Izrael : Palestina že n-tič
ANTI-CENZURA ::
TezkoDihanje je izjavil:
nova mapa:
https://twitter.com/nexta_tv/status/171...
The #Israel Defense Forces says it struck a Hamas tunnel built under a high-rise tower in the northern #Gaza
"An operational terrorist tunnel used by the terrorist organization Hamas was attacked. The tunnel is located under a high-rise building in Fatah Darj in the north of Gaza City," the IDF says in a statement.
Verjetno bodo s tem načinom na žalost kar sami pobili zajete talce, ki jih Hamas zadržuje v teh predorih.
Tudi tisti, ki so živi, so v resnici žal že mrtvi. Si sploh ne predstavljam, kaj te ljudje doživljajo pod temi živalmi. Pa je to žaljivka do živali.
- spremenilo: ANTI-CENZURA ()
dexterboy ::
Khm... kdaj bomo videli pri blagajnah živilskih blagovnih znamk košare z napisom "za Izraelske sirote"?
Sprašujem za prijatelja...
370 mrtvih Palestincev.
TezkoDihanje ::
BREAKING: Hamas terrorists massacring Israelis were trained by Russia's Wagner PMC and Redut PMC terrorist groups with Putin's approval.
Blowback for the West's inadequate support of Ukraine to neutralize Russia.
Scaramouche3 ::
Židi imajo Ameriko pod kontrolo, Rusije še ne...
Zrtve so res Palestinci. Ampak se najmanj od Izraela. So zrtve Sirije, Egipta, SA, Irana itd. Vse muslimanske drzave jih izkoriscajo za preusmerjanje pozornosti in iskanje zunanjega sovraznika.
Drugace bi ze zdavnaj imeli sporazum in 2 drzavi.
- spremenil: kow ()
Scaramouche3 ::
Israeli says to American stopped by Israeli police: "The Godly thing to do is to kill you.
Scaramouche3 je izjavil:
Israeli says to American stopped by Israeli police: "The Godly thing to do is to kill you.To da so oboji neandertalci, ni treba posebej poudarjati. Boljse sicer Izrael, kot Iran in ostala radikalizirana drhal.
Ti mora dosti faliti, da se greš z oboroženimi pavijani kregati o veri. Je že boljša ruska ruleta. Je vsaj v trenutku konec.
Nemci bod pa prej ali slej morali zaključiti s svojo naci samopomilovanjem, ultra desničarski Izraelci se jim že prav režijo, ostali desni v evropi pa kmalu, čez generacijo jih pa tako ali drugače, no Nemce ne bo jemal resno.
blay44 ::
Malo sem preletel situacijo.
Očitno so se vloge zamenjale. Sedaj Izraelci lovijo zajce in
une norce. Glede na premike težke mehanizacije najbrž Gaze
ne bo več v roku 24 ur.
Vseeno mislim, da bi morala obstajati EU, ZDA delegacija ali
opazovalci v štabu in glede na etična merila posredovati med
odrejanjem ciljev. Fak no. Zamisliš se ko napišeš "tarče".
Tile managerji so zjebali svet.
Kapitan Jack ::
Fuj, ker posran narod.
Bostjan_321 ::
SZ torej tudi Rusija je podpirala Izrael in pomagala ustanoviti državo.
Izrael in Rusija so buliji
Ni lepo gledati, da umirajo ljudje na eni in drugi strani ... ampak palestinci so si z včerajšnjim napadom na izrael že izkopali jamo, izraelci pa jih bodo še samo zvrnili v jamo. Če bi jaz bil voditelj, bi naredil isto - napadel bi nazaj z vsem s čimer razpolagam. Ne bi jim ostal dolžen ...
Če še kdo ni opazil, skoraj povsod, kjer so muslimanske države ali po večini prevladujejo muslimani, so povsod notranji problemi ... v iraku svoji koljejo svoje, v afganistanu svoji svoje, v siriji svoji svoje, v pakistanu svoji svoje itd itd ... In potem so za rusofile krivi za vse težave tam dol, američani ... Američani so hoteli narediti red, ampak ga je nemogoče. To so ekstremisti in globoko zagriženi verniki, katerih ne moreš prepričati in so pripravljeni umreti zraven za svoj prav.
Muslimani so destabilizator svetovnega miru. Niso vsi muslimani slabi, ampak očitno je, da je nekaj z njihovo vero hudo narobe. Eni muslimani govorijo, da njihova vera ne govori o nasilju, drugi pa za vsako sranje, ki ga naredijo, povzdigujejo vero v višave, kot da je vera razlog, zakaj klati po svetu.
