdi da pr enih platah.
  • spremenil: Dr_M ()
Dva računalnika na izbiro
121770 (1613) opeter
Je ta konfig OK? Hitra pomoč potrebna
82337 (2142) Area_51
Serial ATA
103736 (3573) JIM22
nForce 3 (PR)
61929 (1792) noraguta
Serial ATA
242234 (1860) Mr.B
