Forum » Programska oprema » C++ debugging
C++ debugging
black ice ::
Naložil sem Eclipse Juno na Win 7 x64. Program se izvede brez napak, ko pa želim debuggati mi javi naslednjo napako:
Kaj sem spregledal?
Error in final launch sequence Failed to execute MI command: -gdb-set auto-solib-add on Error message from debugger back end: No symbol table is loaded. Use the "file" command. No symbol table is loaded. Use the "file" command.
Kaj sem spregledal?
| » | Težava Microsoft-Windows-Kernel-Power (strani: 1 2 )Oddelek: Pomoč in nasveti | 10222 (7232) | Anney |
| » | BSOD problemOddelek: Pomoč in nasveti | 2237 (1895) | Oktan |
| » | Windows XP Black screenOddelek: Pomoč in nasveti | 4782 (4522) | Twix |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2913 (2652) | Duhec |
| » | BSOD pri Remote Desktopu v Win 2003 Server R2 Enterprise SP2Oddelek: Pomoč in nasveti | 2338 (2165) | ender |
