Intel izdal nove Atome za strežnike
2
CaqKa ::
krneki0001 je izjavil:
atom S12XX ima porabo od 6.5W do 8.5W na procesor. Opteron 6XXX pa 10x več od 85W do 115W na procesor.
Torej en opteron 6XXX ima vsaj toliko porabe kot 10 atomov S12XX.
performance per watt je pa 115.06 za atoma proti 31.3 za opterona. Torej je izkoristek nekje 3.5X boljši od atoma nasproti opteronu.
Kakšna pa je enota za "performance"?
Spock83 ::
Zanimivo kaj se že dobi od Supermicrota.
CPU/Chipset
Intel Ivy Bridge-M ECC i7-3517UE, FCBGA1023,17W, 1.7GHz, 4MB, Turbo boost to 2.8GHz
Intel Panther Point Mobile QM77 Express Chipset, 4.1W
Up to 16GB DDR3-1600MHz ECC SODIMM x2
1 PCIe 3.0 x16, 1x Mini-PCIe (mSATA support)
2 SATA3 6Gb/s and 4 SATA2 3Gb/s ports (Raid 0/1/5/10
I/O Connectors
HDMI, Display Port , DVI-I and eDP with HD Graphics 4000
1x COM Port header
Quad GbE LAN ports with Intel 82579LM and 3x 82574L
4x USB 3.0 (2 by header), 8 USB 2.0 (6 by headers)
Misc
3x 4-pin Fan connector, SATA DOM Power Connector , TPM header, SMbus Header
Realtek ALC888S ,7.1 HD Audio
0 ~ 60C Operating Temperature.
FCC B, WHQL, AMT 8.0, vPro
Mini-ITX 6.75"x6.75", 10 Layers
A to je tista zadeva za 700e?
krneki0001 ::
ja huda zadeva, samo cena je najbrž temu primerna. Si pogledal na kaki strani kok je price za to zadevo.
Sem danes celo popoldne poslušal SM cvetke, do konca leta obljubljajo 3U škatlo s 96 8core avoton nodei. Nebivedu, nekaj zate ;)
Spock83 ::
Mislim da so tiste plošče z i7 procesorjem okoli 500e če se ne motim.
Ja avton bo slasten.
CPU/Chipset
Intel Atom Avoton SoC S2xxx, BGA1283, 20W, 2.4GHz, 8 Core 20W or 4 Core 14W
DDR3 up to 1600MHz Up to 32 GB ECC SODIMM
1 PCIe2.0 x8
2 xSATA 3.0, 4 x SATA 2.0
I/O Connectors
VGA from AST2400
2 COM ports (1 by rear)
4USB 3.0(2 by rear, one type A), 2 USB 2.0 Ports by rear
Quad GbE LAN Ports (Intel I347-AT4)
Misc
IPMI 2.0 with KVM on dedicated LAN
3 4-pin Fan, TPM header, SATA DOM Power connector
12V DC In and ATX Power
6.7 x 6.7 " mini-ITX
0 ~ 60 Degree C Operation Temperature.
FCC B, WHQL
Če bo vse po sreči dobim sample julija in to z 8 corov :D
  • spremenil: Spock83 ()
A te mislis? Pa se visji TDP imajo.
Spock83 ::
Ups. Sem dobil za info za i5-3610ME procesorje.
Jp i7 različica je kar dražja in zna biti 700EUR.
krneki0001 ::
Cena je malo visoka???
A chassis loaded up with 45 Atom S1200 nodes, each with 8GB of memory and a 500GB SATA drive, plus one switch module, costs $61,875. HP is not breaking down the prices for the chassis, nodes, and switch.
Res je pa to:
45 X procesor
45 X 8GB ECC DDR3 rama
45 X 500GB SATA disk
4 portni switch
Za switch se neki govori, da naj bi bil 10Gbit. To je pa potem že neka realna cena.
Meni se zdi cena zelo dobra, še posebej, ker sem slišal ceno od Bostona za podobno arm škatlo.
krneki0001 ::
No ja, cena je realna. Upam, da jih bodo še pri kakšni firmi kopirali, da bo konkurenca in da cena še za ene 20 do 25% dol pade, potem pa najbrž kupim celo kišto s 45 nodi. Pa kr nekaj serverjev gor in optiko 100/100 zraven.
Poraba cele kište ne bo 1000W, tako da bo tole kr odlična zadeva za "domači" orenk server.
http://www.theregister.co.uk/2013/04/09...
"And when you do the math - assuming what we presume is pretty poor but nonetheless typical utilization on those two-socket x86 boxes - a rack of the Moonshot servers based on the Atom S1200 processors uses 89 per cent less energy and 80 per cent less space, at a cost per node that is 77 per cent lower."
Spock83 ::
Pride oktobra Supermicro z 48 nodi in vsak node bo imel Avotona od 2 pa do 8-corov.
2
Prvi integrirani Xeoni SoC
Oddelek: Novice / Procesorji
3111707 (8789) Spock83
AMD pripravlja obilico strežniških novosti
84768 (3506) pegasus
Facebookova grožnja HP-ju, Supermicru in drugim velikanom
2413701 (11958) PrimozR
Intel izdal nove Atome za strežnike (strani: 1 2 )
6315076 (12431) Spock83
Vojna med Intelom in nVidio
387006 (4862) PrimozR
