XP profesional in IIS
Border ::
Lep pozdrav!
Imam win XP profesional in instaliran IIS, ki mi odlicno deluje. Normalno delam z ASP vpis in izpis iz baz mdb. Ko pa je ce zelim narediti mail formo?
Set Mail = Server.CreateObject( "CDONTS.Newmail" )
Mail.MailFormat = 0
Mail.BodyFormat = 0
Mail.From = email1
Mail.To = email2
Mail.Subject = "bla"
Mail.Body = sporocilo
Mail.Send
Set Mail = Nothing
JAVI MI ERROR
Error Type:
Server object, ASP 0177 (0x800401F3)
Neveljaven razredni niz
/email1.asp, line 26
kje kaj nastavim?
andrej ::
Border ::
EVO NASEL SEM TOLE IN VSTAVIL V "C:\Inetpub\wwwroot\ "
Dim iMsg
Dim iConf
Dim Flds
Dim strHTML
Dim strSmartHost
Const cdoSendUsingPort = 2
StrSmartHost = "smarthost"
set iMsg = CreateObject("CDO.Message")
set iConf = CreateObject("CDO.Configuration")
Set Flds = iConf.Fields
With Flds
.Item("http://schemas.microsoft.com/cdo/config... = cdoSendUsingPort
.Item("http://schemas.microsoft.com/cdo/config... = strSmartHost
.Item("http://schemas.microsoft.com/cdo/config... = 10
.Update
End With
With iMsg
Set .Configuration = iConf
.To = "nekdo@mail.si"
.From = "nekdo@mail.si"
.Subject = "naslov"
.HTMLBody = "test"
.Send
End With
Set iMsg = Nothing
Set iConf = Nothing
Set Flds = Nothing
CE NISEM POVEZAN PREKO ISDNA NA NET JAVI TOLE:
Error Type:
CDO.Message.1 (0x80040213)
Povezava s strežnikom pri prenosu ni uspela.
mail.asp, line 30
CE PA SEM POVEZAN PREKO ISDNA NA NET PA TOLE:
Error Type:
mail.asp, line 30
KAJ SE MORAM TU NASTAVT? SE KJE DA STREZNIK NASTAVLJAT?
HVALA ZA POMOC!
  • spremenil: Border ()
andrej ::
mas SMTP streznik pravi?
Border ::
Ka pa jaz vem? Kje se to nastavi? Daj mi napisi vse korake kako in kaj, lepo prosim andrej!
Border ::
no sedaj sem ze nasel admin nastavitve "moj racunalnik" desni gumb in upravljaj. Potem izberem storitve in aplikacije in nato IIS.
potem mam na izbiro SMTP in WEB Sites... z desnim gumbkom na eno od teh dveh ikon mi pokaze Lastosti...
in kja naj sedaj?
Border ::
No naj povem, da mi WEb sites normalno deluje, ko vstavim v IEju svoj IP... pa tud v SMTPju sem natsavil svoje IP pa mi ni hotlo poslat? Sedaj pa res ne vem nc vec...POMOC
andrej ::
probaj tole
Border ::
Oj,
Ne dela zadnja varianta!
Test sm naredu s tem ne dela : http://msdn.microsoft.com/library/defau...
Ej sigurn nimam prav nastavljen SMTP... dej povej kok mas ti... a teb tud dela? Si naredu test na svoji masini?
alesrosina ::
aspemail.com
poskusi to, z CDO objektom ni ravno priproceno posiljat maile (oz. ni zanesljivo - ce ti uspe poslat mail, potem ga ponavadi dobis na e-mail sele cez par dni). Jaz uporabljam ta objekt ze par let, pa me se ni pustil na cedilu (imas nekje tud free varjanto, sicer mal manj opcij ampakje cist kul za osnovno posiljanje mailov).
[ACCESS] Pomoč
Oddelek: Programiranje
82433 (2230) Stewie
Spletna stran ASP
Oddelek: Izdelava spletišč
71776 (1537) inferno666
ASP in loop problem
101838 (1685) rap3r
Shraniti XML string iz interneta na strežnik (ASP)
62358 (2254) tejcek
CDONTS in javascript
91410 (1322) sp4yk