Saj so kristjani nekoč, pred 200 leti in več naredili ogromno sranja po svetu, največ po južni ameriki, kjer so klali vse po vrsti, ki se ni strinjal z njihovo biblijo. Ampak kristjani so par stoletij pred muslimani, zato so se hitro streznili in dali mir. Danes kristjani ali krščani več ne delajo sranja po svetu zaradi vere ampak zaradi politike, kjer vsak hoče na nek način obogateti, si koga podrediti in kaj od tega imeti.
Danes pa najhujše stvari po svetu povzročajo muslimani, teroristi, ki so večinoma muslimani. Pedofilija, družinski umori iz časti, ženske so v večini muslimanskih držav ničvredne, njim danes ni več nič takega, če z mečem sekajo glave stran itd itd ...
ZDA so lepo rekle, da naj Hezbolah in Iran 2x dobro premislita preden sprožita napad na Izrael in poslale vojaško ladjevje v bližino.
Malo zgodovine za osvežitev:
Še eno morda preveč enostransko mnenje, ampak ker je ravno sveže:
Še kot zanimivost:
Še kot zanimivost:
The term "Palestine" first appeared in the 5th century BCE when the ancient Greek historian Herodotus wrote of a "district of Syria, called Palaistinê" between Phoenicia and Egypt in The Histories. Herodotus provides the first historical reference clearly denoting a wider region than biblical Philistia, as he applied the term to both the coastal and the inland regions such as the Judean Mountains and the Jordan Rift Valley. Later Greek writers such as Aristotle, Polemon and Pausanias also used the word, which was followed by Roman writers such as Ovid, Tibullus, Pomponius Mela, Pliny the Elder, Dio Chrysostom, Statius, Plutarch as well as Roman Judean writers Philo of Alexandria and Josephus. There is not currently evidence of the name on any Hellenistic coin or inscription.
In the early 2nd century CE, the term "Syria Palaestina"[a] (literally, "Palestinian Syria") was given to the Roman province of Judaea either before or after the suppression of the Bar Kokhba revolt in 135.
he English term "Palestine" itself derives from the Latin Palaest?na, which, in turn, derives from the Koine Greek ???????????, Palaist??n?, first attested in the 5th century BCE. Per Martin Noth, the name likely comes from a proto-Semitic word, albeit there is a strong similarity between Palaist??n? and palaist?s, the Greek word for "wrestler/rival/adversary", which has the same etymological meaning as the Hebrew word "Israel." This was expanded by David Jacobson to theorize the name being a portmanteau of the word for Philistines with a direct translation of the word Israel into Greek (in concordance with the Greek penchant for punning on place names.)
Whilst the term was used in Egyptian and Assyrian times, prior to the time period in which the Bible is thought to have been written, scholars generally conclude that the term is cognate with the Biblical Hebrew ?????????????? P?l?št?m.
- spremenil: Gregor P ()
xseki ::
Izraelske letalske sile so v Evropo poslale transportno letalo, s katerim se bo vrnilo več sto Izraelcev, ki bodo služili kot vojaški rezervisti.
Glede na nekatere sodelujoče v temi, kot kaže, je to alternativna
zgodovina, in bi morali biti Palestinci zahvalni da že zadnjih 30+ let
živijo v humanih kampih z ograjo, tam kjer ograje ni pa dvojno bodečo žico.
https://www.aljazeera.com/news/2023/10/...
-about-a-simple-guide
Kako je tudi smešno poslušat da so izraelska obveščevalne službe zatajile.
Verjetno je to z malo žrtvami , možno doseže da zamenja kader, ki je
premalo nacionalistično desen in istočasno izvajati deratizacijo , kot
pravijo Židje golazni.
Nekateri v tej in podobnih temah, uporabljajo citirano izrazoslovje iz no
starih fašističnih časov, so vas v jugi dobro oprali.
Sedaj pa izziv za vse tiste, ki zanikate mednarodne humane inštitucije.
Povije nekaj humanih citatov o Palestincih s strani vladajoče koalicije, še
iz časov ko niso bili v vladi in potem ko so bili. Pazite da ne boste
citirali citiranih izjav nacistov.
Moja interpretacija je, da se Abbas zeli boriti do zadnjega Palestinca. Jebiga, prevec koke. Morda ima tudi kaksne biolabe?
Vemo, da se je Bandera nacizma ucil prav od Palestincev.
- spremenil: kow ()
papasmrk ::
Če Izrael sedaj ne bo očistil Hamas in ostalo đihadistično zalego v svoji državi potem ne vidim več razloga, da bi sploh še obstajal.
