Forum » Programiranje » Outlook Kategorija + Script
Lombi ::
Hej hej.
Imam malenkost problema pri skriptanju Outlooka in sicer zelim da mi maile v rule-u preposlje mail v evernote s tem da doda noter dolocene kljucne besede v subject.
Trenutno to resujem s kategorijami, vendar kategorijo zapopade script sele "v drugo" (ko se ze enkrat zazene in ji doda kategorijo). Ima kdo kako drugo resitev za ta problem?
Rule zgleda takole:
Script:
Najlepsa hvala!
Rule zgleda takole:
Apply this rule after the message arrives from yyy or xxx@xxx.com and on this computer only assign it to the zzzzz category and run ModifySubject.ThisOutlookSession. RunAScriptRuleRoutine
Script:
Sub RunAScriptRuleRoutine(MyMail As MailItem)
Dim strID As String
Dim olNS As Outlook.NameSpace
Dim msg As Outlook.MailItem
Dim fwd As Outlook.MailItem
strID = MyMail.EntryID
Set olNS = Application.GetNamespace("MAPI")
Set msg = olNS.GetItemFromID(strID)
' do stuff with msg, e.g.
msg.Subject = msg.Subject & " @Email arhiv" & " #" & msg.Categories
msg.Save
Set msg = Nothing
Set fwd = Nothing
Set olNS = Nothing
End Sub
Najlepsa hvala!
moja video predavanja za adobe in wordpress: 321.si
moje slike in animirani filmi: lo.si
| » | Visual BasicOddelek: Programiranje | 4266 (3292) | cekr |
| » | batch fajl iz txt (strani: 1 2 )Oddelek: Programiranje | 13131 (11792) | b3D_950 |
| » | [Access 2007]Oddelek: Programiranje | 3062 (2662) | urosz |
| » | Pomoč pri nastavitvah NTbackup.exe v win xpOddelek: Programska oprema | 1995 (1724) | XWY |
| » | XP profesional in IISOddelek: Izdelava spletišč | 1396 (1261) | alesrosina |
