Forum » Navijanje » Slo-Tech 3D Team: Blender Cycles 2.61 Benchmark
Janac ::
Najprej preberi prvi post v celoti.
Renderiramo:
Naložite Blender: http://www.blender.org/download/get-ble...
Sceno: http://dl.dropbox.com/u/1742071/1m/BMW1...
Brez spreminjanja nastavitev! Za začetek renderiranja pritisnite F12.
Če hočete na lestvico zajemite ScreenShot z odprtim CPU-Z(Memory ter CPU) in GPU-Z.
Napišite še:
1. [Ime] - [CPU model/freq.] - [GPU model/drivers/freq.] - [RAM model/freq.] - [OS] - [Datum] - [Čas]
Primer:
REZULTATI:
Vsi rezultati dobrodošli :)
Renderiramo:
Napišite še:
Primer:
REZULTATI:
1. [Janac] - [i5 3570K/@3.4Ghz] - [7870 (Tahiti LE)/13.1/@975Mhz/1500MHz] - [G. Skill 2GB 9-9-9-24T/1600Mhz] - [Windows 8 Pro 64bit] - [9.3.2013] - [05:48.42]
- spremenil: Janac ()
b3D_950 ::
Blender version: 2.66 CPU: 2x Intel(R) Xeon(R) CPU X5355 @ 2.66GHz (2x4) RAM: 4GB ECC DDR2 GPU: NA OS: xbuntu 12.10 x86 Time: 3 min 19 sec (CPU)
Blender version: 2.66 CPU: 1x Intel(R) Pentium(R) CPU G620 @ 2.60GHz (1x2) RAM: 8GB DDR3 1066 GPU: Nvidia GTX 560 OC OS: ubuntu 12.04.2 LTS x64 Time: 1 min 54 sec (GPU) Time: 10 min 0 sec (CPU)
p.s.: GPU čas lahko z bolj optimalno nastavitvijo zmanjšaš tudi za +30 sec brez problema.;)
Xserces ::
"Noben drug nima namena pognati?"
ne ker se nam neda vsak dan novga bencha dol ulect...
- spremenil: Xserces ()
b3D_950 ::
2loud4u ::
prilagam, ker sem pozabil zraven slikat:
[2loud4u] - [2× Xeon E5320/@1.86Ghz - stock] - [6850 13.1/775/1000 - stock] - [Hyundai Electronics 4GB ECC Registered FB-DIMM 667MHz] - [Windows 7 Ultimate 64 bit] - [16.3.2013] - [06:49.28]
Zanimivo, da blender sploh ne reagira na kakršnokoli navijanje ali cpu-ja ali grafične, rezultat je vedno enak...
c^2=E/m
HP XW6400|2× Xeon E5320 @1.86GHz|16MB L2
Cache|Sapphire HD6850|4GB FB-DIMM|HP 575W
- spremenil: 2loud4u ()
HighBane ::
Meni pa je razlika pri naviti in nenaviti grafični 19 sekund.
GPU [HighBane] - [AMD FX 8320 - stock (3500Ghz)] - [GTX 460 314.07/860/1000] - [Corsair Vengeance 8GB / 1333] - [Windows 7 64 bit] - [17.3.2013] - [01:50.82]
CPU [HighBane] - [AMD FX 8320 - stock (3500Ghz)] - [GTX 460 314.07/860/1000] - [Corsair Vengeance 8GB / 1333] - [Windows 7 64 bit] - [17.3.2013] - [05:17.37]
Halfdead987 ::
Naviti ? Pri obeh imaš isto frekvenco
Sicer je pa razlike malo veliko.
- predlagal izbris: Janac ()
HighBane ::
Pri prvi navedbi je grafična zrendirala sliko pri drugi pa CPU. Sem samo dal za primerjavo. Pri stocku (715/900) je grafična imela čas 2:09.
2loud4u ::
"Meni pa je razlika pri naviti in nenaviti grafični 19 sekund."
Aja, to misliš, ko rendiraš z grafično, jaz sem govoril, da se pri rendiranju s CPU-ji ne pozna niti, če naviješ CPU, niti če naviješ GPU.
c^2=E/m
| » | Slo-Tech 3D Team: Unigine Valley 1.0 (strani: 1 2 3 )Oddelek: Navijanje | 29985 (18048) | dj_uro |
| » | Unigine Heaven 4.0 (strani: 1 2 3 )Oddelek: Navijanje | 51128 (36534) | barocco |