Lepo pove, da so tam živeli s svojo nacijo pred Rimljani ki so jim jo vzeli…
On so nacija. Ljudje ki so živeli tam pred 1930 so pač neki nomadi, ki so se notrebno plodili... No skoda da so americani deratizirali obstojeco zemljo od teh s perjem osmesenimi lokalnimi nomadi, drugace bi se lahko bili primorani preseliti od tam kjer so prisli...
ok, bodi bolj kultiviran. Sej ves da zgodovino pise tisti s kontrolo medijev.
- spremenil: Mr.B ()
trololololo ::
Eden od faktorjev uspešnosti napada naj bi bil tudi praznik, kjer so izraelci v velikem številu pustili elektronske naprave doma (v smislu verskega očiščenja), veliko jih tudi ni bilo na vojaških položajih zaradi tega praznika.
Da bo ironija potem večja je Hamas vdrl v hiše civilistov in prisilil ljudi tam, da so se prijavili v socialna omrežja. Tako je bilo več primerov kako so ubili civiliste - v živo pa so streamali preko njihovih lastnih socialnih omrežjih njihov umor. Skratka zadnja objava tvoje socialne strani je tvoj lastni umor.
Na splošno je za razumet, da za Izraelce pomeni to dejanje Hamasa ekvivalent holokavstu. Koliko sem poslušal pravijo, da tiste vojne ki so bile z Arabci so bile teritorialne narave. To pa razumejo kot eksistenčno nevarnost. Skratka tako jezni verjetno zadnjih 70 let še niso bili. Popolnoma so izgubili razum, vodijo jih samo še čustva. Kar bo sledilo pa si lahko predstavljate.
Ker trdis, da jih vodijo "samo custva", bi me zanimalo kaj naj bi naredili, ce bi jih vodil "samo razum". Hvala!
- spremenil: kow ()
Bo, bo, od Gaze bodo ostali le še spomini in fotografije.
Evo vam palestinske teroriste povsod po svetu...
https://twitter.com/AustralianJA/status...
In tako svojo teroristično propagando širijo svobodno po svetu, rusofili pa jih zagovarjajo...
AgJ1 ::
Saj vse normalne vojske na svetu vzamejo talce in potem nasprotnikom gozijo, da bodo talce pobili, če le-ti ne izpolnijo njihovih pogojev, a ne?
In seveda ob vojaških akcijah izvajajo safari nad civilisti, ki jih potem žive ali mrtve paradirajo pred kamerami kot trofeje?
Pred 110-imi leti leti je bilo to ozemlje pod Otomanskim imperijem. Ker se je ta imperij odločil sodelovati z Nemškim cesarstvom v 1. sv. vojni, so jih Angleži hoteli sesuti s pomočjo tam živečih arabskih plemen (sedaj Palestinci), katerim so obljubili samostojno državo in s tam živečimi Judi, katerim so tudi obljubili samostojno državo. Smola za oboje je pa ta, da so Angleži obljubili obema isto ozemlje. Po 1. sv vojni so nad tem ozemljem držalo roko Angleži in vzdrževali svojo oblast ter mir.
Po 2. sv. vojni so Judje potem le dobili svojo državo (tudi zaradi holokavsta), ampak to ni bilo dogovorjeno/usklajeno s tam živečimi (rečimo jim) Palestinci, zato je je takoj po razglasitvi države Izrael začela arabsko izraelska vojna, katero so za las dobili Izraelci.
Sedaj pa lahko začnemo lepiti zemljevide, kje so živeli kateri v časovnem obdobju po 1948.
Oba dva naroda sta zelo bojevita, če eden ne bi bil, ga tam ne bi bilo več. Oba dobivata pomoč od zunaj, da lahko eksistirata.
To kar se je Hamas šel sedaj, je nepremišljeno, se bo za Palestince v Gazi zelo slabo končalo, predvsem bodo kratko potegnili civilisti. Tisti, ki so to organizirali, so se že verjetno poskrili, zaslepljeni vojaki so pa nesli glavo na prodaj.
PS Ne bi enemu vzel in drugemu dal. Bosta potrebni kar lepo dve državi, ločeni z visokim zidom in da se čim manj vmešavata ena v drugo.
- spremenilo: fikus_ ()
SasoS ::
Zgodovina je žal polna krivic. Ne moreš vseh popraviti... ja, res je, po ww2 so Palestincem vzeli zemljo, tako kot so marsikje izselili npr. Nemce pa Poljake iz današnje zahodne Ukrajine in tako dalje.
