Outlook Kategorija + Script
Lombi ::
Hej hej.
Imam malenkost problema pri skriptanju Outlooka in sicer zelim da mi maile v rule-u preposlje mail v evernote s tem da doda noter dolocene kljucne besede v subject.
Trenutno to resujem s kategorijami, vendar kategorijo zapopade script sele "v drugo" (ko se ze enkrat zazene in ji doda kategorijo). Ima kdo kako drugo resitev za ta problem?
Rule zgleda takole:
Apply this rule after the message arrives
from yyy or xxx@xxx.com
and on this computer only
assign it to the zzzzz category
and run ModifySubject.ThisOutlookSession. RunAScriptRuleRoutine
Script:
Sub RunAScriptRuleRoutine(MyMail As MailItem)
 Dim strID As String
 Dim olNS As Outlook.NameSpace
 Dim msg As Outlook.MailItem
 Dim fwd As Outlook.MailItem
 strID = MyMail.EntryID
 Set olNS = Application.GetNamespace("MAPI")
 Set msg = olNS.GetItemFromID(strID)
 ' do stuff with msg, e.g.
 msg.Subject = msg.Subject & " @Email arhiv" & " #" & msg.Categories
 msg.Save
 Set msg = Nothing
 Set fwd = Nothing
 Set olNS = Nothing
End Sub
Najlepsa hvala!
moja video predavanja za adobe in wordpress: 321.si
moje slike in animirani filmi: lo.si
Visual Basic
Oddelek: Programiranje
314266 (3292) cekr
batch fajl iz txt (strani: 1 2 )
6513131 (11792) b3D_950
[Access 2007]
133062 (2662) urosz
Pomoč pri nastavitvah NTbackup.exe v win xp
Oddelek: Programska oprema
291995 (1724) XWY
XP profesional in IIS
Oddelek: Izdelava spletišč
91396 (1261) alesrosina