Problem je, da Palestinci vztrajno zavračajo 2 state solution, ki je bil ponujen že leta 47. Yes, tough luck...75 let nazaj so jih zajebali, tako kot Kurde in še koga... ampak ne raztreljuješ se zato sredi avtobusnih postaj polnih ljudi.
Tudi če se jim da državo, ali kdo misli da bo to kaj drugega kot islamistična diktatura in novo leglo terorizma? Hamas je to dokazal...zato se Palestincev tudi sosednje islamske države otepajo. Free Palestine bo bolj Welcome to Palestine Islamic Caliphate.
OutOfTheBox ::
To je dejansko on point.
... ja, res je, po ww2 so Palestincem vzeli zemljo, ...Glede na to da so ta arabska plemena tam bili bolj nomadi, jim niso ravno vzeli zemlje, ker si jo niti niso zares lastili ... lastniški koncept je prišel kasneje, recimo ko so Izraelci od Arabcev (ne nomadov, ampak tistih "drugih" bogatejših Arabcev, kjer so ti arabski nomadi bili njihovi hlapci ipd.) začeli kupovati zemljo tam ipd.
Ampak bile so vojne, nekateri so jih sprožili, drugi izgubili, kako daleč nazaj naj zdaj gledamo v zgodovino?
blay44 ::
To je čisto res. Samo sprejeli so vlogo kmeta na šahovnici
in pokazali naverjetno krutost. Daleč od civilizacijskih,
kaj šele etičnih norm.
Zdej, da ne bomo v ljudeh.
Tole nakazuje, da gre za čisti barbarski pohod, daleč od kake borbe.
https://t.me/vchkogpu/42602
Informacijsko so jih čisto zaprli. Vse kar je zaslediti, da
so pobili 1500 kao norcev. Zdej, če so brez vode in niso
shranili strateških zalog, bodo začele razsajati bolezni.
Drugi se jim izogibajo, ker so enaki kot so za nas cigani. Tudi obnašajo se enako.
xseki ::
Francoski predsednik Macron pravi, da je nesprejemljivo, da Hamas izkorišča talce za izsiljevanje, in ponovno izraža podporo izraelskim operacijam.
In kako naj bi po vašem mnenju zgledala zmaga Izraela? Povejte mi po kakšni logiki bo Izrael dobil to vojno? Saj ne pravim, imajo sposobnosti da uničijo Gazo, jo zavzamejo, podrejo vse zgradbe in tam postavijo svoje domove ampak vse to je kratkoročno. Prebivalstvo Palestine raste bistveno hitreje in jih bo kmalu več kot Izraelcev. Izrael ima še problem v Egiptu ki bo imel kmalu 150 milijonov ljudi, poleg tega rast prebivalstva tako v Siriji kot tudi Iraku (obe državi v popolnem razsulu) strmo narašča. Prebivalstvo Iraka se je skoraj podvojilo od napada leta 2003. Prebivalstvo Sirije dobesedno raste še hitreje kot pri Iraku. Saj ne pravim to so države ki so danes v popolnem razsulu in nimajo za burek, ampak kako bo čez 50 let? Pa ne pozabite na sto milijonski Iran. Zgoraj omenjene države bodo imele skoraj 500 milijonov ljudi leta 2100. Takrat nas ne bo več ampak ali res mislite da bodo te države vse skupaj pozabile? In zdaj naj bi se spravili še na Iran? Po navadi je tako da ko napadeš neko državo in jo pahneš v revščino da se rojstva in rast prebivalstva hitro začne večati, ali Izrael sploh razmišlja o tem? Bodo imeli še Iran z 2x toliko ljudmi.
Dejstvo je da neglede nato kaj Izrael danes stori, se vseh držav v okolici ne bo mogel znebiti pa ni pomembno kako tehnološko naprednejši so in bodo od ostalih držav. Kot sem napisal že zadnjič, bog ne daj da ZDA nekega dne izgubijo svoj vpliv in svojo moč, ker potem je z Izraelom konec. Poglejte si zemljevid, kako majhna država je Izrael, obkoljena je pa iz vseh strani. Vsi vemo da tam spodaj ne pozabljajo takšnih stvari in da vlečejo odločitve na podlagi stvari ki so bile zapisane tisoče let nazaj.
Ne pravim da se Izrael nima pravice braniti in da Hamas ni problem, ampak kako bo čez 50-100 let? To ni dolgo obdobje sploh tam pri njih so to kratka obdobja. Realno gledano Izraela nekega dne ne bo več. Resno vprašanje, kako bo vse skupaj zgledalo leta 2100? Ali res mislite da bo Izrael še vedno na tistem območju?
Izrael ima nukico in USA. ;) Vikingi so bili pred stoletji najbolj krvoločni in borbeni narod, sedaj so pa Skandinavci najbolj mirni in demokratični z najmanj korupcije in želje po bogastvu. Mogoče pa mislimani malo podvomijo v Alaha v prihodnjih stoletjih, kot smo mi v Jezusa in RKC.
- spremenil: fur80 ()
Hypathia ::
Kakšno je vaše mnenje glede teze, da za Hamasom stoji Kitajska, kot to namiguje Rok Frelih?
https://www.domovina.je/vojna-v-izraelu...
fur80
Saj pravim, kaj bo ko bodo ZDA izgubile vpliv? Izrael ima lahko jedrske ampak ga bodo zgoraj omenjene države lahko izolirale brez vojaškega posega. Izrael je majhna državica ki nima niti 10 milijonov ljudi. Neka Palestina jih bo imela kmalu več. Ni vse v številkah vendar ko vidiš da so obkoljeni iz vseh strani in da imajo ostale države po 100 milijonov prebivalcev se moraš vprašati kako bo vse skupaj zgledalo že čez 50 let? Ti govoriš o stoletjih, jaz ti govorim o desetletjih. Samo zemljevid pogledaš pa ti je jasno da je samo vprašanje časa kdaj bo Izrael nehal obstajati. Samo malce logičnega razmišljanja pa nisem proti Izraelu in menim da ima vso pravico odgovoriti na Hamasov napad.
Pa koga od vas res briga usoda Izraela, ali samo malo tja v tri krasne moralizirate in se delate sočutne do ubogih ljudi? Palestnicev očitno nihče od sosedov muslimanov ne mara, in jih puščajo tam v Gazi in Zahodnem bregu, da Izraelci s njimi delajo kot z živino. Izrael se bo diplomatsko povezal s Savdsko Arabijo, pa se lahko Hamas in s tem Iran na trepalnice mečeta. Kaj bo pa čez pol stoletja tam doli, pa naj bo vprašanje za ljudi, ki dejansko dol živijo.
fur80
Izrael ima toliko vode, da jo prodaja sosednjim državam, kot je Jordanija. Zakaj bi nehali obstajati? Libanon, Jordanija, niso toliko veče, potem imaš tam spodaj Kuvajt, Bahrain, Katar, ZAE, ki so manjše... Egipt jih je pa priznal, naj bi jih tudi SA v prihodnosti. Grožnja so jim samo Palestinci in Iran. Preberi malo zgodovino so bili še veliko bolj ogroženi tam spodaj, tako predost in varnost kot jo imajo sedaj je nikoli niso imeli.
blay44 ::
Saj je čist enostavno. Imaš delujočo državo, ki spoštuje
osnovno etiko, ustavo, zakone in uzance. In seveda, sam
skrbiš za red.
Kako že, sosed je mejak ne vrag.
Takole izgleda "short-term thinking".
Če bi bilo res tako preprosto kot omenja Pompeo potem bi "eliminirali" vse sovražnike že desetletja nazaj. Skratka utopija da boš eliminiral vse sovražnike.
Torej praviš, da tudi priseljenci v Ameriko "niso ravno vzeli zemlje" domorodcem?
BREAKING - Israel to Egypt: If you bring supplies into Gaza we will bomb the trucks
Voda na iranski in Kitajski mlin ker v tem primeru se bodo morale vključiti ZDA.
Ampak še zmeraj je uganka, zakaj se je šel Hamas lotiti političnega, gospodarskega in vojaškega samomora.
Zna biti, da Izrael ni zamočil pri obrambi, ampak je to "presenečenje" naročil in plačal. Par mandeljcov, ki jim je vseeno za ljudi, ne pa za denar, z lahkoto kupiš. Hamasovce pa še posebej.
Kayzon ::
Lepo na koncu pove,obe strani imata toliko masla na glavi da mi je kar smesno gledati kako se usajate zdele eni glede bogih izraelcov.
Ah ko zivis v taksnem zaporu kot zivijo palestinci,ki so konstantno zatirani s strani izraelcev pac ni druge opcije kot da se ljudje radikalizira in potem prihaja do tega kar vidimo sedaj.
Čisto možno, ker nekateri so za denar pripravljeni narediti marsikaj.
Poleg tega me čudi, da Mosad tega ne bi zaznal, menda so jih še Egipčani opozarjali, da se na nekaj velikega pripravlja.
Ker mi pa damo ciganom najboljšo zemljo in plac? Pri nas vsaj samo ropajo in ne režejo glav.
Ko jim je Drnovšek peljal kontejner Ciganom, da ne bi zmrznili, so ga pljuvali v glavo Slovenci.
